Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Official 335D 1/4mi thread
      07-31-2016, 11:42 PM   #23
32valves
32valves's Avatar
109
Drives: 2011 335d sport
M4 vs my black D
      09-03-2016, 07:41 AM   #24
32valves
32valves's Avatar
109
new times
new times from last night, but only two runs people kept leaking on the track.
      09-18-2016, 06:46 PM   #25
32valves
32valves's Avatar
109
new best
today at mdir
      09-18-2016, 07:41 PM   #26
ASBSECU E93
Know's a guy that know's a guy...
ASBSECU E93's Avatar
5639
Drives: 2010 335d; 2008 135i
Would be beneficial to post wheel/tire set up as well.
Who's running drag radials?
And what wheel size?
Originally Posted by Lups View Post
She stood there. Pointed a finger at me and laughed at me. That damn bitch.
Poop shit, shit and poop. I'm mildly angry now.
      09-18-2016, 08:49 PM   #27
335dsleeper
389
Drives: 09' 335d 10'35D
Originally Posted by 32valves View Post
today at mdir
60ft times are getting better.
      09-19-2016, 03:09 AM   #28
32valves
32valves's Avatar
109
today at mdir
I ran 18psi on those nitto drag radials.
But yeah the car is running damn good.
You see the red arrows on the time slip, when I got my time slip, they made me pull over and shut the engine off. Because my car had excessive smoke but then I told them it was diesel. And they were amazed and also dumb founded that my car wasn't smoking due to mechanical failure...
      09-19-2016, 11:45 AM   #29
mefferso
Drives: 2010 335d
today at mdir
Just curious, what was in the other lane on this run? Looks like y'all were side by side at 60' but you steadily pulled on him from then on.
      09-19-2016, 11:55 AM   #30
32valves
32valves's Avatar
109
today at mdir
a civic coupe gutted out, all motor with huge slicks.
      09-19-2016, 11:57 AM   #31
kydiesel35
kydiesel35's Avatar
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
today at mdir
Good job!
      09-19-2016, 12:00 PM   #32
32valves
32valves's Avatar
109
he thought I was joking when I said it was diesel too. lol
      09-19-2016, 03:00 PM   #33
335dsleeper
389
Prob good to mention track prep... You're not getting a 1.7 in a 335d on Nittos without a GREAT track!
18psi each pass? Results at 18psi at 10pm is vastly different 18psi at noon. Track temps and tire pressures go hand in hand as well as track prep.
With stock turbos you're getting in the "half-shaft failure" territory, might be wise to bring a couple extra along with tools from here on out. You've got some track time on them now. Don't be alarmed if you break one soon. Mine failed at the outside cage. I left as hard as I felt it could, and it exploded. Ha
Interesting you lost so much MPH with only a slight drop in the 60ft time. 106mph is pretty slow considering your mods. Did you check for boost leaks? Was your meth spraying? Did you log any of the runs? Just seems like an odd drop.
      09-19-2016, 04:49 PM   #34
32valves
32valves's Avatar
109
I got one spare shaft, as for logging I have no electronics to log I don't even know what you guys are using to log.
As for the mph you are right low as hell.
I guess I gotta check my car over...
      09-19-2016, 05:13 PM   #35
335dsleeper
389
I would just confirm the WI was spraying as I ran 107mph without meth and similar mods. Might just been empty or fuse or something dumb. Or boost leaks. just ensure everything is as it should. I'm sure it's something dumb.
      09-19-2016, 05:19 PM   #36
32valves
32valves's Avatar
109
meth was spraying cause I topped it off as for boost leaks I gotta check that.
by the way what's your best e.t.
      09-19-2016, 05:28 PM   #37
335dsleeper
389
12.2 with a 1.8x 60ft. The 1.68 60ft would've been low 12 or very high 11, but that run I decided to turn meth off to see what she'd do on fuel alone. UGH
      09-19-2016, 06:48 PM   #38
32valves
32valves's Avatar
109
gotcha, I will do the same, I guess we will see who hits high 11's first... lol
      09-19-2016, 07:10 PM   #39
RollingCoal
Drives: 2011 BMW 335D
What's both your meth ratio? Spray start-max settings, nozzle sizes, etc.?
      09-19-2016, 07:33 PM   #40
335dsleeper
389
I'm not in competition. I'll be unavailable for most of this year. Maybe next year I'll play. Until then, good luck.
      09-19-2016, 07:37 PM   #41
32valves
32valves's Avatar
109
thanks buddy, I will try my best...
      09-20-2016, 09:03 AM   #42
TDIwyse
Drives: 2011 335d
Originally Posted by 335dsleeper View Post
...Don't be alarmed if you break one soon. Mine failed at the outside cage. I left as hard as I felt it could, and it exploded. Ha
335dsleeper, what's a good price on these? Looks like the left and right ones are different part numbers, and new ones seem to run in the $4-500 range.
It looks like the process for changing them is fairly straight forward. Not sure, since I haven't had the "opportunity" yet to learn that procedure (I can't seem to hook good enough to stress them anyway).
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      09-20-2016, 10:08 AM   #43
Hoooper
Drives: 335D
You mean second right, since its already been done a couple times by TDI?
      09-20-2016, 10:09 AM   #44
32valves
32valves's Avatar
109
You mean second right, since its already been done a couple times by TDIwyse?
I meant between 335dsleeper and myself...
