11-08-2018, 01:53 PM | #24 | ||
Rep 97
000 for them. I know it's the looks...call me shallow. If I won't get a setup below 22" with that staggered setup I see myself giving the green light on them. |
1230vani660.00 |
11-08-2018, 06:28 PM | #25 | ||
Rep 442
Any idea what the offset is on the 20" 509s? |
11-09-2018, 01:42 AM | #26 |
Rep 125
I was quoted the same and passed on that! Pick mine up from the dealer tomorrow with 22's... Hopefully it doesn't snow any more in Calgary until i can figure out a 20" winter setup!
11-09-2018, 04:12 AM | #27 | |
Rep 237
I am not sure you can get real winter tires in a 22 inch, 315 wide setup. same goes for snow chains |
11-09-2018, 06:35 AM | #28 |
Rep 97
Pirelli (Scorpion Ice & Snow) 275/35/22 front and 315/30/22 back. Would not put chains on them for sure...
11-09-2018, 06:52 AM | #29 |
Rep 237
no chains would be a deal breaker for me as in some regions in Austria they are required by law.... Guess I am going with the square Setup, maybe putting on some wheel spacers to make up for the difference between 275 and 315 (40 mm per side)
1230vani660.00 |
11-09-2018, 10:02 PM | #30 |
Rep 2,516
Just ordered a winter package from Tire Rack to compliment my 22" setup. MSW Type 48, black w/ machined face, 20x8.5", mounting Bridgestone Blizzak 275/45r20 square. $2181.24 delivered.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
11-10-2018, 01:15 AM | #31 |
Rep 602
I thought the factory wheels were 20x9. Does the 8.5 make a difference? Also, what was the offset? Thanks!!!
11-10-2018, 04:17 AM | #32 | |
Rep 116
Thanks for this info. Will be needing a winter setup and this looks great. My question is that I’ve read the bolt pattern on G05 is changed. Did you confirm these wheels will work? |
11-10-2018, 05:38 AM | #33 | ||
Rep 2,516
11-10-2018, 05:45 AM | #34 | |
Rep 2,516
11-11-2018, 06:04 AM | #36 | |
Rep 116
11-11-2018, 09:23 AM | #38 |
Member
904
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
It's for this reason I did an aftermarket 20" staggered setup with Pirelli RFT Scorpion Ice and Snow for $3300. The problem I have is the change in bolt pattern. I'll probably put the tires on a new set of rims.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
11-12-2018, 07:40 PM | #39 |
Rep 11
Undersized snows?
Most dealers seem to have BMW G05 winter setups as 265 50 19 - the overall diameter is 1/2" less than any of the OEM options (all are 29.7"). Is 1/2" smaller enough to look odd and/or throw the speedometer? Most BMW snow options seem to be exactly the same overall diameter as OEM even where the rims are smaller in diameter.
11-12-2018, 07:57 PM | #40 | |
146
Rep 330
11-12-2018, 08:10 PM | #41 | |
Rep 442
If you compare the 20, 21 and 22 OEM tire sizes, the circumference is different for all of them. |
11-13-2018, 12:34 PM | #42 |
Rep 769
this will not work, its for 2018. Tirerack is not aware of the bolt pattern change. You will need to return those
11-13-2018, 04:45 PM | #43 | |
239
Rep 353
The MSW has a 5 x 112 pattern and fit the hub as well. DrKev is correct and his fitment was confirmed by tirerack and my BMW dealer parts guy. Tirerack did scan of a G05 x5 with msport and the MSW style 48, also 49, and OZ cortina also works. Cheers! |
DrKevM52281.00 |
11-13-2018, 04:47 PM | #44 | ||
Rep 769
2022 x4mc (gone)
2019 X5 40i M-Sport (gone) 2016 X5 35i M-Sport (gone) |
