06-13-2018, 07:15 PM | #23 | |
4672
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
hooligan_G016431.50 Dang3r12516.00 |
06-14-2018, 01:20 AM | #25 |
Rep 775
Patek models from about 10 years ago were generally about +/-4 seconds a day. The new Rolex models are -1 for the 2018 Hulk, -0.25 for the 2017 SS SkyD blue, and think the 2016 Sub is like +1 seconds a day. Crazy accurate, though note when i wear a model it is worn 24/7. Seems to me they keep better time when left on the wrist all the time. At least it is in my experience. Hope this data helps.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
06-14-2018, 01:40 AM | #26 |
338
Rep 359
I think it's a balancing act. I think they adjust the movement so that it accounts for a person wearing the watch a certain number of hours per day. If worn more or less or with frequent jolts, the timing can be off. I also manually wind mine depending on how much/little wrist time they get. I generally wear my sub-c 15 hours a day and lay it flat in a watch case for the remaining 9 and it works great for me with my current piece.
06-14-2018, 08:17 AM | #27 |
Rep 2,524
you need to remember that its also an average when fully wound across multiple positions (Face up/down, crown up/down, etc.) so depending on how you wear it, how often you wind it, how often you move to let the automatic works wind it, how you store it, your timekeeping will vary.
you could be 0 s/d in one position, and +5 or -5 s/d in another. If your watch isnt COSC certified, you can be even further out across positions. |
06-14-2018, 02:28 PM | #28 | |
Space Shuttle Door Gunner
6432
Rep 5,312
I'm willing to bet your experience with IWC and AP are not the norm compared to most when it comes to accuracy. Just because a watch isn't COSC certified doesn't mean it isn't capable of being that accurate (or even more accurate), it simply means it wasn't tested by COSC. Most of the top tier watch marques don't bother with COSC certification, actually. |
06-14-2018, 02:37 PM | #29 |
2932
Rep 415
Drives: 2019 440i Coupe
This is correct, and if I'm not mistaken, only "Swiss Made" movements can even be submitted for COSC certification.
TheWatchGuy3904.50 |
06-15-2018, 08:02 AM | #31 |
Rep 2,882
My Seiko 007 runs about 15-20 sec off per day, so not bad compared to these.
And is it just me or are some computers pretty far off of any accurate time standard? Not unusual for me to notice somebody's handheld or workplace computer time is off by a minute or more from my watch, but later when I check I'm still fairly accurate (certainly not off that far). update: NO, checked my records and actually only lost about 6sec/day, DK what I was thinking Last edited by Maynard; 06-17-2018 at 12:08 PM.. Reason: accuracy |
06-16-2018, 11:52 PM | #33 | |
11818
Rep 23,187
06-17-2018, 09:56 AM | #34 | |
Rep 960
The movement is good, just not pretty |
06-17-2018, 12:12 PM | #36 |
Rep 2,882
You got me wondering so I dug out my notes, and you are right - it did not lose this much. Actually only lost about 6sec/day, so a fail for my memory rather than the watch. It is a Japanese model.
06-17-2018, 11:52 PM | #37 |
Lofty
3462
Rep 849
My Panerai is pretty good and i daily that. Tag Carrera is kinda crap tbh; nice looking watch but that movement is so bleh. Maybe it's my usage; but the movement is really tightening up and losing its time. Gets off by w couple minutes after a few days.
F30 335 (FBO and BM3 OG)
991.2 C2 Range Rover Sport Diesel I4 M50 (coming soon) |
06-18-2018, 08:01 AM | #38 | |
#buildnotbought
11136
Rep 4,934
Not only the position your arm is in. A lot of people here seem to think that COSC is an accuracy for timekeeping. That is only true if you dont move the watch. How the watch behaves under movement (something you cant prevent when you wear it) is a whole other matter. If you regulate a watch with a timegrapher you can see that it can sometimes take 30 sec. or so before the watch is in a resting state that the timekeeping is constant again. So how you use the watch also determines how accurate it is. If your useprofile is accurate you can regulate a watch to your specific behaviour.
06-19-2018, 12:12 AM | #39 |
Quadrex
1094
Rep 1,424
Drives: W212 Mercedes=Benz E Class
For a strange reason I can't edit my earlier post in this thread . What I would like to add is that Zenith's El Primero movement is also as accurate as Rolex's movements that meet new Rolex standards
06-19-2018, 09:41 AM | #40 | |
Rep 2,524
i can shake up a rolex 3135 and put directly onto my timegrapher and its at 0-1s/d right off the bat. now some of the older movements, cant do that cause there is enough play in the jewels/gears that it takes a bit for them to balance out. |
06-19-2018, 08:48 PM | #41 |
Rep 3,739
Drives: 2016 M4 DCT Tanzanite/Amaro
this 806 is getting near 60 years old. while I haven't made any effort to check it for +/- sec/day it's never been more than one minute off in all the time I've owned it.
07-09-2018, 12:18 PM | #42 |
Rep 1
My Rolex keeps +/- 2 seconds, which i think is pretty good for a 15 yeard old watch.. of course it's not keeping any time at all right now since it's in the shop for repair.
07-09-2018, 08:40 PM | #43 |
91
Rep 336
I never kept track, but only time I would notice watch was off is if I didn't last it flat overnight. I'd have to adjust time every other month due to not being quick set.
That was on my 1967 Datejust, which took a hit on the crown and is now only accurate 2 times a month... Matt |
07-10-2018, 01:20 AM | #44 |
Discharged
140
Rep 160
Lots of good posts, thank you. I can only wear wood battery watches bc I kill the battery in metal watches within two weeks to a month for some reason. My wife started the wood ones after talking to a local jeweler. I have a few high end metal watches that are just about useless, but the mechanicals I’ve never considered. Will need to dig into this.
