      10-27-2018, 07:41 AM   #23
Zirenz2006
Zirenz2006's Avatar
1838
Drives: G80 M3 Comp Xdrive
I will be doing this today. Just coded off the volume pop-up yesterday.
Where is this located in Bimmercode? I'm not seeing it.
Current: 2026 ///M3 Comp xDrive IOMG
Past: 2024 ///M2 | 2021 ///M3 Comp | 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
      10-30-2018, 12:16 AM   #24
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
You are doing this on a G05 or G01?
      10-30-2018, 12:23 AM   #25
Almaretto
Almaretto's Avatar
Originally Posted by hcastudillo View Post
I contacted Bimmercode back in the end of July when I placed my order for the X5 and the reply was that the ECU is shared by other G series vehicles. So any G series vehicle will be supported right from the start and more features will become available as they start working with that specific model.
I checked ECU's for G05 and there were all new ones. Attached PDF highlighting unmapped CAFD's for G-series.
I guess we will find out when someone tests Bimmercode on a G05.
File Type: pdf BMW_CAFD_ID's_v4.13.31_Highlighted Unknown.pdf (136.9 KB, 1636 views)
      10-30-2018, 04:16 AM   #26
bavaria22
bavaria22's Avatar
Germany
57
Drives: BMW X3
Originally Posted by Jrunr View Post
Question... If I do something like Race Chip, can I still code my G05 to do the other things that i want, or will the RC negate that?
As far as I know RC only affects motor management. It has no "interface" to all the other control boxes inside the vehicle.
      10-31-2018, 11:49 PM   #27
hcastudillo
hcastudillo's Avatar
Drives: 2019 X5 xDrive40i M-Sport 3rd
Yea...all I can go off of is what Bimmercode wrote me. So we'll see.
      11-01-2018, 12:16 AM   #28
r33_RGSport
r33_RGSport's Avatar
14693
Drives: X7 M60, G05 X5 40, 991.2 GT3RS
RaceChip is a tuning chip to increase engine horsepower. It doesn't and will not limit you from coding thr car.
If anyone local to me and willing to let me play with it for a day or two, I'll code the car for free and maybe other things too.
M Sport model in Alpine White is preferred.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEAL!!
AST • iSweep • RaceChip • PowerFLEX • Akrapovic • Vossen • Eventuri • HRE
KW • H&R • Ohlins • Remus • CSF • SPL • SST and more...
Accepting - Visa, MasterCard, American Express, Discover, Paypal, Venmo, Cash App, Amazon Pay, Affirm.
      11-03-2018, 08:48 AM   #29
ressayflex
Drives: 2011 335i Convertible
Originally Posted by SCA View Post
Per the developer BimmerCode can.
Impressive considering they are not on the road. Wonder how developer tested.
Website also says software can code HUD turnsignals, which cannot be done on Digital clusters.
I just tried bimmerCode on my G05, no luck, none of the ECUs are recognized. Having said that, my car just came back from the dealer after the software update they had to do.
I wonder if BimmerCode needs to update their app
      11-03-2018, 10:32 AM   #30
SCA
SCA's Avatar
Drives: Multiple BMWs / Porsches
Contact the developer.
Also click on settings at the bottom right and see if coding is unlocked at the top.
      11-03-2018, 05:05 PM   #31
Almaretto
Almaretto's Avatar
Sounds like what I predicted.
Bimmercode will need to update their app to support new ECU's.
      11-03-2018, 07:39 PM   #32
ressayflex
Yea I know my set up is working cause I coded my friends 2018 X1 the same day.
With my G05 it scans all the ECUs and goes to the selection page just fine. Its just that only one ECU comes up as green, and then when you click it none of the options show up. All the other modules say ECU not supported.
      11-03-2018, 07:45 PM   #33
Almaretto
Almaretto's Avatar
Which one comes up Green?
Does list of not supported show actual ECU's? Do you have screen shots?
      11-04-2018, 09:11 AM   #34
ressayflex
Here you go:
[IMG][/IMG]
Almaretto2432.50
      11-05-2018, 01:58 AM   #35
Almaretto
Almaretto's Avatar
Here you go:
Did DME work on the G01?
      11-05-2018, 04:58 AM   #36
1230vani
1230vani's Avatar
804
Drives: G05 40i LCI
Originally Posted by ScottMZ3 View Post
Their website provides a few OBD2 adapter options that will work with the app: http://bimmercodeapp.com/adapter/
Hello,
First of all thanks for the link!!!!!
If one buys KIWI of amazon.co.uk, to charge it will it be possible on German electricity socket. Perhaps someone know here what I mean ?
Cheers!
      11-12-2018, 05:03 PM   #37
jbx5
Drives: 2016 X5 XDrive35i M-Sport
Sorry to dredge back up a kind of old thread, but has anybody been able to successfully code beyond what can be controlled in iDrive on G05 using this app?
I just want to know before I pull the trigger on purchasing the app. I already have the cable and a Veepeak OBDCheck BLE adapter.
THANKS!
      11-12-2018, 05:15 PM   #38
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
May want to check Carly it is the other coding app that works from mobile, not sure if it really can support a G05 either, I use it on my F15 and E93, it has the G05 in the listing, you can get the free version and see if it will tell you what will work or not.
The other choice will probably be to use e-sys with updated daten files that support the G05 but will take some time for people to sort through all the modules and see what can and can't be coded - that is what I had to do with my 14 X3 when it first came out, nothing was figured out, so slogged through e-sys and figured out a few things I needed (like close the hatch from the remote).
2025 X5 Msport
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      11-12-2018, 05:24 PM   #39
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
THANKS!
Can't even code the G05 with E-SYS yet. I noticed a couple new ecu's , a lot of trimmed files and a lot of renaming codes so the cheat codes no longer work. I highly doubt this app will work right now on the G05.
It's good to be bad
      11-12-2018, 06:42 PM   #40
roadkillrob
The apps will probably take a while to get updated to work I would suspect also. Esys will work with latest daten files as dealer needs to obviously work on the cars, so November Daten should be good, as long as your psdzdata file version is >= Ista version use to program the car then you have what you need, cheat codes are not going to be available until people get connected to the cars and go through all the ECU options. Happy to start building out the cheat sheet as soon as I have my car, I will connect and start translating modules and others will do the same, but it will take a few months for everyone to get options figured out and tested.
2025 X5 Msport
2008 E93 335i FBO
      11-12-2018, 06:46 PM   #41
skalberti
skalberti's Avatar
Already working on that. I have the latest psdzdata and can connect to the car and read the ECU's. Problem is all the trimmed files.
It's good to be bad
      11-12-2018, 09:11 PM   #42
roadkillrob
Good luck can’t wait to take a look once mine arrives!
2025 X5 Msport
2008 E93 335i FBO
      11-12-2018, 10:16 PM   #43
Almaretto
Almaretto's Avatar
You can use E-sys to generate file set before car arrives. Not very exiting with trimmed files.
      11-13-2018, 12:44 AM   #44
Jrunr
Germany
200
Drives: 2019 BMW X5 M40i - G05
I am wondering, and I know this is a long shot, if I can get the German dealership out here to re-code so things that aren’t in the US version of the G05. (Like the anti-dazzle laser lights, etc...)
