2010 2011 BMW 5 Series Forum F10 Anybody else with "Increase Battery Discharge" |
04-03-2013, 08:26 PM | #23 |
Rep 42
This happened all the time on my old 2007 X5. The problem was so bad I lemon lawed the car. The warning of increased battery discharge was merely a symptom of a serious problem with the car's electrical system. Three times over seven months, I would start to get this warning. And each of those times, my car completely shut down on the highway. To say it was scary situation would be a gross understatement! The first time the dealer replaced the battery, the second time they replaced the voltage regulator, and the third time I lemon lawed it.
I wouldn't wish that problem on anyone, so I hope this isn't anything like what you're having....
_____________________________
2013 550i (6-speed, MSport) |
04-03-2013, 11:03 PM | #24 | ||
Rep 2,246
04-04-2013, 01:26 AM | #25 |
Rep 42
Yeah, some people think I was nuts for lemon lawing my X5 and using the money to buy a new F10. Knock on wood, everything's been good with my 550i so far. But if I have similar problems again, I may have to become (God forbid) an Audi owner. ;-)
04-04-2013, 03:48 AM | #26 |
Rep 2,232
Drives: Made in Bavaria
Had it happen once on my F10; after working on my tires and leaving the radio on for the duration of my wheel change out. Next morning the dreaded increase discharge was on the dash. Cleared after a drive to work and then out again for lunch and was kool again with no messages by the time I left for home that evening.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten '15 BMW M3 (Black/Black) - gone not forgotten '10 BMW X5M (Black/Black) - gone not forgotten '08 BMW M3 (Space Gray/Black) - gone not forgotten |
04-04-2013, 08:13 AM | #27 |
Rep 469
Had something similar on an e39 530 diesel. Basically battery would drain completely, alarm would go off and the car would be dead. Even remote central locking would fail (had to use the key).
After a couple of battery changes, etc (all under warrantee) discovered it was the "pre-heater" coming on all by itself (this is the heater that warms the car until the engine is running at the correct temperature - which can be a while in a diesel as they are much more heat efficient then petrol). This may not be the case with your car; but the way we found this out was by putting a meter on the car's battery and taking fuses out methodically to see what then stopped the drain... OK, it's all software nowadays, but it may be a method if nothing else seems to identify the cause? |
04-04-2013, 06:59 PM | #28 |
Rep 604
I've gotten this message after having left the key in the car while washing. I always lock the car and take the key with me when parking in the garage at night and haven't had any issues.
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
04-05-2013, 12:31 AM | #29 |
Rep 2,246
Cannot begin to describe how upset I am.
Shop foreman said I left my parking lights on and the battery won't be covered. I said I always leave my lights on Auto. He said parking lights are activated by the turn signal stalk and showed me how to turn them on. I said I didn't even know about the feature, much less how to activate it, and that the car should cut off anything accidentally left on after a certain amount of time - to prevent battery drain. He said not with the parking lights. Got nowhere with asking for the printout; he said the report is BMW property and confidential!? Service advisor said a new battery would be $700 ($325 + labor for installation and programming)!? Absolute BS. Dishonoring warranty work on a $100k+ car with a mere 22k miles on the clock / 2 hours labor to "program" a battery. Are we in the twilight zone or something? WHAT THE HELL IS WRONG WITH THIS POS COMPANY (AND ITS DEALER NETWORK)? Can't help but think that this is some big joke. Taking this up with the General Manager (Service Manager is useless, as I know corporate to be too). Even if I drop $700 on a new battery, I'm not letting this go. Can't believe it's come to this. Complete disgrace. Total shame. Any advice / insight welcome. By the way, I always take the key and lock the car. Otherwise, does Mercedes or Audi have these battery problems, and if so, how do they handle same? |
04-05-2013, 01:47 AM | #30 |
Rep 541
The parking lights will not shut off after 15 minutes the side that is activated will stay on until the battery goes flat. If that is the case you should be pushing them to recharge the battery and monitor it over the next few weeks. Afterall the battery has only been drained it doesnt require replacement because it went flat.
04-05-2013, 12:12 PM | #31 | |
Rep 855
Try another dealer if its close by
2018 540ix msport
2015 X5 msport 2013 750ix msport 2011 550ix msport 2009 e92 335i msport |
04-05-2013, 02:09 PM | #33 |
Rep 2,246
They stated they charged the battery, but that is isn't charging fully. Good point, however, that the battery shouldn't require replacement simply because it supposedly went flat (I never needed to actually jump the battery, however).
04-05-2013, 02:23 PM | #34 |
Rep 541
No and if they try and fob you off don't let them. The battery fitted to our cars is an AGM battery (Absorbed Glass Matt), Its whats known as a deep cycle battery and is used in applications where they get heavily used a lot both discharging and recharging frequently (such as campers and caravans). They use them on our cars because of the electrical system charging and discharging so frequently with the likes of brake regeneration etc. If it wont hold a full charge then it is clearly faulty.
04-05-2013, 02:41 PM | #35 | |
Rep 2,246
I was told that when it isn't fully charged, sulfur builds up and damages the battery; not sure whether or not true, but even one instance of going flat should not result in not being able to fully charge the battery as you say. |
04-08-2013, 05:58 PM | #36 |
Rep 2,246
Good news: General Manager of dealer states they’re going to goodwill the battery. Crazy I had to take it up with him and crazy they’re “goodwilling” it instead of “warrantying” it, but such is the game corporate plays. Thank you for your support everyone.
Could a software issue have cause this? At one point I noticed a key data report stated there was a new “Software Integration Level” available, but whenever I ask my service advisor he states there are no updates. How do I find out what my car has and what’s available? |
04-10-2013, 10:50 AM | #37 |
Rep 2,246
ALSO, when experiencing the “increased battery discharge” / “charge battery” problem and the car is started with the side view mirrors folded in, there are times the mirrors do not deploy upon driving off or pressing the button on the driver’s door, where it takes 5-10 minutes of driving before they can be deployed. This is EXCEPTIONALLY dangerous and I don’t understand why it happens when other features work (i.e.: windows, seats, instrument cluster, radio, HVAC, heated and cooled seats) even under the “increased battery discharge” / “charge battery” situations. Is there any way to “code” this so power goes to the mirrors upon startup, without needing to drive 5-10 minutes with them folded?
04-10-2013, 07:37 PM | #38 | |
Rep 31
Drives: 2013 535i Individual (12/2012)
2013 535i BMW Individual Moonstone(Mondstein)Metallic with BMW Individual composition•Platinum Ext. Merino leather with Piano Black Trim•Individual wood inlay steering wheel•Ceramic Controls•B & O Sound System•Driver Assist Package•Luxury Seating Package•Technology Package• Premium Package•Dynamic Damping Control•Parking Assistant•Power rear sunshade•Soft-close automatic doors•Automatic high beams•
04-10-2013, 09:33 PM | #39 |
Rep 5
I'm also having problems with my 2011, 535i car battery. I took my car to my local dealership and they told me I needed a new battery because the one I had could no longer hold a charge. I asked if the manufacturer's warranty would cover this and they said no. They said the vehicle computer showed I was not shutting down the vehicle properly. According to my service advisor, turning off the engine in my garage was not sufficient. I needed to set the alarm every time and this would shut off everything. I almost fell off my chair when they told me the price for a new battery was $865. They're blaming me for "being negligent". I believe that since I didn't buy my car from them, they don't want to help me. I called Sears and they have two batteries that will work for my car, a Diehard Gold and an AGM. They are priced at $169 and $179, respectively. The Sears rep said that they can install for $20. Does anybody know if these are good replacement batteries and if they will void my remaining warranty?
Thanks.... |
04-10-2013, 10:01 PM | #40 |
Rep 2,246
AGM batteries are what we have in our cars, problem is, however, that dealers want 2.5 hours of labor to supposedly 'program' replacements, stating we can't simply disconnect an old battery and connect a new one…
04-11-2013, 12:57 AM | #41 | |
Rep 541
I don't understand why they are selling you guys new batteries and not just charging them up. As for not locking the car there may be some truth in that but I would expect that if not locked the car would still shut down properly but just take longer to realise its been left (its about 15minutes to shut down after the car is locked). |
04-11-2013, 08:43 AM | #42 | |
Rep 8,835
My parking brake works fine and I always use it when i park the car but I tried NOT using it for the past week and I did not get the increase battery drain warning. I normally get the warning every week since i don't drive the car M-F. I will keep testing this out by not using my parking brake at all to see if thats the culprit to my issue. Alan
04-11-2013, 10:38 AM | #43 |
359
Rep 365
I had Chase (itschase) program my daughter's car after installing a new battery. It took him 5 minutes and that included plugging in the computer.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
