11-15-2023, 08:59 PM | #24 |
Rep 3,757
What is the recorded Edrive miles? It says 6.9kWh is consumed. Should be responsible for some Edrive miles, right?
2022 G05 B58/PHEV
+ a few very old BMWs |
11-15-2023, 09:24 PM | #26 |
Rep 33
11-15-2023, 09:26 PM | #27 | |
Rep 33
11-15-2023, 09:27 PM | #28 |
Rep 33
11-15-2023, 09:49 PM | #29 |
13718
Rep 20,397
When you engage Battery Hold it will keep the charge at the percentage it is. For example, if you engage it when then charge is 30% then it will keep the batteries charged at 30%.
Preconditioning is the ability to heat/cool the vehicle prior to you using it. For a regular ICE vehicle this is done by remote start but for the PHEV the engine is not used but rather the battery. That is why it is always good to keep some charge in case you want to heat or cool the vehicle prior to you using it.
11-15-2023, 09:58 PM | #30 |
Rep 3,757
45e maybe 14-15 on flat. But if you are down hill, ICE off miles get counted toward Edrive miles, it is hard to say, can be a lot more.
2022 G05 B58/PHEV
11-15-2023, 10:05 PM | #31 |
Rep 6,946
Preconditioning may be more of a major benefit in the winter if the vehicle was parked outside. IF there was snow or ice on it, the heating would allow you to clear it off much faster and easier. Same with remote start. If your battery is too low to perform that, you'd have to drive it enough with the ICE to build up some charge to get the heat on full, similar to an ICE on a cold start. It's much more comfortable to get it warmed up (or cooled off in the summer) prior to getting in it. And, ideally, you're plugged in when that happens so you don't lose EV range. Note, preconditioning on the PHEV lasts longer than remote start (about 30-minutes versus 15 on the ICE), giving you a bigger lead on clearing snow or ice. An ICE engine doesn't warm up that fast when no under load, as it would be idling. Also, you can precondition the PHEV in a closed garage without CO issues as the engine doesn't run. If you request preconditioning and the battery is too low, essentially, nothing will happen, it won't fall back and start the ICE until you get it in and hit the start button.
Regardless of the battery charge, the PHEV will always act like a hybrid, and make the best use of whatever battery capacity it is allowed to use, helping. You just may not be able to drive very far on the batteries before it activates the ICE, but will give you a boost from a stop or during acceleration. Just maybe not for long. Roads are rarely totally flat, and you're almost always going to see a little bit of speed change, so there will be some opportunity for regeneration to occur...Go down the back side of a mountain, you might fully recharge it! |
11-15-2023, 11:02 PM | #33 | |
Rep 3,757
The car can use edrive motor to help ice in very specific situations, like large throttle input. As far as I can tell, the condition is rare. Most of the time if ice is running edrive won't engage. You can record the energy flow diagram by phone or GoPro, and review it later.
2022 G05 B58/PHEV
11-15-2023, 11:49 PM | #34 |
Rep 296
How fast does it charge on level 2? Thought it was a couple of hrs? That doesn’t sound appealing.
From 0% to 100% approx. 3 hours, 15 minutes. However you don't have to charge it full. One of our Target's around a shopping center allows 2 hours free charging. So it is convenient if you have to go shopping in the area anyway. |
eluded3071.50 |
11-16-2023, 04:20 PM | #35 |
Rep 6,946
You'd have to know your typical trip length to understand how long it will take to fully charge the vehicle...for example, a typical day for me might only use half of the charge, so the time to reach full would differ considerably from someone that needed to recharge an empty one.
Power=volts*amps. So, knowing the inlet voltage and how big your EVSE is along with the maximum the X5 can accept with the size of the battery, you can get a decent rough approximation. As a rough approximation, allow about 10% loss to the ACV-DCV conversion and cooling loads. BMW purposely chose not to support DC fast charging on the X5. Maybe the next one, and almost certainly on any upcoming BEV versions. But, the speed of that also can vary based on the unit you plug into, and the maximum the device can handle. A DC fast charger could be as small as a 25Kw device, or (the largest I've seen) is a 350Kw device...not very many vehicles can handle a 350Kw input, and would be drawing much less from it. SS batteries are coming, and those appear to be able to accept a large charge quite fast. None are available just yet, but some appear to be going to show up next year, but BMW hasn't announced any that I'm aware of. In the summer, when everything has to contend with heat, the cooling load will decrease what makes it into the batteries, so things will be at least a little slower and, as you reach the upper charge levels, things slow down (at least for current battery tech...SS ones may not need that slowdown to prevent damage). |
11-16-2023, 07:22 PM | #36 | |
184
Rep 337
11-16-2023, 07:42 PM | #37 | |
Rep 210
Only way to bring 10% of battery level(for precondition or etc) from below 10% is using BH or Sport mode. Using Hybrid mode will not do anything but just going back at forth 0% to 3%.(0-1miles elec range). This thread is for the people who can not charge at home not for people who can charge it. So it does not mattery BH hurts fuel efficiency. Battery should be charged to certain level for preconditioning. Also it feels like acceleration is slower when battery is depleted VS when it is charged 10%. So I think to utilize full acceleration potential, it is better to be charged all the time at least 10%. Also if somebody can not charge, what is difference between maintaining battery level at 10% all the time or 0% all the time in terms of fuel efficiency? |
11-16-2023, 07:59 PM | #38 | |
Rep 8,887
Drives: eVeRyOnE mAD!
are you doing that deactivate BH > regenerate higher charge level > activate BH cycling thing? |
11-16-2023, 08:25 PM | #39 | |
Rep 210
1. Hold battery level as is when Battery charge level is above 10% 2. Charge battery to 10% when Battery charge level is under 10% Recycling BH button is only used to charge is more than 10%. I guess even though BMW took away Battery condition function for political reason(https://cleantechnica.com/2022/07/05...rid-emissions/), they still need to give opportunity to recharge battery for preconditioning for certain scenarios that driver can not charge it from the plug. So they let BH to charge up to 10% just for that case. I think 50e is better vehicle than 45e but 45e is more complete vehicle for having Battery Condition function. 50e is crippled since it lost one essential function due to political reason not because of technical limitation |
11-16-2023, 08:27 PM | #40 |
Rep 418
If I were in the OP's shoes I'd just get the thing fully charged, then drive around in sport mode all the time. If the battery eventually runs down, figure out a way to get it charged and repeat the cycle. I've only done this for a tank at a time - roughly 400 miles - but the battery stayed at 100%, and those tanks were the highest mileage tanks we've seen, if that matters.
We have a 45e, though, and I suppose the 50e could behave differently. It still doesn't have Battery Control, right? That's too bad for the OP, as it's the quickest way to recharge the battery if it does run down. Mark |
11-16-2023, 08:30 PM | #41 |
Rep 3,757
I think all of these extras maneuver for 50e for those cannot charge consistently, get old very fast. The need to go some where out of your way to chsnge for even half hour consistently is very painful. Think a long gas station stop. We used to have model S and without home charging capability. Super charging 2x a week on average. Charge time is about 30 min. Going there and coming home, together it is 1 hour. It was ok for the first couple of week, but it really gets annoying after a while.
Doing BH in sport all the time will for sure degrade mpg compare to hybrid. This basically is a 40i with extra weight because ice is on all the time.
2022 G05 B58/PHEV
tooloud10796.50 |
11-16-2023, 08:31 PM | #42 |
Rep 8,887
there are definite improvements with the 50e, but I would hate to lose the Battery Control function. I just used it last weekend on a road trip from VA to PA and back. I set it to 50% and drove in this mode for both legs and still logged 27mpg
11-16-2023, 09:04 PM | #43 | |
Rep 418
Mark |
11-16-2023, 09:16 PM | #44 |
Rep 3,757
But that is highway right? How about For stop and go or mix usage?
2022 G05 B58/PHEV
