10-24-2021, 12:04 AM | #23 |
Rep 159
OP, what aspects about engine Temps led you to believe they were overheating? 100F is serious heat. Most I've tracked in is 90F ambient and the car felt pretty stable and consistent to me.
I don't have any data readouts yet, but I'm under the impression that temps seem to be well controlled. Looking forward to the build! |
OG Shark4777.50 |
10-24-2021, 05:30 AM | #24 |
Rep 744
If you have the cash to splash BMW offer "Enduro" version of some of the cooling packs for 24h racing. https://www.apmotorsport.co.uk/produ...ion-oil-cooler https://www.realoem.com/bmw/enUS/sho...diagId=17_1204
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
OG Shark4777.50 |
10-24-2021, 01:26 PM | #26 | ||
Rep 157
Also I didn't find the cooling to be a problem in 90f temperature keeping an eye out on oil, water and DCT fo 15-20 minutes sessions, maybe the longer ones are a problem |
OG Shark4777.50 |
10-25-2021, 08:43 AM | #27 | ||
BimmerPost Supporting Vendor
4778
Rep 2,571
Awesome - think this is a excellent platform for this type of build. Not only fast but also an absolute joy to drive.
Dr.Mark84.00 |
10-25-2021, 10:13 AM | #28 | |||
4778
Rep 2,571
Heat Management
First just want to make it clear that despite having to do cool down laps mid session I was still very impressed with the stock cooling on the M2C. For those that haven't tracked at COTA before - it can be very hard on cars - heat management, brakes, etc. Add the high ambient temps we had that weekend and I definitely wasn't surprised to see elevated temps. I was hoping that in my baseline runs on MP4S that a full session at full pace would be feasible - but certainly not disappointed when that wasn't the case for me. One note on the pace we were able to get that setup to as well - definitely wringing the car out to get there. Been fortunate to have run a few hundred laps out there between racing/hdpe/private days so I feel pretty comfortable running as close to 10/10ths as I am willing to do in that kind of situation. About halfway through the baseline run I got the high temp warning and the car noticeably pulled power. The DCT was also getting pretty sloppy at that point. One cool down lap & she was happy again and we were back to full pace. I have no issue with having to do a cool down lap in this kind of situation. Its hot, we are running hard, and the tires could also definitely benefit from backing down for a bit. But with this car one of our goals is to be able to push hard for a full session without needing to back off. Track time is precious & I want the option to be able to go full bore as much as I want to without the car being a limiting factor. Also considering this will be the slowest state the car will be in moving forward I would definitely anticipate heat becoming a bigger issue. When we were on slicks during the afternoon I was having to back off at least a couple of times during the sessions. And since we are still a decent ways off from our time goal it definitely makes sense for us to address it moving forward. So cooling - definitely a case by case scenario. Absolutely depends on track characteristics, ambient temps, setups, etc. Definitely do not want to come across as saying the oem setup is deficient. On my other home track the engine temps were kept in check on our baseline run (although the dct still got a bit warm). Definitely do not want to change it if it is still keeping up (my recommendation to my customers - definitely do not throw money at something like this until it is needed.). But in this case seeing that the car will run COTA quite a bit and we have to deal with the Texas heat pretty often we are at the point where the oem system can't quite keep up. As far as what we are going with - Wagner for the radiators and a Mishimoto DCT cooler. As part of the last stage of the build (power) we will also be installing a Wagner intercooler as well.
10-25-2021, 10:27 AM | #29 |
4778
Rep 2,571
Going with their uniball bearings front & rear. Might be a bit much for a car that sees street time but that is a big part of what we are testing for.
10-25-2021, 12:04 PM | #30 |
4778
Rep 2,571
The Build Begins!!! Suspension...
Suspension!!!
We are working with Inertia Laboratory on putting the suspension setups together for the F87. Spring rates & lengths, valving, settings - get everything dialed in as best as possible for their intended application. First up is the Nitron R1 kit. Nitron has a track record of excellent performance and durability - exactly what we are looking for on our cars. The R1 kit consists of a single adjustment shock combined with Nitron's springs and camber plates. We are going with a one-way kit first since our priority with the build is to attain our goals in the simplest way we can. With a single adjustment unit being about as user friendly as you can get we felt it definitely needed to be tested first on our build. Going to be testing spring rates as well as lengths (wider tire clearance) both on the track and the street. Figure out which setup gives us the best mix of track and street manners. Will also consider the valving throughout the process. One of the big benefits in working with Inertia Laboratory is their resources & knowledge that will be a huge help working through everything. The setup will be installed later this week after we clear out a couple of other projects first. The MKR monoball bearings will not be installed until after we have some time with the Nitrons first so that we can gauge their individual benefits and/or drawbacks. Hoping to be able to start testing at the end of the week.
10-25-2021, 06:05 PM | #31 |
Rep 3,549
Drives: 328d Wagon, M2 Comp, i4 eD35
It would be great to see the design priorities and considerations when picking your spring rates and damper curves!
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
10-30-2021, 07:05 AM | #32 |
Rep 1,480
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Great job in on the build! I can't wait to check it out the next time I'm in Texas!
Happy Halloween!
10-30-2021, 08:12 AM | #33 | |
4778
Rep 2,571
Beautiful car! By far the best color Pretty sure you have two of the nicest E92 M3s out there. We got the supercharger installed on my E90 and took it out for the first test run yesterday!
11-01-2021, 08:45 AM | #34 |
4778
Rep 2,571
Nitron's Installed
We installed the Nitron R1 kit last week. Installation was very straightforward being a direct replacement, single adjustment system. Everything needed is included in the kit - including the camber plates. We set the ride height where we wanted and immediately started the most important testing - street comfort. I'm getting a bit softer as I get older and my tolerance for poor street characteristics is exponentially getting lower. After putting it through its paces on a mix of highway & some less than stellar roads it is apparent that we started out a bit too ambitious with the the spring rates. Although I think we would be happy with these rates on the track it is apparent we need to dial them back a bit to obtain our street goals. Happy with the length though - plenty of wheel/tire clearance (wanted to make sure we provided the necessary room to run the wider wheel/tire setups). When the new springs are on will recheck street compliance and once satisfied there will head back out to the track. On a side note we had the weekend of Dec 4 & 5 open up so we are going to head to Eagles Canyon in Decatur, TX and run the M2C in NASA time trials. Going to be far from optimized for whichever class we land in being basically a mildly prepped street car - but still ought to be a lot of fun. Will be running the car pretty much as it sits right now but with a 275/295 Hoosier A7/R7 stagger. Only other change I would anticipate is the installation of the Cobra Nogaro's and our half cage - we finally took delivery of our new automated tube bender & miller style notcher last week
11-01-2021, 08:52 AM | #35 |
Rep 505
OG Shark4777.50 |
11-01-2021, 11:30 AM | #36 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Looks amazing!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
OG Shark4777.50 |
11-14-2021, 04:29 AM | #40 |
Rep 878
Drives: ///M2
What kind of power is it putting down with the bend calibration tune?
Ethanol mix or full tank?
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
11-14-2021, 08:56 AM | #41 |
4778
Rep 2,571
We haven't touched anything power related yet including tuning - with this car we have been focusing on suspension to this point and haven't really had time yet to get to the power. Also still waiting on the rest of the coolers to show up so that we can install everything at one time. Should be pretty soon though - likely after we get back from the time trials we are running the first week of Dec. Will post before & after numbers once everything is in. Will be able to support full E85.
11-30-2021, 08:55 PM | #42 |
4778
Rep 2,571
Stock Dyno Run & TT Prep
Finishing up the prep for the NASA time trials at Eagles Canyon this weekend. Have to submit a dyno run for classing & needed a stock baseline anyways so went ahead and got that done today. 390 hp & between 408 - 415 tq - pretty much in line with what we have seen. With our running weight & adjusted hp/wt ratio that classes us nicely into TT3. So were pretty much going to run a stock car with upgraded brakes and dampers this weekend - ought to be a riot
And on the subject of the suspension - after deliberation with Chris at Inertia Laboratory the decision was made to first try revalving the Nitron’s since we weren’t quite satisfied with how they rode. He knocked them out quickly and we should have had them back with plenty of time to install and test before this weekend... but they have been in the FedEx black hole for over a week know. Finally got them this afternoon and going on the car in the morning. Very excited to see how these do this weekend.
M1500Z433.50 |
12-01-2021, 10:12 AM | #43 | |
434
Rep 351
I meant to post previously, but was going to say that it didn't look like the spring rates you've got there are too extreme and was wondering if a revalve might be better first, or maybe (just maybe) trying a tender spring. I have never driven a car running tender springs but have read they can make things a little vague initially as you overcome the tender rate and transition to the main rate, but maybe it would be worth it ¯\_(ツ)_/¯.* Cool stuff though and looking forward to seeing how you get the setup working. *I am a suspension basic Last edited by M1500Z; 12-01-2021 at 01:44 PM.. |
OG Shark4777.50 |
12-01-2021, 10:34 AM | #44 | |
4778
Rep 2,571
Initially was leaning towards springs but after getting to drive the car a little bit more I started leaning towards the dampening being the biggest issue - more in rebound but bump also being a bit too stiff. Once the graphs were received it confirmed that revalving was the best way to proceed first. Did not want to go softer on the springs if we didn't have to so hopefully this gets us where we want to be
M1500Z433.50 |
