01-28-2022, 10:20 AM | #23 |
Rep 292
Are there any DIY videos or instructions for pad replacements on these cars?
r33_RGSport13122.00 |
01-28-2022, 10:47 AM | #24 | |
13122
Rep 18,794
The rear gets complicated when you are super low on the old pad. Here is the video that I found on how to do the rear.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 Coupon Code: "MEMORIAL" MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
01-31-2022, 03:00 PM | #25 |
Rep 21
Do these new pads have any impact of the typical life of the rotors? This will address the two largest complaints I have about the X5M, brake dust and squeal. Thanks
01-31-2022, 03:51 PM | #26 |
13122
Rep 18,794
No, same amount of rotor life based on my testing on my F97 X3MC.
02-01-2022, 02:43 PM | #27 |
3201
Rep 1,866
Got mine installed. Bite is real nice and feels like it stops quicker than before. Will post pics of dust in a couple days.
r33_RGSport13122.00 QF8221.00 |
02-01-2022, 06:36 PM | #28 |
Rep 818
Ben just did mine, pedal feel appears to be same as stock.. haven't had a chance to drive it more to test different conditions.. squeal is finally gone and i'll check on brake dust on the next wash.. so far so good!!
Retired: '02 E46 M3, '02 E46 M3 Vert, '11 E90 335d, '15 F10 M5, '17 F85, '18 F90, '02 E46 M3, '21 F96 Comp
02-03-2022, 11:13 AM | #29 |
13122
Rep 18,794
Local customer M8 GC with IS2000 pad after a week.
02-03-2022, 11:35 AM | #30 |
Rep 682
What about us cheap G05/G06 M50i's ?
02-03-2022, 11:38 AM | #31 |
13122
Rep 18,794
PM me your VIN and I'll check.
I believe I do have it.
02-18-2022, 04:27 PM | #32 | |
Rep 1,301
Which pads did you order and any update on the dust?
02-19-2022, 01:52 PM | #33 |
3201
Rep 1,866
Got the ones with more bite and more dust. This is what it looked like after a week
03-12-2022, 03:50 AM | #35 |
Rep 192
Update:
Ive had my IS1500 pads installed for over 3 weeks now without washing my car as a test. The brake dust is near non - existent and the brakes feel just like stock. Thank God no more brake dust. Thanks Ben for bringing these pads to market. |
03-12-2022, 08:13 AM | #36 | |
13122
Rep 18,794
Glad I can help you guys.
04-27-2022, 07:00 PM | #37 |
Rep 1,301
For the rear pad swap, did you replace the caliper bolts or re-use the existing bolts with a little locktite blue?? I'll replace both wear sensors. Received my IS2000 Fronts & rears from Ben yesterday so will probably do the replacement when I switch over tires to summers in a week or so if weather holds. i assume the small square brown packet that came with them is ceramic silicon grease similar to permatex 24127 ceramic silicon? Other thing to note is no counterweight on these like the factory pads.
04-27-2022, 07:08 PM | #38 | |
13122
Rep 18,794
Yes, the brown packet is the brake pad grease, not free Nutella from me. Counterweight it not required. I notice that BMW stock pads doesn't always comes with it. It is normally used to reduce brake noise.
04-27-2022, 09:17 PM | #39 |
19
Rep 46
Just had the medium compound installed yesterday. Absolutely silent. If theres no dust, thats gravy.
04-29-2022, 07:57 PM | #40 | |
Rep 292
04-29-2022, 08:12 PM | #41 |
Rep 1,301
How did you turn back the ebrake? Obd scanner/bimmerlink, caliper tool or did you take apart the actuator motor and wind back? Do you recall the size of the 2 front caliper bolts you removed to take off caliper? Mine looks like a torx bolt, round with torx fitting. These are the round bolts that the caliper bolts to the bracket in the inner side of the caliper ,they face front on caliper
04-30-2022, 01:57 PM | #42 |
Rep 292
I think I used the 8mm hex bit socket for the front caliper bolts.
I didn't end up turning back the ebrake and bc of that I got a bunch of malfunction lights. I took it to the dealer and they took care of it for me. I've heard bimmerlink works well. |
04-30-2022, 10:28 PM | #43 | |
Rep 1,301
Thank you!
05-06-2022, 07:05 AM | #44 |
Rep 1,301
Installed my pads yesterday. Used Bimmerlink brake feature to turn back EPB. Looking forward less brake dust. Shout out to Ben for making these pads available and for the outstanding customer service he provided with a few questions I had
