02-21-2024, 04:33 PM | #221 |
Rep 1,022
Yes, I know the button still works....
This is what I have this on my cheat sheet of things to go through whenever software update occurs Engine Control Auto Start Function Memory Active Auto Start Stop function Not Active |
02-22-2024, 08:26 AM | #223 |
13724
Rep 20,406
Congrats.
02-22-2024, 10:44 AM | #225 |
Rep 105
Well the way TB was saying for a minute, I had a 50/50 shot of it working. I know I'm not on the latest over all version though. The biggest thing reason I wanted to upgrade was the transmission EGS software bug. Previous version -- The current software version of your vehicle may mean that the electronic transmission control continues to consume energy after parking the vehicle and may result in the total discharge of the 12V battery. BMW Defect code 0024720100
2021 X5 xDrive40i M-Sport | Phytonic Blue / Cognac
02-22-2024, 11:00 AM | #226 | |
13724
Rep 20,406
02-22-2024, 11:13 AM | #227 |
Rep 105
Well then the BMW App does a poor job of explaining that since it said The current software of my vehicle. (prior to me upgrading)
02-22-2024, 11:39 AM | #228 | |
13724
Rep 20,406
Interesting, never heard of it having that on the app. You were running 11/2020.50 and the issue was introduced in 07/2022.50 and ran through 11/2022.31
02-22-2024, 12:10 PM | #229 |
Rep 105
I was on 11/2021.50, but that doesnt matter since apparently I wasn't affected as the bug wasn't even introduced yet
02-22-2024, 12:18 PM | #230 |
13724
Rep 20,406
Sorry, mistyped that.
02-22-2024, 04:03 PM | #231 |
Rep 105
Well....on the drive home I noticed that my gesture control barely works now and when it does its spotty at best. Tried the IC reset and its still bad. My hand has to be about 3 inches away from from the sensor and it only recognizes volume up and down but doesn't keep going. It's like it flicks the volume knob and let's go. Won't recognize any other gesture.
02-22-2024, 05:37 PM | #232 | |
Rep 8,893
Drives: eVeRyOnE mAD!
after every update, I go through the entire menu and verify all my settings. some may reset to default or become disabled from updating, so you may want to double-check your gesture control settings |
02-22-2024, 10:15 PM | #233 |
Rep 105
Thanks. I may give it a few days and see if it irons out. I was just really bummed that gesture control was broken. It was the first drive on the new software. I must have. Looked odd to other drivers though.
02-23-2024, 01:29 PM | #235 |
Rep 105
Nice! Does your X5 have gesture control by chance? If so, does it still work? I'm curious since I'm only on 03/2023.67 and telling me there is no further updates available.
02-23-2024, 02:23 PM | #236 |
Rep 508
Drives: 2022 X5 xdrive40i msport
Is Bimmercode affected by the 11/2023.50 update iDrive7 X5?
02-23-2024, 03:10 PM | #237 |
Rep 105
If you mean do you have to redo the settings, I have heard from other people that you have to re-apply any settings that you coded in. If you mean does it not work at all any more, I haven't seen anyone saying that.
02-23-2024, 03:27 PM | #238 |
Rep 1
I did the update today. No issue with the installation but now (1) music doesn't appear in the BMW interface and (2) the forward and reverse buttons on the steering wheel do not work. FYI I use CarPlay and the same issue occurs whether in BMW or CarPlay. Is this just me?
02-23-2024, 03:33 PM | #239 | |
Rep 105
Fieldst550.00 |
02-23-2024, 04:12 PM | #240 |
Rep 508
I was able to update the software to version 11/2023.50 and use bimmercode to reset everything back. It does reset the normal settings pre bimmercode changes.
02-24-2024, 08:17 AM | #241 |
Rep 105
I don't want to jinx it, but on my way home from work yesterday gesture control appeared to be fully working again. I am not sure If it's related, but I also finally set up my profile in the car before leaving work as well.
nZtiZia4770.50 |
02-25-2024, 08:50 PM | #242 |
Rep 198
Completed the update. Bimmercode seems to revert back to factory. Wondering if any of the coding stays. My 5 times turn signal stayed but the option to choose was gone.
