01-09-2022, 10:19 AM | #23 | |
Rep 101
2019 X5 40i CHP | B&W | Executive | M Sport | DAP | Carbon Blue | Tartufo |
01-10-2022, 01:51 PM | #24 | |
Rep 81
Post a pic, I'll see if I can make some sense of it (unlikely lol). Not sure if there's a difference in f95 vs g05 B&W; I'd imagine there shouldn't be an issue with the harness. |
08-21-2022, 02:34 PM | #25 |
Rep 14
Do you have any pictures of the actual install? How hard was it to remove the coverings to get access to where you plug in the harness?
It's a brand new car and afraid of tearing into it if the dissassembly required is hairy! |
09-02-2022, 12:42 PM | #26 | |
Rep 81
The pictures posted pretty much show the extent of the install. It's very simple; coverings are held in place by plastic push pins to get the battery. The wiring harness is extremely accessible. Other than that it's just a few bolts to connect to the battery. For clarity's sake: https://www.youtube.com/shorts/rU66CcVwL3Y |
09-13-2022, 03:27 PM | #27 |
Rep 14
Thank you so much! Taking delivery this week hopefully, and will attempt the install in a few weekends.
I got the Technic harness + a Rockford Fosgate P300-12 powered sub. |
09-13-2022, 07:38 PM | #28 |
Rep 81
09-14-2022, 07:04 AM | #29 |
435
Rep 362
Out of curiosity what is your music source?
Are you playing high quality compressed loess files like FLAC or maybe Tidal HiFi versus compressed lossy Spotify or iTunes? It makes a tremendous difference. Your music will come alive if you are not. I used to love throwing in my Led Zeppelin II CD into my B&O in my F86 and letting it rip with amazing quality, but alas that won't happen in my F95. I use Tidal HiFi for better streaming sound. Instant upgrade.
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
09-14-2022, 10:54 AM | #30 | |
Rep 81
09-14-2022, 03:11 PM | #31 |
435
Rep 362
OMG. You won't believe the difference. More than the subs. Compressed iTunes and Spotify files sound like crap. I mean really bad. Especially noticeable with great HiFi systems like yours.
Might want to flatten out all EQ settings and ensure any loudness EQ is off.
09-18-2022, 11:24 AM | #32 |
Rep 14
Did the same thing as OP!
- Technic PNP harness + WavTech Link2 LOC - RF P300-12 powered sub Install was super super easy, the harness installs in 5 minutes and easy access on the side panel in the trunk. I took the longest routing the power/ground wires from the battery area to the trunk, then routed smaller AWG cables from the amp bracket to power the LOC + remote. Sounds sweet - really fills up the bass! |
johnnyredgtr120.50 scottiekay73167.50 |
11-08-2022, 11:27 AM | #33 |
Rep 88
[QUOTE=irpirate;28157351]As amazing as the B&W system is, the low end was a bit lacking for me(basshead). The goal of the install was to retain all cargo space and the spare. Initially I looked at spare tire powered subs but there just wasn't enough depth to be able to close cargo floor while keeping the spare; so I started looking at powered underseat subs. I settled on Kicker mostly because I like the company. Pretty straight forward install, all in all took 3-4 hours.
Kicker Hideaway 10 Technic PnP add a sub harness Not quite Sema quality lol but I'm just a dude in a garage who likes bass. Foam insert removed, all the spare tools went into a tool bag. Maybe someday I'll clean up the wiring if I care enough. Happy camper for now Where did you put the amp and what did you ground? |
11-08-2022, 09:14 PM | #34 | |
Rep 81
Is the enclosure secured to anything? The hideaway is a powered unit, amp is built in. Grounded to the factory battery ground (essentially battery -). |
Greg87611.00 |
11-09-2022, 02:28 PM | #35 |
Rep 29
I have the same sub as el_guineo just sitting in my garage looking for a home. Sine this seems pretty easy I may do it also
At the same time i like it empty and clean in the back DB 2022 X5MC Last edited by -DB-; 11-09-2022 at 02:50 PM.. |
01-22-2024, 12:40 PM | #36 | |
Rep 6
Questions: How do I connect an audio RCA signal to the Kicker's amp? How do I get power and ground to the Kicker's amp? Does PnP add a sub harness' provide the signal, power and ground? Or do I need to run wires under the car to the battery under the hood? |
01-22-2024, 01:10 PM | #37 | |
Rep 63
Assuming the G05 is the same as the F95, the car battery is in the back. So all you need to do is run the red power wire from that kit from the car battery to your powered sub. And then run the black ground wire from that kit from your powered sub to somewhere in the trunk area. |
01-22-2024, 02:36 PM | #38 | |
Rep 6
01-22-2024, 02:42 PM | #39 |
Rep 63
Mine is not in the spare tire area but one that is the cargo space. I usually don’t use much of the cargo space but if I did, disconnecting and reconnecting the powered sub is a simple task.
01-22-2024, 10:28 PM | #40 |
Rep 28
I had the JBL spare tire sub in my F85. I had to remove the strut on the spare tire cover to get it to fit.
Have not tried fitting it in the F95 because I'm lazy about wiring the gain control to the front. Last edited by X5MGuy; 01-23-2024 at 09:06 PM.. |
01-23-2024, 04:54 PM | #41 |
71
Rep 36
I opted to remove the spare tire and install the JBL Stadium BassHub powered by the JBL Club A600 600W mono amp. The Technic PNP - Bowers and Wilkins (Option 6F1) Add-a-Sub Harness for RAM/Booster audio systems - LOC-150: Gain Adjustment. Does and amazing job to fill in super clean bass and when the gain is turned up it literally shakes your soul. No regrets sacrificing my spare tire for the super stealth setup.
01-24-2024, 07:41 AM | #42 |
Retired Navy
39
Rep 118
Doesn’t the JBL BassPro Hub fit in the spare? Isn’t the JBL BassPro powered and not in need of an added amp?
Where did you get the LOC-150 for B&W and it is the one optioned in the link for $155 (meant for everyone who purchased one) and other items? Links https://technicpnp.com/product/bw-op...-systems-copy/ https://www.crutchfield.com/p_109BAS...ssPro-Hub.html Last edited by Vyper340; 01-24-2024 at 07:49 AM.. |
01-24-2024, 08:04 AM | #43 |
Retired Navy
39
Rep 118
Anyone try this subwoofer? Would it work (Crutchfield says it is a fit)?
https://www.crutchfield.com/p_109BAS...ssPro-Hub.html |
01-24-2024, 08:22 AM | #44 | |
Rep 63
You probably know this already, but if not, you’ll also need a 10-gauge amp wiring kit as noted in the Crutchfield listing for that sub. There’s a couple of links to buy that within that listing as well. |
