Billet front diff housing with stronger gears
08-28-2016, 02:15 PM | #23 |
Rep 91
Seems like there are guys drag racing high horsepower xi's who beat the snot out of them have failures. When your in the low 11's maybe high 10's day in and out, there are going to be some broken front diffs. It sounds like there are random failures as well but doesn't seem like a lot.
If you look on the xi forum, the documented failures seem to gear related. The fact that the fluid capacity is small doesn't help. What would be really cool is an LSD solution for the xi front diff but that's probably too much to hope for… M factory group buy ? |
08-28-2016, 08:43 PM | #24 | |
Rep 1,340
08-29-2016, 12:48 AM | #25 |
Rep 75
Interested
RIP10' A/W M-Sport-JB4-E85/93,50/50-BMS DCI-AR DP'S-Balck Kidney Grills-muffler delete-mm6 mesh18x8.5/9.5-Conti DWS 235/40 18, 265/35 18.
10'e90 a/w SportPackage-mhd e40 map- a/r dp's-vrsf charge pipe and tial blow off valve 95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, 2000 lbs. |
08-29-2016, 11:33 PM | #27 | |
Rep 91
MFactory, what kind of unit do you propose to supply ? Interested. As mentioned, would love a front LSD for the xi. Possible if not cost prohibitive ? |
08-30-2016, 07:16 AM | #30 | |
Rep 56
If you are wanting to design and build the entire front diff, then I wouldn't need to go any further on mine haha. If you wanted to work together I could do that too! |
08-30-2016, 09:35 AM | #31 |
Rep 91
I believe what Mfactory is talking about is fitting a helical gear setup into the existing pumpkin, I cannot comment on it being stronger than the existing open setup but I imagine it could be depending on how much money is spent.
08-30-2016, 10:22 AM | #32 |
Rep 1,421
Yes, replacement Diff only (not the carrier, nor the Ring & Pinion).
It will definitely be stronger than the oem Diff (whether that matters or not), but what will definitely be of benefit is the increased traction. |
08-30-2016, 11:22 AM | #33 |
Rep 91
Someone correct me if I'm wrong but the failures seem to be ring gear related ? If so, some kind of treatment of the ring gear to strengthen it would would potentially be beneficial ?
Apologies if I am threadjacking. |
08-30-2016, 01:22 PM | #34 |
Rep 56
I think there's a lot of problems with the factory front pumpkin.. the carrier looks weak, the housing is split in an odd spot with nothing constraining the shear load other than friction, the spider gears look weak, the ring and pinion are relatively small, and the ball bearings seam to have more backlash than necessary. As the pinion gear starts to push load into the ring, it looks like it would be able to climb into a slight misalignment. Also not a lot of fluid volume.
05-26-2017, 09:38 AM | #36 |
Rep 246
F Diff
I hope this can be made at a reasonable price point to hold 750-800 lbs. of torque. People are going to be building blocks very soon and this will be right in the wheel house as a necessity. I appreciate the efforts to date and look forward to see more.
05-27-2017, 02:03 AM | #38 |
Rep 154
I'm kinda saddened that it's been almost a year since this thread started and no success, prototype, our anything. I would be willing to pay 3k for a strong front diff with a LSD. An Xi that can have 2 LSDs and can actually be lauched would be amazing.
05-29-2017, 02:28 PM | #42 |
Rep 1,415
05-29-2017, 10:12 PM | #43 |
Rep 223
05-30-2017, 05:08 AM | #44 |
Rep 2,139
Drives: 2009 e92 335i MSport DCT
Here's what they look like
http://www.ebay.co.uk/itm/BMW-X5M-E7...-/182012076412
When you doppelkaplung you doppel your fun.
