07-04-2023, 12:27 PM | #287 |
Rep 3,760
Guys, common. Hardware and plug has the same power and efficiency for all the intended purpose. People can argue the plug may add some resistance in the connection, but think reality, how much??? It is negligible in the grand scheme. NEC is so conservative, You think they will approve plug if difference isn’t negligible.
Plug vs wire, just pick the more convenient one, installation and availability, or many lower cost …. . There are a lot more meaningful things in life than spending time in this. Last edited by eelnoraa; 07-04-2023 at 12:34 PM.. |
07-04-2023, 12:33 PM | #288 | |
Rep 3,760
07-04-2023, 06:10 PM | #289 |
Rep 6,946
The vehicle will never pull more power than its internal power supply can use. Just like you can plug a 50W lamp into a circuit that could handle 1800W(15A*120V), your BMW can't use more, even if you plug in an EVSE that can supply more. The EVSE sends out a pilot signal to the vehicle that announces the maximum number of amps it can supply, then it's up to the vehicle to never try to draw more than that. Internally, you can opt to set a maximum amount of amps, but that doesn't work across the board, depending on the specific device.
ramachk1.50 |
07-04-2023, 07:01 PM | #290 | |
Rep 8,891
Drives: eVeRyOnE mAD!
Watts (W) divided by Voltage (V) = Amps (A) 7400W divided by 240V = 30.8A ... 22kWh (adjusted for charging losses) divided by 7.4kW = ~3h |
07-05-2023, 01:12 AM | #292 |
Rep 6,946
An EVSE is a fancy, semi-smart power cord...all of the charging logic and the AC-DC conversion is done IN the vehicle. A typical EVSE costs less than $1k...a CCS unit can be $20K or more, and it would be a rare home that had a large enough power panel to support one.
The X5 PHEVs do not have HVDC (CCS) charging capabilities. A CCS unit IS a DC power supply that wouild bypass the AC-DC converter in the X5 PHEV if it had that capability (mostly on BEVs, not PHEVs). Those, when available, tend to be higher powered than the one in the vehicle as they can be larger and have more cooling capacity. |
07-07-2023, 11:24 AM | #293 |
Rep 194
Drives: 2024 X5 50e
For those in the Dominion Energy service area and who have signed up for the Residential Charger Program, any initial feedback?
It seems like something close to a no-brainer, at least for me. Installing the wiring and plugs will be at least $2k, not counting the cost of the charger itself. The Dominion Energy program is $40 a month for everything all in, with a $125 rebate off the charger purchase and $40 rebated annually for keeping with the program. It's essentially taking my total installation cost and spreading it out over five years. Even Dominion Energy being able to pause my charging during high peak times can be over-ridden if I really wanted to (I would mostly be charging overnight, so I'm not sure this would be an issue for me.) What's the downside? I'd be interested in anyone's feedback who signed up. Thanks
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
07-07-2023, 12:22 PM | #294 | |
Rep 28
Drives: 2023 X5 xDrive 45e
07-07-2023, 01:28 PM | #295 | |
Rep 110
07-07-2023, 02:06 PM | #296 |
Rep 194
Drives: 2024 X5 50e
Right it’s $40 a month, and effectively you get one month back a year, plus the savings of $125 off the charger. I thought I was clear above, but sorry if I wasn’t.
I’m not following why you think it’s not worth it. Effectively it’s no cash outlay upfront to install the wiring, plugs and charger. In my case, it would take five years before my $40 monthly payment on top of my regular electric bill would exceed the cost I would have had to pay up front to an electrician. |
07-07-2023, 02:16 PM | #297 | |
Rep 8,891
yes, there’s a $40 annual rebate on your anniversary month. when I signed up in late 2021 here in VA, it was called the Demand Response program. I don’t have to pay $40/month to be in the program, though, yet I do get the $40 annual rebate |
07-07-2023, 03:29 PM | #298 | |
Rep 3,760
2022 G05 B58/PHEV
+ a few very old BMWs |
07-15-2023, 08:18 AM | #299 |
Rep 70
Sharing some more information as I'm learning through the process. Unless one has a strong preference for NEMA plugs, the EVSE is best hardwired. Random tidbits :
- Consider future and not x50e since new evse setup is not cheap. You'll likely be upgrading x50e or getting pure BVs whose demand is going to be much higher than x50e. - NEMA plug means 50A breaker --> 40A max charge current irrespective of charger. Good enough for x50e, not so much for any other EVs. -Cheap NEMA plugs can cause heating and other issues. - Chargepoint can go charging hardwired at upto 80A on a 100A breaker and correct wiring. Keep the future demand in perspective. - A NEMA plug is going to require 6/3 wire (4 strands) while hardwired Chargepoint/Emporia can work off cheaper 6/2 (3 stands) wire. There's a significant price difference between these wires especially if you have long run to garage. In my case I recently got a Volvo and am doing hardwired Emporia that can charge at 48A max on a 60A breaker. |
07-15-2023, 09:12 AM | #300 | |
Rep 53
You can do a nema 6-50 - 6/2 wire at 50 amps as well 6/2 or 6/3 is rated for 60A hard wired. So if you do a nema plug you can swap to hard wired and upgrade your breaker and you can get 60A. |
07-15-2023, 09:58 AM | #301 |
Rep 3,760
6AWG is good for 55A per NEC. So to pass inspection, you need to use 50A breaker. 60A breaker will technically fail inspection. If you hire a licensed electrician, he/she will not risk the inspection fail with a 60A breaker
07-15-2023, 10:04 AM | #302 |
Rep 110
Dumb question: does the BMW Wallbox have any useful integrations with the car itself or the My BMW app? Anything value to it over a Charepoint or Juicebox?
07-15-2023, 10:08 AM | #303 | |
Rep 70
Regarding the wire - also found out that Romex 6/3 or 6/2 is rated at 55A max but only 44A continuous. If you truly want the 60A then you have to use the individual THHN wire which can also get very expensive. |
07-15-2023, 10:12 AM | #304 | |
Rep 3,760
When all things are allowed, absolutely run the largest wire for EVSE, but in reality, it is a lot more complicated. You need to consider panel size, run distance, cost, and most importantly benefit of the additional cost. 40A charging give you 32kWh for 8 hour of charging overnight. Average BEV will easily do 3.5mil/kWh, that is 100 mile worth of charging every night. How many people commute 100 everyday? The reality is not the bigger the better. You need to size according your usage. |
07-15-2023, 10:23 AM | #305 | |
Rep 3,760
As for cost, they are actually very equal in normal time. Now, price fluctuate, so some time 4x THHN is more then same wire count Romex, sometime less. Now if you go large gauge, say 2AWG for 100A, I haves never seen 2AWG romes myself. With 3 or 4 wire Romex, I am not sure this wire can be run more than a 10-15 fit with a few turn. So chances are you need conduit and THHN anyway. |
07-15-2023, 03:17 PM | #307 |
Rep 6,946
An EVSE is a fairly dumb power cord. The only smarts related to the vehicle is its pilot signal and safety interlocks. The pilot signal tells the vehicle the max current it can provide, and the interlocks determine when it is safe to provide the power.
Some WiFi enabled EVSEs may add monitoring of the system that may be more complete than what you can get from the app, and may have a more flexible off-peak charging routine. Other than that, what you pay for are aesthetics, max power, and the length of the cable. |
couchgate133.00 |
07-16-2023, 07:32 AM | #308 |
499
Rep 328
Is there new version of the JuiceBox? Don’t know where I saw it but saw one with a black handle on a recent purchase post. Nonetheless, very happy with our JuiceBox 40. Went with the plug in version and had the larger wire ran to upgrade in the future. Aesthetically, I think it’s one of the better ones on the market.
