04-04-2021, 04:36 PM | #354 |
Rep 66
04-06-2021, 03:07 AM | #355 | ||
Rep 176
Drives: 2019 BMW 330i
So this certainly makes it a lot safer in the US simply by unchecking that option. Thanks again for the info ifr! |
ifr1201.50 |
04-06-2021, 04:42 AM | #356 |
Rep 242
Hi ifr,
With 03/2021, tla seems to work very well although I am noticing that it no longer signals me with the sound when traffic light turns green. I wanted to ask you if I want test only the highway exits, can I code only the relevant module? (Without emergency exit and other things I don’t need) |
04-06-2021, 05:44 AM | #357 | |
1202
Rep 1,587
You can code just highway exits but I haven't tested them independently so you will need to figure the coding out yourself. I believe its qman for exit assistant. It's a poor feature, as is the no undertake/overtake option. The emergency lane formation is a good concept but also useless when yours is the only car using it |
04-06-2021, 07:54 AM | #358 |
Rep 21
Hi ifr,
A question to you: In the dsc/vip ecu (I know not really necessary but I wanted to code it anyway) regarding Land masks it is said to change to 0xffffffff. But the read out values under „werte" are in format 00, 00, 00, 00, 00. Question is: Should you change it to the same format: ff, ff, ff, ff Or really to the format: 0xffffffff Or even to the format: 0x, ff, ff, ff, ff Coded the land masks to ff, ff, ff, ff instead of 0xffffffff resulted in no errors and successful coding message. Thank you for any help or at least indication in this |
04-06-2021, 11:00 AM | #359 |
1202
Rep 1,587
leave as is. the fact its set to all 00's means its not enabled for anyone anywhere, so unless you want to be an alpha tester dont touch.
for reference, if you are changing a werte from xx, xx, xx, xx then you should keep the formatting exactly the same. e.g. 08, 00, 00, 00 would change to FF, FF, FF, FF The obvious answer is nearly always the right one, even with BMW |
04-06-2021, 12:22 PM | #363 |
1202
Rep 1,587
Not that I can be bothered explaining
I've said it many times before. aSLA and TLA is advanced coding. If peeps don't know how to edit werte, or have the discipline to track changes made to your 2-3 tonne weapon, then you should cut your teeth with bimmercode, or something simple. or pay someone to code it for you. These level of changes are serious. No more questions direct to me people. Its a community forum, direct them to the community. |
leightos189.50 Bambazonke213.00 |
04-06-2021, 01:48 PM | #364 | |
Rep 1,181
Search for the specific code and you should see how Werte was set before you made the change. |
04-06-2021, 02:02 PM | #365 |
Rep 242
Right as says srbs73
Write always ur changes on excel or notepad (or where u want) to repair any problems it should be simple, the ecus used in the encoding (from memory) were only sas, vip, Bdc and hu_mgu Bye |
04-06-2021, 02:43 PM | #366 |
1202
Rep 1,587
Anyone who has esysx can generate stock ncd/fwl configuration without going anywhere near the car, as long as you have saved your FA and SVT.
You can compare the difference between what is currently coded, and what the stock configuration for the car's FA is. With expert licence you don't even need an SVT - you can make your own for any i-step current or past, as long as you have a saved FA. It's in the esysx manual. |
marcosg24.50 mandomedic12240.50 |
04-06-2021, 02:50 PM | #367 | |
Rep 242
Really?? Oh great I didn't know this possibility, thanks for the information ifr. the generation of the ncd stock files is always found in the manual or is it only related to the part with the expert version? Thanks Edit: found on the manual at 5.3.4 NCD/FDL calculation with FA + SVT I will read it, thanks |
ifr1201.50 |
04-08-2021, 09:08 AM | #369 | ||
Rep 21
It is indeed. The section for creating stock ncd's out of stock FA and svt is hidden under expert mode -> coding-verification With created new generated stock ncds you can code them back to the ecus and doing so coding the cat back to stock or you open them via FDL editor and compare with your current codes in your car Interesting for someone who forgot to create coding sheet and wants to do it now or check the what he has done. Thanks guys! |
04-12-2021, 08:05 AM | #370 |
Rep 4,452
My U.K. dealer has advised that TLA is not available here by design, so I'd need to wait until BMW enables that functionality @ifr
04-12-2021, 10:13 AM | #371 | |
1202
Rep 1,587
They advertised it in brochures and press releases as coming to the UK. They are even still be advertising it in the UK configurator - checkout the 5 series DAP detail. Strange that they even allow it to be enabled in menu, but disabled with land mask block. Doesn't sound like much of a design to me, more like a mix up. At least with aSLA in North America, they don't offer the option to automatically accepted Speed Limits, but then block it when you choose to do so. |
04-12-2021, 10:21 AM | #372 | |
Rep 4,452
They said if I have seen it somewhere on a U.K.-spec car, it’s non-standard and only there because it has been added on. I’m in no rush to have it, but it would be nice to get that functionality at some point soon. |
04-12-2021, 10:25 AM | #373 |
1202
Rep 1,587
point them to the configurator. if you can get it work - seems they've messed the BMW UK website up too.
04-12-2021, 10:27 AM | #374 | |
Rep 4,452
I'll try a different dealer tbh, probably Sandal Wakefield as that's what I've done before when Sytner hasn't played ball |
