05-23-2024, 07:13 AM | #23 |
Rep 2,175
Summer tires start to lose.grip at 60-65 degrees ambient temps depending on the tire. By 40 they're very slippery. By 30, they can be damaged. 20? Forget about it.
05-23-2024, 07:46 AM | #24 |
Rep 240
I live in the south and I can feel the difference in the tires through winter. Just sayin'. I don't want to swap out tires so I put on all season.
2025 X5 xDrive40i (Blue Ridge | Silverstone | 21" Style 744)
2012 Z4 35is M Sport Adaptive (Atacama Yellow) |
05-23-2024, 12:04 PM | #25 |
Rep 114
tire rack has PIRELLI P ZERO ALL SEASON 2,500 for a set of four for 22" wheels. I wonder if changing just the tires to all season would do the trick? or do I definitely need to buy 20" rims and tires?
05-23-2024, 12:19 PM | #26 |
16004
Rep 22,833
Since you said you don't get much snow you will be fine.
05-23-2024, 12:21 PM | #27 |
Rep 4,287
No no no. If ground is dry, summer will out grid all season and winter down to 0C/32F at least. Above 40F, the same car with summer will run circle around all season. The real issue for summer tire is wet + cold or ice. Reason is at say 40F or so, wet surface won't allow tire to warm up. If temperature is at 60F range, even in drechned surface, summer will win by big margin because the channels in summer pattern will dissipate water much more efficiently. Winter tire's grid is low to begin, it just doesn't degrade much in cold + wet.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 05-23-2024 at 12:54 PM.. |
matowi742.50 |
05-23-2024, 01:01 PM | #29 |
Rep 691
Drives: '24 X5 M60i
I can add from own experience - last year in late April we had a sudden snowfall and temperatures dropped to 3-5C (mid-30sF if I’m not too off with my mental math)
Snow turned into slush about 2cm (1 inch) deep. My 7 x-drive on summer tires (PZeros 4) was hardly staying in straight line, and took miles to stop from speeds that in 50-60kmh range (~40mph). I can’t remember another time when my palms were so sweaty, and when I’d been so stressed/focused while driving.
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d |
05-23-2024, 01:12 PM | #30 | |
Rep 2,175
Given the fact that there's like 5 sets of tires that fit these cars anyways, and these.cars have giant tires to boot, I'd run all season tires if I thought I would deal with cold. |
05-23-2024, 02:18 PM | #31 | |
Rep 4,287
Take a more street friendly good summer, PS4s, absolute no tread block won't come off at 40F. I have always been using summer in my E39/E46/E82. I drive them daily. E46 being my commuter, it has PS4s currently. My morning temperature can easily be 40F even in March, and mid 30s in winter. Never in my 20+ year usage of summer tire, I ever see tread block come off due to 40F kind of temperature, not to mention 60F. Less grip at 40F than in 60F, sure. Now I have see tread blocks come off even for all reason, but they are all because old/aged tires, which should be replaced to begin with. But it is another story.
2022 G05 B58/PHEV
+ a few very old BMWs |
05-23-2024, 03:22 PM | #32 |
16004
Rep 22,833
While you start to lose grip earlier, you likely won't have any damage until it is freezing or below. I think all of the manufactures warn against using summer tires in the cold both from a safety point of view as well as a chance of damaging the tires.
05-23-2024, 04:56 PM | #33 |
18
Rep 30
It is honestly absurd that more people in the northeast don't move to winter tires in the winter. As many others have pointed out, it isn't so much a function of snow but temperature. Stopping distances and overall grip deteriorate considerably as temperatures drop. Meanwhile, people will spend 10-40k+ extra on various performance specs but they can't put the HP to the ground when the tires don't work. Not to mention the liability they are on the road.
At the very least, it is worth considering some of the high quality all weather options now available. I put a set of Nokian WRG5s on my wife's car and they've been tremendous. Maybe not a performance option given the sidewall flex, but lovely for her. Have been killing all conditions in CT. About to spec out a X5 x40i, and will likely go with the black 22s. Shortly after I will buy a set of Nokian R5s and 20" rims for the winter. Last edited by iceburgh; 05-24-2024 at 07:58 AM.. |
05-23-2024, 06:08 PM | #34 |
Rep 114
Why do you choose to buy 20" wheels and tires if you can just buy another set of 22" all season tires? Unless there is a lot of snow in CT. Here is NY it was snowing for a few days a couple of times but the snow cleaners usually clean up snow over night pretty quickly. I rarely had to drive in a snow.
05-23-2024, 08:33 PM | #35 | |
Rep 114
05-23-2024, 08:51 PM | #36 | |
Rep 2,175
That said, in cold, a summer tires is still not better than a good all season tire. |
05-24-2024, 07:55 AM | #37 | |
18
Rep 30
CGG205.50 |
05-24-2024, 12:33 PM | #38 |
Rep 4,287
I cannot agree to this at all. Even lightest snow/slush accumulation on surface, summer tire will suffer long before the cold start to impact tracking.
2022 G05 B58/PHEV
05-24-2024, 08:42 PM | #39 | |
Rep 114
Maybe a wheel alignment is needed too and those sensors. |
05-25-2024, 05:47 AM | #40 | |
Rep 2,175
I have all season tires on my TBSS and I live in Florida. It's not like AS tires are useless, they just typically have a slightly smaller max grip level, and will get greasy faster if pushed to the limit (like on a race track). I drive my cars hard, and I've never gotten AS tires to feel greasy on the road, even in a 5000lb beast. |
05-25-2024, 10:12 PM | #41 |
Rep 114
These 22 inch tires are like 500 - 700 bucks each to replace (especially if you want to get a 2nd pair of all season 22 inch tires). Does anyone purchase warranty for Rims and Tires or for tires only and how much do people need to expect to pay for tire and rim warranty?
05-25-2024, 10:33 PM | #42 |
Rep 114
By the way I used to lease Ford Edge ST for three years back in 2010. No issues during the winter in NY with 22 inches that was an all season performance tire i think.
22 inches is fine during the winter. I guess you just have to get get decent all season tires. |
05-27-2024, 08:49 PM | #43 |
Rep 280
Knocking on wood here, but in the last 20 months I’ve put 34,000 miles on two different X5s, including ~ 12,500 miles on 21 inch tires - no flats. The rest of the mileage was in 20 inch wheels with either winter or all season run flat tires….
05-31-2024, 04:40 PM | #44 |
Rep 114
My dealer has X5's with 20" wheels and 21" wheels. Dealer keeps telling me that I should get 21" wheels as they look better and it's not like I am living in Adirondack.
Although the majority on this forum seem to think that 20" is the best as there are options. Last edited by MartieNYBK; 05-31-2024 at 05:36 PM.. |
BSfmAZ301.00 |
