04-27-2023, 05:03 PM | #1 |
184
Rep 337
Charging options - X5 xDrive50e - 2024
Hi everyone!!, so it seems there's nothing out there on how to charge our soon to arrive cars. The Genius are not so Genius and BMW's website redirects you to Qmerit which is the most expensive option in the world.
So... anybody knows how to charge the car? Does it come with one of the chargers? What's the real time it gets to charge the car with either charger, L1 and L2. What are the requirements or type of wallbox to purchase as well as the plugs on both sides. It's crazy that we have to wait until we receive the car to check this. Also the user's manual for these cars is not available online yet. Any info will be appreciated!! |
04-27-2023, 05:11 PM | #2 | |
13719
Rep 20,403
That manuals have been available for awhile now. Here is a link to some I downloaded. https://g05.bimmerpost.com/forums/sh....php?t=2005828
Xtabi1718.50 |
04-27-2023, 05:21 PM | #3 |
31
Rep 48
It comes with 10A adapter which fits the included "fast charger" which takes 30 hrs to fully charge on a regular wall socket.
There are several ways to make it work faster - I'm learning about it too (on the forum - thanks). I'm personally going to get a 14-50 NEMA socket built and buy a BMW OEM 220 V 40 A adapter (which fits the fast charger)that allows it to fully charge in ~2 hrs. |
04-27-2023, 05:39 PM | #4 |
Rep 98
I have ditched the Flexible Fast charger that came with my 50e. I installed two level 2 Chargepoint chargers. One at work and one at home. They charge my car from 0 to 100% in a little over 3 hours. I had them installed about a month before receiving the car. I chose not to use plugs but rather hard wired them.
rexus300155.00 |
04-27-2023, 05:59 PM | #5 |
Rep 522
04-27-2023, 06:11 PM | #6 |
Rep 443
I believe its this one?
https://parts.bmwnorthwest.com/p/bmw...905A13A61.html I am planning to get this and use it with the flexible fast charger but still debating to get the home 240V wall charger too. |
Gmag088.00 |
04-27-2023, 07:18 PM | #7 | |
Rep 6,946
New owners may not realize the actual charger is IN the vehicle...the EVSE is a fancy power cord. FWIW, the 50e user's manual linked appears to be for a Euro vehicle. I've not tried to get one for a US vehicle. |
04-27-2023, 07:20 PM | #8 |
13719
Rep 20,403
No, that was downloaded from BMWUSA using a US VIN.
04-27-2023, 07:25 PM | #10 |
13719
Rep 20,403
It could be they have/had the wrong one online or perhaps don't have a US specific one ready yet. It would be interesting to see what the hardcopy ones are. Maybe someone can chime in.
04-27-2023, 07:41 PM | #11 | |
24
Rep 49
I installed a Chargepoint Flex on a 40A circuit, so I'm getting the maximum 32A and 7400 watts at the X5 50e. It is awesome. The Chargepoint was super easy for my electrician to install. I like the look with the hard wire. I'm somewhat looking forward to the math / optimization around two chargers in my garage at some point in the future.. but I'm going to live with one for now. My 200A house feeds a 60A garage sub-panel, so I will likely need some sophisticated amperage balancing via software. Tesla chargers have good ways to do this, as far as I understand, and I'll wait for the other charging companies to catch up then buy theirs instead. |
04-27-2023, 08:31 PM | #12 | |
Rep 3,761
Actually, most EVSEs you can set charging limit. If you have two of the same brand, they communicate with each other and make sure a set max current won't be drawn at the same time. So no need to catch up, or they were never behind. In fact, Tesla L2 EVSE is the behind one. Their V3 lack many features compared to other brands.
2022 G05 B58/PHEV
+ a few very old BMWs |
04-27-2023, 08:34 PM | #13 | |
24
Rep 49
I'm fine with my single charger but would not be okay with two chargers. There's also the other amperage in the garage that would need to be balanced (treadmill being the worst offender). The Span solution is looking really smart for future two-car households. |
04-27-2023, 08:45 PM | #14 | |
Rep 3,761
As for garage load, maybe setup a charge time window where you don’t be using other devices, such as mid night or 1am to the next morning?
2022 G05 B58/PHEV
04-27-2023, 11:38 PM | #15 |
Rep 6,946
There are also EVSEs with dual cords, so it knows what each vehicle is asking for, and adjusts its pilot signal to limit them so they can share the singular input power line. Clipper Creek has one, and I don't think they are alone. Each will get part of the capacity until one finishes, then it will shift the rest of the power to the remaining unit. One box, one power feed, simpler, less expensive option if you are power limited. https://store.clippercreek.com/featu...al-rugged-evse Those that are smart enough to 'talk' to each other and split the power usually are required to be the same brand to work together properly.
04-28-2023, 06:01 AM | #16 | |
Rep 8,892
Drives: eVeRyOnE mAD!
if I had an X5 50e, the fastest it could charge is 24A if the 530e is also charging since the load-sharing program knows my circuit can only pull 40A max. I’m glad I went with JuiceBox for this feature, but truth be told, i initially got this brand because of the rebate incentive from my utility company. i only learned about its load-sharing feature after we got the 530e. |
04-28-2023, 08:23 AM | #17 |
31
Rep 48
I'm reading all of the above. My ? is if we are really looking at a hybrid vehicle with a smaller battery (compared to a full electric) do you really need to have the wallbox/chargeflex etc. Granted it seems better but isn't that setup significantly more expensive? My reason so far to get the adapter was it does the job fast - uses included equipment and therefore cost is less. Please correct me if I'm wrong (novice in the EV *******
04-28-2023, 09:33 AM | #18 | |
Rep 8,892
still, you may not need a level 2 if your use case doesn’t require it. note when plugged in to a common household 110/120V outlet, it will take ~24h to charge from 0-100%. on my 45e, I use 95% of the HV battery capacity every day, so the included EVSE is not fast enough to charge overnight which is why I added a 240V circuit and invested in a level 2 EVSE that takes 5-6h to charge from 0-100%. this way I’m guaranteed to have a fully charged battery every morning. for U.S. vehicles: level 1 = 110/120V level 2 = 240V |
04-28-2023, 10:57 AM | #19 |
184
Rep 337
Thank you!!
You guys are the best!! Thanks for all the posts, I will probably invest in a L2 charger, I don't like the idea of having to wait so long for a full charge of a small battery. Either way will use the new charger in the future.
04-28-2023, 11:13 AM | #20 | |
Rep 8,892
AloneAlien67.50 Levrac680.00 |
04-28-2023, 02:15 PM | #22 | |
bmwnewbie
Rep 30
