06-25-2020, 05:09 PM | #265 |
135
Rep 372
06-25-2020, 07:29 PM | #266 |
Rep 71
07-04-2020, 12:07 PM | #267 |
2019 X5 40i
117
Rep 226
Thanks ifr
I compared the codes and found below codes were different ACSM5 -- [1B2D] a_pdc: aktiv [01] -- Default : Initwert [00] a_pdc_fp: aktiv [01] -- Default : Initwert [00] HU_MGU -- [3E52] ACTIVE_PDC: aktiv [01] -- Default : nicht aktiv [00] After I made the changes, I do see the option in iDrive for "Active PDC with braking intervention" and I was able to activate through iDrive Will have to test if this works as expected Note : I did get some error messages on iDrive while coding, Parking Assistant malfunction, Driving assistance reduced I was able to verify that the Automatic Parallel parking worked perfectly fine after the coding updates
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 Last edited by anuj452; 07-04-2020 at 12:12 PM.. |
07-04-2020, 12:28 PM | #268 | |
135
Rep 372
07-04-2020, 01:01 PM | #269 | |
1202
Rep 1,587
Don't worry about the coding errors. Just temporary. |
07-05-2020, 12:46 PM | #270 |
135
Rep 372
Not sure if anyone noticed or is still interested, but some peeps on the G20 forum figured out ambient lighting custom colors! It works via bimmercode expert mode within BDC. Got rid of the nasty mint green and made it true green, added a red pallet and did a blue and red M profile.
Coding More Ambient Colors And Amber Sidemarker Delete? https://www.bimmerpost.com/forums/sh....php?t=1708753 |
07-05-2020, 01:31 PM | #271 | |
Rep 2,610
07-05-2020, 01:38 PM | #272 | ||
135
Rep 372
LexxM31703.00 |
07-05-2020, 02:47 PM | #273 | |
Rep 5,463
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-05-2020, 03:10 PM | #274 | |
Rep 5,463
Forward, it just runs over the box, so a_pdc_fp active seems to not be enough assuming that means forward. Rob
2025 X5 Msport
07-05-2020, 05:09 PM | #275 | ||
1202
Rep 1,587
Not sure it's offered. Fp could mean flank protection. For ref, if an option is available in idrive and grayed, it means it's only enabled in the interface (hu_mgu) and needs other codes in another ECU. If it's available and not gray, then it usually means it's fully active. |
07-05-2020, 06:25 PM | #276 | |
Rep 5,463
2025 X5 Msport
07-07-2020, 10:33 AM | #277 | |
Rep 64
https://docs.google.com/spreadsheets...CW2o14FGI3oXWE |
LexxM31703.00 mandomedic12240.50 |
07-07-2020, 10:44 AM | #278 | ||
135
Rep 372
07-07-2020, 12:00 PM | #279 |
Rep 64
I wanted to automate it more and put more entry validation in it to avoid errors.. but I rode the struggle bus getting it to where it is... I am no coder or excel guru. Google gets me over the hurdles
07-08-2020, 10:42 PM | #280 |
Rep 159
My 2020 m50i just completed the software update. Some of my prior coding was lost. Disable Legal warnings, Default start in Adaptive, keyfob close tailgate. Interestingly, I did not lose my Alpina dash.
I updated to the latest psdzdata. It connected. I could code <cafd id="00007083" name="BDC_BODY3" author="jokinawa" series="S18A"> <!--3075 LceMaster--> But not <cafd id="000044ED" name="BDC_BODY3" or <cafd id="00003E52" name="HU_MGU" It could not read the coding data. |
07-08-2020, 11:24 PM | #281 |
Rep 71
Hi,
I just got a loan X6 and found this new setting under Activate PDC emergency interv. iStep 11/2019.70 Has anyone got this? Last edited by jeet; 07-08-2020 at 11:30 PM.. |
07-09-2020, 02:26 AM | #282 | |
Rep 2,610
07-09-2020, 05:11 AM | #283 | |
1202
Rep 1,587
There are codes to enable on MY2019, but the checkbox cannot be enabled in idrive. I believe this is because the radar sensors in the flank, SRR (HRSNR and HRSNL) need to be coded to High_Performance type. When coded, these generate an unsupported hardware error in ISTA, and the system cannot be activated. The two front sensors don't complain when configured as High_performance, I guess because these support the capability. Guess you could replace the rear sensors if really required, but I would never use it. It's hard enough reversing out of the garage with the rear braking enabled, never mind flank as well! |
jeet26.00 |
07-09-2020, 05:13 PM | #284 | ||
135
Rep 372
07-09-2020, 05:17 PM | #285 | |||
1202
Rep 1,587
07-09-2020, 07:02 PM | #286 | ||||
135
Rep 372
