03-19-2014, 06:13 PM | #1 |
European Editor
10633
Rep 22,992
DIY electric water pump VIDEO for N-series (N51/N52.N54/N55) engines...
BavAuto put together a great video on how to replace the electric water pump/thermstat in our car. Plus the car in their video was a 135i, so its quite an interesting video!
BavarianAuto's DIY video on Replacing the electric water pump on late model BMW N-Series 6 cylinder engines...
03-19-2014, 08:56 PM | #3 |
84
Rep 1,623
Drives: Alpine White 128i Cabrio
Thanks for posting. I saw it a few months back on bav blog! Awesome info.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
Dackelone10632.50 |
04-01-2014, 06:56 AM | #4 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
Thanks a million Dack and BAV!!
Just recieved my pump and thermostat today. Can't wait to bring her out for the season.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
04-01-2014, 04:39 PM | #5 |
European Editor
10633
Rep 22,992
HondaGoneRogue be sure to post up some pics of the R&R-ing of the water pump for us 1Addicts.
Btw... your still in K-town right>? I am starting the planning phase of our summer Alpine Pass tour. So keep a look out in the European forum soon. I'm thinking of mid to late July for our tour.
04-12-2014, 07:41 AM | #7 |
433
Rep 3,762
Got the water pump swapped out. It took a little less than two hours following the video exactly. I didn't take pics because I was very rushed to get it done (working two jobs at the moment), and so I just flew through it. VERY straightforward. There were no surprises at all. All clamps and couplings came right off. Everything was able to come off with only a 1/4" drive ratchet, which made things a lot easier considering the small space you are working in.
I can't believe what the dealer chargers for this. Maybe I should go into that business haha.
04-12-2014, 04:45 PM | #8 | |
European Editor
10633
Rep 22,992
I remember when you posted pics when replaced your HPFP in the parking lot of Bitburg airfield! My hats off to you sir!
04-14-2014, 05:26 PM | #9 |
Rep 435
I just replaced my thermostat and I never want to do that again. What a PITA!
Enter voucher code XKRMLL for $5 off Carly adapter for BMW. For users ordering through Amazon UK or US, please contact trainer@mycarly.com PRIOR to your adapter purchase. You will receive a reply with a special voucher code. |
01-18-2015, 03:47 AM | #10 |
European Editor
10633
Rep 22,992
Cross posting... (pics and tips on water pump DIY)...
Another water pump down, <48k http://www.1addicts.com/forums/showthread.php?t=1021604
10-02-2015, 10:03 AM | #11 |
14
Rep 33
Starting mine today! Pump and t-stat.
Update: Completed successfully! Got sold the wrong t-stat (128i) and only noticed when I tried to re-install as they look almost identical. Had to scramble around on Saturday to pick one up from the local BMW dealer (who gave me a nice discount...thanks Maranellow BMW!). I did it all with the car up only on ramps, which didn't leave a ton of room underneath leading to lots and lots of cursing (sorry neighbours!). I have to say that without those videos from Bavauto, I would have taken one look at where the pump is and just given up! Just an excellent excellent video! Last edited by JohnnyG_TO; 10-04-2015 at 10:23 AM.. |
01-12-2016, 08:28 AM | #12 |
Rep 80
Great video and really not too bad of a job. I did mine using ramps and it made things a little tight. If you have access to a lift or jack stands, all the better. The worst part was disconnecting/reconnecting the hose form the radiator to the thermostat. It's positioned in such a way that you can't get any leverage and is pretty tight on the thermostat.
01-13-2016, 01:42 PM | #14 |
European Editor
10633
Rep 22,992
Because no one wants to go back in there. Mechanical thermostats fail so I don't think an electronic one is any more reliable. I would replace the thermostat - IF it were my car.
01-25-2016, 09:20 PM | #15 |
Rep 284
My water pump failed a few months ago and had no choice but to get a tow to the dealer and have them replace it. They told me my thermostat was still good, so they only replaced the water pump. I'm thinking I should replace my thermostat soon. Probably as soon as it gets nice out. Looks like I'll still have to remove the water pump? Anything else I should replace other than the aluminum water pump bolts?
01-26-2016, 03:49 AM | #16 | |
European Editor
10633
Rep 22,992
N54... See hose #1 here... http://www.realoem.com/bmw/enUS/show...diagId=11_3972 N55... See hose #1 here... http://www.realoem.com/bmw/enUS/show...diagId=11_4468
01-28-2016, 09:25 PM | #17 | |
Rep 284
02-18-2016, 10:22 PM | #18 |
Rep 284
Dackelone, if the dealer replaced the water pump bolts too when they replaced the pump, do I still need to get new ones when I switch out the thermostat?
02-19-2016, 04:46 AM | #19 |
European Editor
10633
Rep 22,992
Yes, you should replace them. The bolts are only good once. They are allu and will stretch once torqued. To be safe I would buy new bolts.
03-06-2016, 12:14 PM | #21 |
Rep 435
03-07-2016, 01:44 PM | #22 |
European Editor
10633
Rep 22,992
Btw... Looks like my waterpump is on its was out. I have a small coolant leak under the front of the engine. I don't see any coolant when I park my 135i, but I can see coolant at the front of the engine/radiator - inside the belly pan. A friend of mine who is a BMW tech says its very common for the e-pump's to develop a leak at the casting seam.
I'm at 124K kms - with my US spec 135i. :/
