03-22-2021, 11:26 AM | #288 | |
1202
Rep 1,587
It's the UNBELEGT at the top of SAS3 in older versions of esysx |
03-22-2021, 03:24 PM | #290 | |
Rep 242
All code it’s ok, my car now read traffic light and stop when is red (and call me when change in green) I see that my car now read signals that I don’t see Tomorrow I will verify |
03-23-2021, 10:27 AM | #292 | |
1202
Rep 1,587
I'm 95% certain your region is not allowed, but we'll know for sure when you've maxed out all the masks. |
03-23-2021, 09:50 PM | #293 | |
11
Rep 35
A samurai doesn't have a goal, he has a way |
volodp199.50 |
03-24-2021, 12:15 AM | #294 |
Rep 207
I am still thinking what thing i had miss out. I had code all the things in aSLA and TLA except the below.
1.) C_SLA_Vorausschua_Land_Altiv (I do not have this line in my DSC_VIP) 2.) C_SLA_UCC_Land_aktiv in DSC_VIP I had also tried update to the latest psdzdata and recode. My version is 11/2020.42. I still do hope it is not country restriction. |
03-24-2021, 01:16 AM | #295 | |
Rep 242
Very strange I have both and I think all basic code are similar Wait the reply of ifr that he know moooore |
03-24-2021, 02:24 AM | #296 | |
1202
Rep 1,587
I don't think you have missed anything, and coding the other land masks for 'potential' dependant systems was only an experiment. Where a mask has at least one binary bit enabled then its being used by BMW to 'firewall' a feature and the extent of that feature based on region and also potentially model. I max (all FF) these out as generally I want all the available features. For example, KAFAS\VFW_COUNTRY_VARIANT_MODE is already set to allow UK GWW and WWA, but by maxing it, I also get Traffic Light Recognition so it warns if both TLA and the driver don't slow for a red light. This is actually an interesting code. It generates errors if you do not have the correct FSC, which many regions do not, which is why I don't recommend changing it for TLA. There is still a slim possibility that it is related to TLA but I doubt it, mainly because some without the FSC in the USA have TLA working. If the land mask is all 00, then BMW are not using it to enable any features on any models in any regions. Doesn't mean it won't do anything, but it does mean that if it does work, then it's for a dev or future state feature. In the case of TLA and Singapore, I have to refer you to this: https://g05.bimmerpost.com/forums/sh...&postcount=278 |
03-24-2021, 03:05 AM | #297 | |
Rep 207
Hi,
I guess i have to give up on TLR. Thanks for all the advise for me to get it work. Quote:
03-24-2021, 03:12 AM | #298 |
1202
Rep 1,587
03-24-2021, 03:17 AM | #299 | |
Rep 194
I'll do the coding next week once my car is serviced and report back. |
03-24-2021, 03:29 AM | #300 | |
1202
Rep 1,587
If you can't get the SLI working right, I can't see any way forward. |
03-24-2021, 03:41 AM | #301 | |
Rep 194
I'm failing to understand how KAFAS (only) would not work at all for SLI though... I'll just code and see anyway. |
03-24-2021, 04:43 AM | #302 | |
Rep 207
Hi,
I am able to get the speed assistant to work. It is able auto accept speed limit and show anticipation after coding aSLA. Before coding, it just show “Anticipation is not available in this country” and basically selecting “Adjust automatically” for speed limit do not work. After coding, it work nicely and able to anticipation the change of of speed limit ahead of how many meters and display above the current the speed limit. This leave me wondering if this is able to work, why not TLR? Quote:
03-24-2021, 05:24 AM | #304 | |
11
Rep 35
C_SLA_Vorausschau_Land_aktiv.... Both are available, even in the absence of TLR |
03-24-2021, 05:44 AM | #305 |
Rep 207
03-24-2021, 06:39 AM | #306 |
1202
Rep 1,587
Yes, it's in the spreadsheet - single mask starting VFW in KAFAS (40F8).
You will need GWW FSC or it will error. You can tell if its worked as the iDrive Drive Assistant menu for Stop/Give Way/Traffic lights will change to allowed, from partially allowed or not allowed. and before you ask... YES! you need to copy and paste/replace the huge FF, FF.... mask into esys |
03-24-2021, 07:18 AM | #307 |
185
Rep 303
What are the driving assist prerequisites?
Are there any new features for SA 5DF and/or SA 5AS?
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
03-24-2021, 07:52 AM | #308 |
1202
Rep 1,587
