01-27-2021, 12:50 AM | #199 | |
Rep 430
Thank you in Advance!!
2019 X7 40i Metallic Black
01-27-2021, 03:54 AM | #200 | |
1202
Rep 1,587
https://drive.google.com/file/d/1JFf...ew?usp=sharing |
FreddyBMW96.50 bimmerelectric14.50 |
01-27-2021, 11:37 PM | #201 | |
319
Rep 387
First, I noticed that there are 2 codes on the aSLA tab that are missing from the All tab. They are both in the DSC_VIP module: C_SLA_Anzeige_Zusatztexte C_SLA_aSLA_vorhanden Next, was a little confused as to what the following 3 groups of codes do: Group 1 Group 2 Group 3
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
01-28-2021, 02:15 AM | #202 | |
1202
Rep 1,587
Group 1- unrelated settings. DCA I believe relates to the driver camera, sicht_absicht is the forward looking system used in various places including Assisted Driving View, although not dependant on it. The other 2 are related to Advanced Driving Assist System, and lane prediction I believe. I haven't tested every setting independently. That would take forever. What I do is check what group of settings work together and that BMW have released together for a specific MY or i-step version. These settings may be across multiple ECU. Some are inter-dependant so I cannot be 100% that say, TLA is not in some way dependant on an unrelated setting in HU_MGU that I already have set but others don't, so I include the ALL MY21 spreadsheet for completeness only. The best way people can help with this is to test and feedback their own experiences, like akakingj and Baron G15 have done. Group 2 is the give way warning for stop, give way and traffic lights. It flashes and beeps warning as you approach these at speed. It needs an FSC purchased from BMW to work if you do not have it already. Group 3- Trojanlaw stated that his Lane Departure Warning came on at lower speeds and more often with this enabled. However, it needs more testing and feedback. |
01-28-2021, 11:30 PM | #203 |
319
Rep 387
@ifr That was awesome, thanks for the detailed responses. All this was pretty broken on 07/2020 I got the dealer to bump me to yesterday 11/2020 so I'm going to give this another go tomorrow night.
One more question, for now.. For the Group 2 code you referenced an FSC code, I am guessing this is some sort of purchased option though the app store thing? Similar to the speed camera subscription?
01-29-2021, 02:35 AM | #204 | |
1202
Rep 1,587
Results vary by region even with 11/2020. For example, aSLA works perfectly in most regions, TLA works well in the UK but is dependant on a regions traffic light system and BMW progress with that system, the highway exit assistant is a work in progress.... The FSC is '[0x01AD] right of way warner' and needs to be purchased from BMW either via a friendly dealer, or 3rd party such as those on the cartechnology forum. It's not available on the CD store, presumably as its a regulatory restriction by region. |
02-01-2021, 05:18 PM | #205 | ||
Rep 66
Can you please point some link to car technology? Can not find. Is it right that only coding will not get the TLA work properly? I have coded it with your help ( your cheatsheet) but not quite satisfied with the functionality. Have no mistakes. It works. The recognition is fine but convenience is not quite good. Is tha because of missing that FSC? And more question. Was that start on green on 07/2020 automatic? Or I miss something? Now I should press the gas pad all the time to start on green. Thanks |
02-02-2021, 01:40 AM | #206 | |
1202
Rep 1,587
TLA via coding works fine for me in the UK. You need to start manually on green i.e. press gas or resume cruise |
02-16-2021, 12:13 AM | #207 |
Rep 29
all, big kudos to the people helping in this forum. i am back on coding issues, just got my x5, still model 2020 looks like but i have the latest 11/2020 software (and no updates available).
I live in Belgium, i saw many other people in the forum in BE. Can we point what is missing, what limitations and what would work in Belgium? I was coding at the time of esys with the loader, now I believe if I want to code at this level of update on g05 I need to buy esysx license, am I correct? which exact version of pszxdata and esys? (I found many different indications) thx for all the help in advance |
02-16-2021, 10:01 AM | #208 |
Rep 8
The problem with loader seems to be its out of date and the mappings don't exist. If it is updated recently then I don't see why it can't be used, but i use esysx personally.
The esysx needs to be reasonably up to date for the mappings to be in place, from memory its Sept/Oct ish but if you're buying it new then it will be fine. I've used e-sys 3.27.1 which last tine I checked is still the version recommended and pszxdata 4.26.22 and successfully added TLA but if you can find the usual sources to download I'd just get the latest version. If ifr wants to correct me I will defer to his better judgement but hopefully this will steer you in the right direction |
02-16-2021, 01:19 PM | #209 |
Rep 158
Which of these features, if any on this topic, can be coded via BimmerCode Expert Mode on a US G05 at the moment? Any instructions on modules and parameters to change would be appreciated.
02-17-2021, 06:33 AM | #210 | |
Rep 29
I have 11/2020.38, aSLA and Lane change assist are there out of the box but I am not honestly impressed, still struggling with Lange change and ACC disengages in a very aggressive way, it looks completely detached from the navigation. I still don't realise what is active and what's not in Belgium, nor I know if TLA would be available in Belgium if enabled via coding. |
02-28-2021, 08:28 PM | #211 |
Rep 103
Drives: M550I/X6M50I/G83
hi
just picked up my m50i x6 & i dont have this traffic light thing is it coded or how can i get it? i would assume its updated since i just got the car? |
03-06-2021, 03:38 AM | #213 |
Rep 272
Also interested in this matter. Considering what app I should buy now. Will bimmercode be sufficient or should I get esysx to decode country restrictions for tla/asla?
03-06-2021, 04:24 AM | #214 | |
Rep 51
03-13-2021, 11:26 AM | #216 | |
Rep 1,181
Car updated OTA to 11/2020.50 this week and upgraded EsysX to the latest version with the latest psdzdata courtesy of Shawn. Using your spreadsheet, I just needed to change the 3 “FF, FF, FF, FF” values in the SAS3 module from your speed limit assistant tab and all of the coding from the TLA tab except the VIP module. Thanks again! |
ifr1201.50 |
03-13-2021, 11:38 AM | #217 | |
1202
Rep 1,587
It's working better than ever for me, which coincided directly with my upgrade, but could also be a cloud change by BMW. Hard to tell sometimes with this feature. It needs to learn about the different light systems, and they did say it would use cloud based machine learning to improve TLA, but what they say and what they do aren't necessarily the same |
03-13-2021, 02:28 PM | #218 | |
Rep 1,181
The next one, I didn’t realise if the car isn’t sure (conflicting red and green lights for different turns) you have to accept the red light and hit the Set button. Notification for the green light worked well too. I think I set this to early - not sure if this just controls the warning beep? Do you know if the 03/2021 i-step fixes the HUD issue where the tachometer is displayed in sport. Really missing that! |
03-13-2021, 02:48 PM | #219 |
1202
Rep 1,587
03-13-2021, 02:56 PM | #220 | |
Rep 1,181
07/2020 broke it and not fixed in 11/2020 either. The only way you can get the tachometer in the HUD now, is to set it to always on in the menu, but then switch it back when you want the driving assistance info. |
