03-31-2021, 12:59 PM | #331 |
Rep 133
After a long wait, and about 6 weeks in the shop for an dead DKombi, and a "Driving Assistance Malfunction" error after they replaced the Kombi, I was able to code the TLA function. I'm in the US and sometimes it recognizes the lights, and sometimes it doesn't. I also notice that when it does recognize the lights, it wants to stop right at the bottom of the actual traffic lights. Traffic lights in the US are placed on the opposite side of the intersection and not at the point where you need to stop like in Europe. Could this behavior be because of that? As for now, I don't use it, because it's dangerous.
03-31-2021, 01:18 PM | #332 | |
1054
Rep 1,952
On mine I have to confirm it, for it to stop and I'm not sure if there's some coding I have to tweak. |
03-31-2021, 03:10 PM | #333 | |
Rep 1,181
03-31-2021, 08:51 PM | #335 | |
Rep 133
I also notice that it attempts to stop in the middle of the intersection if the light turns yellow while going through it. It must be due to the region settings and how it's not ready for US deployment. Armando |
03-31-2021, 11:18 PM | #336 | ||
Rep 176
Drives: 2019 BMW 330i
The scary ones are when it automatically tries to stop as it's passing through the intersection! It's embarrassing because it makes it look like I'm brake checking the person behind me. Doh! I'm on 11/2020 software. |
mandomedic12240.50 |
04-01-2021, 02:34 AM | #337 |
1202
Rep 1,587
Thinking about it pragmatically, unless there are significant improvements in 03/2021 for the US, which I would doubt as it's still not announced for US models, then it sounds like it's not worth enabling. That behaviour sounds both annoying and potentially dangerous.
if you uncheck the 'Consider traffic lights' in the Speed Assistant, does it just give you the TL recognition in HUD? Not sopping but better than nothing, and the green light reminder should still work. If that disables it entirely, then change SAS3/aUCC_Land* back to the default bitmask. This should disable the automatic stopping part. It will still present SET, but you don't have to use it and it wont put you in a position where its stopping automatically but badly. At this stage it sounds like the Give Way Warning would work better for the US i.e. it warns if you are about to run a red light night/stop sign/give way sign, but that requires an FSC in addition to the KAFAS coding. |
04-01-2021, 03:05 PM | #339 | |
Rep 184
Drives: 328i N26
04-01-2021, 03:34 PM | #340 |
1202
Rep 1,587
I've decided to pull all coding support for TLA including the spreadsheet.
While it works well In the U.K. it seems it's still not active on MY21 models and as such not considered production ready. Factoring In dangerous behaviour in other markets, I'm calling time on my involvement for now. Obviously the coding is out there, but I dont recommend anyone try it unless you know what you are doing and are located in the EU. Even then, coder beware! |
04-01-2021, 04:48 PM | #341 | |
Rep 197
ifr1201.50 |
04-02-2021, 12:04 PM | #342 | |
Rep 242
Hi ifr I confirm that even in Italy already with the 11.2020 firmware it worked perfectly (maybe because the form factory of traffic light are more simple than in other countries), he also read the sudden change from orange to red. now my car has been updated to firmware 03.2021 so I will test again to see if there are any improvements. rather I wanted to know from you if in this new firmware bmw add the function that allows you to drive without hands on the steering wheel at speeds below 40km / h (even on urban roads) .. or if it was already present? because this morning in traffic I was almost 5 min without hands on the wheel and on the instrumental cluster didn’t appear ejta+ Very strange but very comfortable |
04-02-2021, 12:10 PM | #343 | ||
1202
Rep 1,587
Maybe they changed the HOD parameters to align with better SWA algorithms? |
04-03-2021, 12:05 AM | #344 | |
Rep 176
The only location I saw is attached. I unchecked there and it didn't make a difference, it would still auto stop at certain lights. I usually have my foot right by the gas so it's not a big deal, but certainly not ready for primetime. Especially if one is not aware of the limitations. Hopefully soon or eventually they work out all the kinks and enable it. My guess is that will happen only with iDrive 8 for the US. [IMG][/IMG] |
04-03-2021, 02:33 AM | #345 | |
1202
Rep 1,587
The menu you posted checks for when the lights turn Green and then prompts if you aren't paying attention. Quite useful. |
04-03-2021, 03:22 AM | #346 | ||
Rep 176
Thanks for pointing me in the right direction! Some of these menus aren't as intuitive as others, and I thought I had seen it somewhere before. |
04-03-2021, 02:27 PM | #348 | |
1202
Rep 1,587
04-03-2021, 08:49 PM | #350 |
Rep 156
The only traffic light assistance I would like to see is a quick sound alert when the light goes from red to green. Sometimes the light is just hard to see, or I may he distracted. Should be easy to do, right?
04-04-2021, 02:01 AM | #351 | |
1202
Rep 1,587
Some of the US forum members should be able confirm that they can activate that without enabling the full TLA. I guess you could break it into 3 parts: 1) Traffic Light recognition - displays light status if not green in the console/HUD 2) Stops, either after manual confirmation or automatically, on amber/red lights 3) Warns (visual and audible) when light changes from red to green Any combination of these should be possible with either coding and/or i-drive menu configuration after full coding. |
04-04-2021, 04:19 PM | #352 | |||
Rep 66
Because when I have coded TLA and aSLA ( thanks for your ideas) on 11/2020 it started to be annoying in city. TLA and other features are great. But that wheel... The most annoying thing is that It even asks for it when you have your arms on it. |
