03-23-2023, 01:17 PM | #23 | |
B58 Power
498
Rep 633
Drives: 05/2022 M340i xDrive Touring
Thank you for you help Wet Fish!
I pointed him in the right direction for the error on HU_MGU. So far i could compare his DKOMBI4 coding to mine there are many different values... I highlighted some values that could do the trick and iīll check the values one by one tomorrow. Maybe PSdZData contains some more information and i can clear some values that are clearly not related to the shift lights. Quote:
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
hayko_M340140.50 Marco115912.00 |
03-24-2023, 02:44 AM | #24 | |
Rep 241
MichaelNRW498.00 |
03-24-2023, 02:46 AM | #25 | |
Rep 241
MichaelNRW498.00 |
03-24-2023, 04:59 AM | #26 |
B58 Power
498
Rep 633
Give me some time to test these values ;-)
I need to make a quick ride around the block to see the results.
03-28-2023, 12:09 PM | #27 | |
Rep 193
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe |
MichaelNRW498.00 hayko_M340140.50 |
03-29-2023, 03:52 AM | #28 | |
B58 Power
498
Rep 633
Hereīs the second compare between the HU_MGU coding.
Thereīs a lot of "M_" values active. Wet Fish was your HU_MGU flashed with M software? So do you have orange or red markers on the menu items? Quote:
03-29-2023, 03:54 AM | #29 | |
Rep 193
But, in answer to your question about orange or red. I noticed mine are now red. They were orange before he did all his coding stuff.
03-29-2023, 04:22 AM | #30 | |
B58 Power
498
Rep 633
What car is shown in your Headunit and Kombi, your car or a M3/M4? Do you remember if there was a window with "TAL processing"? You need to choose some files that were created before. Then theres a big table with all ECUs with multiple rows that can be enabled or disabled. e.g. blFlash, swDeploy, cdDeploy, ibaDeploy
03-29-2023, 04:36 AM | #31 | |
Rep 193
I dont remember much TBH. He wasnt communicative whilst he was doing stuff, and I was mostly bricking it because it looked like it could mess something up. I vaguely recall him saying the flash was complete. Looking at the stuff he asked me to install on my laptop, it includes E-sys and KCAN-PRO but that was it. As for the choosing files, Im really not clear on how you want me to do that. Is that something in E-sys? Again, Im more than happy to help you guys out, but Ill need instructions as I have no idea what Im doing with E-sys.
03-29-2023, 04:40 AM | #32 | |
Rep 193
03-29-2023, 04:44 AM | #33 |
Rep 193
Found out how to unlock it. Theres also a Mapping.exe in there and then a copy of the other stuff I mentioned.
03-29-2023, 04:50 AM | #34 | ||
B58 Power
498
Rep 633
Thatīs just part of flashing an ECU and when you recall him saying something around "flash complete" itīs a hint in this direction. Quote:
Have you check the recycle bin for the files from that zip file? Judging by the size itīs a archive for E-Sys, PSdZData and some more.
03-29-2023, 04:52 AM | #35 |
Rep 193
It was. It had two e-sys versions, the psd data, and a few other files. Ive PMd you
03-29-2023, 05:07 AM | #36 |
Rep 7
To have the M Menu in the MGU, there is basically only one difference in the SWFKs.
For example: SWFK_000056AA = HMI BMW SWFK_000056AE = HMI M If HMI_M SWFK is flashed, you need to change in CAFD 3E52, HMI_BRAND to BMW_M. Otherwise it won't boot the HU. BR |
MichaelNRW498.00 |
03-29-2023, 05:12 AM | #37 |
Rep 7
03-29-2023, 06:15 AM | #38 | |
B58 Power
498
Rep 633
The file doesnīt contain anything interesting other than a Mapping.exe file that gets flagged as a trojan.
03-29-2023, 06:27 AM | #40 |
B58 Power
498
Rep 633
No i didnīt had time to test the values and then drive to see the shift lights.
I would like to change a minimum of values for this.
03-29-2023, 11:44 AM | #41 |
B58 Power
498
Rep 633
I did some tests today and i wasnīt 100% successful.
I only used some of the parameters from the comparison. One thing i could achieve are the shift lights in HUD. My car didnīt had them from factory and now iīve got the normal shift lights in the top of my HUD. Now what i didnīt achieved are the shift lights in the Kombi. Neither the ones on the left/right or the G80 ones in the top area. I found some information about this and that the shift lights are either shown in the HUD OR the Kombi, but not both. Iīll try to disable the sports view in HUD and try it again. See attached image. The G80 shift lights will only work with M software on the HU_MGU. Iīm not sure about every downside so i wont try that for now. Another warning, i got a CEL after coding some of the values. It was a warning that the DME and DKOMBI4 couldnīt communicate. The CEL was gone after a restart and i could clear the DTCs. Just that youīre aware about this!
03-29-2023, 02:37 PM | #42 |
Rep 7
Its not a problem to use M Style on MGU. I can help you with that, also to revert back to original.
hayko_M340140.50 |
03-29-2023, 08:50 PM | #43 |
Rep 12
Hi I started this thread a while ago but i gave up.. Now i got back on the thread and saw so many ppl trying to figure it out...
Any succes with bimmercode? Thx <3 |
03-30-2023, 02:45 AM | #44 |
B58 Power
498
Rep 633
I didnīt code with Bimmercode but it should be no problem to code the two values mentioned above with Bimmercode in expert mode.
Code:
CB_SHIFTLIGHTS => aktiv HMI_SHIFTLIGHTS_HUD_ENABLE => aktiv HMI_SHIFTLIGHTS_KOMBI_ENABLE => aktiv PIA_SHIFTLIGHTS => aktiv G80 shift lights are not codeable with Bimmercode.
