02-23-2024, 11:59 AM | #25 |
Rep 4
For those with the Ikon lip, did it come with hardware and/or 3M double sided tape? And did the rear diffuser block the kick-to-open sensor for the trunk?
Thanks! Last edited by Laxplaya11385; 02-23-2024 at 12:12 PM.. |
02-24-2024, 06:48 PM | #26 | |
Rep 631
The rear diffuser does not block the kick sensor. EDIT: I did use 3M double sided tape during the install, highly suggest it. Last edited by mmm50i; 02-25-2024 at 12:40 AM.. |
02-25-2024, 09:11 AM | #27 |
Rep 4
02-25-2024, 03:37 PM | #28 |
Rep 84
Gloss black matches best. Looks great (ebay version) and fits well. Tough to install by yourself though!
[IMG] [/IMG] Last edited by velopod; 02-25-2024 at 03:46 PM.. |
chicagofan0019328.50 |
02-25-2024, 04:27 PM | #30 |
Rep 84
morales309933.00 |
02-25-2024, 04:41 PM | #32 |
Rep 8,113
Drives: 2024 X5 M60i
That does look really good! How’s the fit and finish in person? How is the install compared to the OEM CF version?
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
02-25-2024, 04:50 PM | #33 | |
Rep 84
I added a screw in the center of the lateral pieces and it looks great. Need to overdrill one side for the screw head/driver and smaller on the other. It did NOT come with double sided tape nor would I use that. So ... one factory bolt near the wheel well, screw just lateral to joint where the pieces bolt together and a screw at the center piece. I'm pretty handy with these things but I know everyone isn't. Can't commend on the OEM CF version as I wasn't going to spend $2K+ for that. I'm sure it fits fine |
02-25-2024, 04:58 PM | #34 | |
Rep 8,113
I’m so torn on which version to get. I’d love to stick with OEM for fit and finish purposes but I have zero CF on my X5 and just feel like the gloss black knock off versions would fit best given that it would match all the other gloss black with the X5.
02-28-2024, 08:11 AM | #35 | |
Rep 506
Gloss black looks better than carbon to me unless you plan on adding multiple other carbon pieces. I love the way the OEM(or knock-offs) splitter looks on either side but not to keen on the middle section. Still leaning Maxton, but will patiently wait and see. |
02-28-2024, 08:19 AM | #36 | |
Rep 452
https://www.amazon.com/dp/B0BWPSG4XW Here is a quick cell phone image. I suspect that many brand name splitters are being sourced from the same manufacturer and sold at many times higher cost. |
TravisBGolf132.50 |
02-28-2024, 08:44 AM | #37 | |
Rep 8,896
Drives: eVeRyOnE mAD!
I purchased OEM M performance CF side mirror caps, and they delaminated after 2 years. pretty upsetting for the price. they were ceramic coated (though knowingly doesn’t protect from rock chips or dings). ppf trial failed due to their curvature (it was noticeably ugly) if you can protect with ppf, all the better. if not, then gloss black is much easier to repair than CF (I replaced my side mirror caps with gloss black aftermarket ones) that said, I’m glad I went with aftermarket ACS-style front lip. it’s still doing well after 3 years even without ceramic or ppf |
03-02-2024, 07:30 PM | #38 |
Rep 23
RW CARBON
chicagofan0019328.50 Bottom1615.50 |
03-03-2024, 05:15 PM | #39 |
Rep 97
Drives: 2024 X5 40i, E63s AMG
Looks great. You mentioned tough to install by yourself....do you have any information you can share regarding the install, how it attached, difficulty if there are two people? Thinking about the same splitter. Thanks.
03-06-2024, 06:26 PM | #40 |
Rep 84
Not much to "describe". Uses factory bolts near wheel wells and screws in the center under the sensor plate that need drilled. I added another screw about half way to make it "tighter" to the body as I didn't want to use tape. It is very solid. Used jack stands to adjust and hold/fitting.
5ive7even165.00 |
03-07-2024, 03:38 AM | #41 |
Rep 585
Drives: F10 535i, M2 LCI, G05 X5 40i
Maxton
playswcars3689.00 |
03-07-2024, 06:33 AM | #42 |
Rep 206
Maxton v1
chicagofan0019328.50 playswcars3689.00 |
03-07-2024, 01:37 PM | #43 |
Rep 8,113
That one looks good! How do you find the quality and how was the install?
03-10-2024, 09:46 AM | #44 | |
Rep 206
Quality seems fine to me, fitment is good and I don’t see anything off with it. No concerns here. |
chicagofan0019328.50 bmwsone0265.00 |
