07-19-2021, 08:44 PM | #23 | |
Rep 7,586
So using the ventilation feature may be something you want to start doing on the days where you’re running the AC…its humid…and you park a hot vehicle in a closed garage. Let the ventilation feature run and it will help reduce the “prime” environment for the growth of mold and bacteria…which is probably the smell you’re getting. Running the ventilation fan will help evaporate residual moisture in the vents and on the condenser. If you were to take a wet towel, then toss it in a gym bag…and leave it like that overnight or a few days…guess what’ you’re going to smell when you open that gym bag…yep…that’s the same thing probably happening with your AC system and residual condensate as you park inside with very little air circulation and darkness. BTW, I’ve been using this ventilation feature for decades…especially on very hot humid days when I’m running the AC and then have to park in the garage. You can see the VENT feature on the MID of my old 97 e38 & 99 e39. I can say that it does work to help prevent AC stink.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-20-2021 at 09:54 AM.. |
07-20-2021, 12:57 AM | #24 |
Rep 20
07-20-2021, 12:08 PM | #25 | |
Rep 814
07-20-2021, 12:14 PM | #26 |
Rep 8,887
Drives: eVeRyOnE mAD!
leaves a rather strong odor in such a small enclosed space, eh?
07-20-2021, 12:30 PM | #27 |
Rep 528
I tried this today after a drive. Put it in park, shut off engine then enabled preconditioning from the idrive screen that pops up every time I turn off the car. The engine did indeed start back up, so won't work for me in my garage unless I leave the garage door open, which I would inevitably forget to close....
07-20-2021, 01:43 PM | #28 | |
Rep 814
07-20-2021, 02:31 PM | #29 |
Rep 8,887
can consider programming a favorite button to quickly access enabling/disabling remote Engine Start
07-20-2021, 05:18 PM | #31 | ||
Rep 7,586
What BMW does, though...is offer the ability to run the HVAC blower fan AFTER the car has been shut down...which can help evaporate excess moisture. Quote:
On my older BMWs with the CIC & NBT idrive versions...I have Memory button 2 programmed to take me directly to the CLIMATE screen to activate the "parked car ventilation" feature...the engine does not start...it runs the HVAC blower fan for approx 15-30 minutes without the engine running then turns off.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-20-2021 at 05:27 PM.. |
07-20-2021, 11:01 PM | #32 |
Rep 62
This kind of issue is common to all AC systems more or less. Solutions like the "parked car ventilation" is a good feature, MB had a "rest" button that circulated warm air from the engine after a stop. This was intended to keep the cabin warm but also worked excellent to dry up the vent ducts on hot days after parking. but if such options are not available, an alternative is to crank up the heating for a minute before parking from time to time. This dries up the residual moisture. Its a bit annoying ofcourse as you have to stay in the car while doing this (at least I havent found a way to keep everything running in the 45e when the EV battery is depleated), but it works while waiting for BMW to code in functionality like this in the I7
07-21-2021, 07:51 AM | #33 |
Rep 8,887
I'm confused. In the 45e, how is ventilating with A/C post-drive effective in mitigating moisture from the just-completed drive that was running A/C?
07-21-2021, 09:08 AM | #35 |
Rep 2,420
07-21-2021, 09:11 AM | #36 |
Rep 8,887
that makes sense. so that would mean that before I leave my car after a drive that used A/C, I would need to increase the thermostat to 80°F or so, so that when I ventilate, it's using heat
except there would be no residual heat from my ICE as I drive fully electric, therefore I would need to increase my thermostat in my 45e to accomplish this? |
07-21-2021, 10:17 AM | #37 |
1054
Rep 1,952
I may be misunderstanding things but I think of ventilation as different than pre-conditioning. Ventilation would just simple be allowing air flow. So for example, rolling your windows down on a hot day to get the hot air out. Instead of doing this, you schedule a ventilation period for the X5. I'm guessing if you have "engine start" toggled, you no longer have this ventilation option?
07-21-2021, 11:08 AM | #38 |
Rep 814
Wow nice. The more (I ask) I know about this car, the more I like it. This must be why some say once you step over the "dark side" there's no way back. Now if we could have a group of commands to be executed when a favorite button is pressed, it would be so cool.
07-21-2021, 11:16 AM | #39 |
Rep 173
Don't you have to set a specific time to "precondition" departure schedule or something?
Whats the easiest way to set this so when you remote start the car the AC comes on full blast |
07-21-2021, 11:58 AM | #41 | |
Rep 2,420
nZtiZia4764.50 |
07-21-2021, 06:44 PM | #42 |
Rep 210
+1 for IFTTT.
07-21-2021, 11:45 PM | #43 | |
Rep 62
Depending on design it will only work if the condensation happens after the point where hot air is routed into the vent system. If the problem is prior to this point it wont help |
07-22-2021, 11:53 AM | #44 |
Rep 744
My 2021 X5 M50i has a fan run for ~5 min after I turn off the engine. I’m not sure if this is to cleanup the AC or to cool the engine but I’ve never had an oder problem (well except wet dog) in eight months.
