      10-19-2022, 02:41 PM   #23
chefwong
Drives: X5
Post #15
Remove the a Pillar Cover.
Do you flood test
See what it looks like with cover removed
      10-19-2022, 02:48 PM   #24
quad_drive
252
Drives: 23 X5 45e; 20 Cayenne S; 17 Q7
Originally Posted by talisman2208 View Post
It's raining. There's no hiding from it. Fills up with about an inch of water an hour. Not including the inch that catches in my Mat.
I'm going to try taping a bag around the roof.
You can tape around the perimeter of the whole sunroof, preventing any water from going into the sunroof gutter, so no water to drain.
      10-19-2022, 04:05 PM   #25
mmm50i
mmm50i's Avatar
545
Drives: '22 X5 M50i & '23 Model Y
I had a leak coming from the microphone when it was really pouring hard, but when it was light rain, water would come down the passenger side A pillar. The leak looks like it may be caused by a similar issue to what I've experienced.
I've posted in this thread in the past about my issue and the repair performed:
https://g05.bimmerpost.com/forums/sh....php?t=1581438
      10-19-2022, 04:07 PM   #26
talisman2208
Drives: 2019 X5
https://g05.bimmerpost.com/forums/showthread.php?t=1581438
Can you unprivate the video?
      10-19-2022, 04:10 PM   #27
mmm50i
mmm50i's Avatar
545
These should work!
      10-19-2022, 07:38 PM   #28
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
Even down here by the door?
The drain hose from the sunroof travels down the A pillar and it exits near the door check, then drains down to the ground.
Maybe there is a kink/clog in the hose and water is finding its way inside?
      10-19-2022, 08:09 PM   #29
talisman2208
Drives: 2019 X5
Must be. The sun roof is clear. Not a spot. Must be clogged at the bottom.
      06-30-2023, 09:30 PM   #30
arjun_3421
Drives: 2020 M340i Xdrive
Was this issue resolved? I am dealing with the same with my m340i. Dealer said that it's not covered under warranty
      08-16-2024, 02:35 PM   #31
neal@seatco.com
Drives: BMW X5
BMW X5 water leak
There is so much bad information about this problem. There are so many things that can cause this problem one fix cannot cure it all. The most common is clogged drains, easily cured, others can be complicated and expensive. Kinked or collapsed drain hoses are not so easy to repair. Materials in the drain channel blocking the drain would require the removal of headliner and sunroof cassette to cure. Broken seal between the cassette and the drain hose receiver, requires the removal of both the headliner and the cassette to cure. Bad weather seal on the glass needs new weatherstrip. Water on the floor is a bigger problem. Speakers and amps on the floor may be damaged as well as other electrical items. The carpet has a high density pad that absorbs water and does not easily release it, needs to be removed and dried or it will mold. Best advice is call insurance provider and make a water damage claim. Take it to a qualified shop.
      08-16-2024, 09:32 PM   #32
swainbmw
swainbmw's Avatar
899
Drives: 2022 x5 40!
Most likely sunroof drains
      11-15-2025, 01:57 PM   #33
Jacsoncheng
Drives: 2016 BMW X5
I tried this, hope its helpful to you all.
Right passenger side drain out is locate right behind here
pull off the strip here.
Door Wire Plug, pull it off, lift the cover slightly
tool needed, just similar, as long as you can reach the pipe inside
insert inside and clockwise turn 90 degree you can feel the pipe there, hook it and pull out.
take this out.
