07-21-2021, 01:13 PM | #199 |
I /// M FAN
427
Rep 428
BMW F15 roofs bars fits perfectly on the G05
I just bought used F15 roof bars, they fit perfectly on my new X5 G05
SmartSaves462.00 |
07-21-2021, 10:51 PM | #200 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Thanks for letting us know. Do you hear any wind whistle when you only have the roof racks installed?
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
07-22-2021, 08:59 AM | #201 |
I /// M FAN
427
Rep 428
07-22-2021, 09:06 AM | #202 |
I /// M FAN
427
Rep 428
Attached a picture of my X5 with the F15 roof bars
SmartSaves462.00 |
07-23-2021, 12:50 PM | #204 |
I /// M FAN
427
Rep 428
07-24-2021, 06:44 PM | #205 |
Rep 1,301
Anyone have a dual setup? Meaning a roof box and a cargo rack? I have the OE BMW bars and a Thule Atlantis 1800 box. I want to add a skinny cargo carrier. When I vacation trunk is full of stuff and I haul a seadoo. I just need some extra space to take a couple of iSUP’s ( stored in 2 backpacks 13” x 34” each) and misc stuff. The box and cargo carrier would need to be side by side so need a skinny cargo carrier that would squeeze in. Oh, and it’s an X6MC. Any ideas?
12-15-2022, 07:58 PM | #206 | ||
Rep 297
12-20-2022, 06:08 AM | #207 |
Rep 72
Are the cross rails fixed?
I was wondering if the cross rails must be in a fixed position or can be moved forward, back, or closer together? Looking at the OEM and the Thule bars.
Can you tilt or open the sunroof with these on? Also, how quick is it to put them on and take them off? Thanks. |
12-20-2022, 02:35 PM | #208 |
Rep 6,948
If you were to load up the roof rack to maximum, you might have problems if you located them outside of the designated points. Likewise, moving them might incur wind noise and more drag.
The OEM bars located where designated do not impact the sunroof's operation unless something attached were to project below the bars. |
12-21-2022, 11:47 AM | #209 | |
4992
Rep 11,891
02-12-2023, 09:32 AM | #210 | |
15
Rep 38
I initially saw an article 2 years ago showing a Tesla with its roof box mounted with the tapper to the rear. While not the same article, here's a good reddit link discussing it. All in all, it's twice as efficient to flip your box to the rear. Luckily I have a Yamika & it doesn't look too crazy in that config. |
02-13-2023, 12:46 AM | #211 | |
Rep 3,761
Both OEM and Thule Windbar Evo are very high, way above any sun roof clearance. In fact, I wonder why they needs to be that high, especially OEM. Put them on and take them off is easy one man job, I would say 10-15 minutes. Majority of the time will be used to aligned them. The method I use is a simple parachute cord, tie two knobs. I use it to locate where the foot of the bar needs to be.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 02-13-2023 at 07:21 PM.. |
02-13-2023, 07:13 PM | #212 |
Rep 6,948
If you search around, you can get the OEM bars for a major discount from Thule or Yakima. But, with new fit kits, you may be able to use those on your next vehicle if you don't sell them.
03-19-2023, 10:34 AM | #213 |
Rep 1,009
For those who have installed and removed the bars when not in use, does your rails show sign of wear/scratches? Specially if your X5 has black rails.
03-19-2023, 11:40 AM | #214 |
Rep 3,761
Yes they do. The spots the bars are clamped in look a bit dull compare to the rest of the rail. I kind of think they are rubber deposit from the rubber feets, because they largely buffed off. But I have only use mine twice, don’t know the long term effects.
aMIC31.00 |
03-19-2023, 12:12 PM | #215 |
Rep 1,009
I haven’t purchased these yet but do the clamps have rubber surface or is there metal on metal contact to the rails? In the close up photos I see there’s a rubber feet but what about when it clamps the inside and outside of the rails?
05-13-2023, 06:26 PM | #218 |
Rep 3,761
I am afraid you need to be a bit more specific. Which bar, which box, suspend height setting …..
Even with oem bars and oem box, the box has a few different version and size. Not a one height fit all kind of answer.
2022 G05 B58/PHEV
+ a few very old BMWs |
05-13-2023, 06:28 PM | #219 | |
Rep 200
It was for the vehicle with Wing bar edge with xl roof box |
eelnoraa2089.50 |
