| 12-07-2023, 07:23 AM | #23 | |
![]() 18623
Rep 2,130
Drives: 2022 X6///M Comp
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
| 12-07-2023, 11:14 AM | #24 |
![]() 3626
Rep 4,534
+1, mine bongs at startup if temp is below 3C, and it will bong any time on that journey if the air temp crosses from above to below 3C.
tracer bullet6112.00 Efthreeoh22385.50 |
| 12-07-2023, 11:22 AM | #25 |
Rep 5,861
Yeah, me 3. Any cold start, even in my garage 1st thing in the morning, if it's cold it bongs at me. The methodology mentioned might be true of newer cars.
I don't mind it, it's kind of a subtle reminder to not go hooning around when tire grip is low. |
| 12-09-2023, 02:36 PM | #26 | |
![]() ![]() ![]() ![]() 22386
Rep 21,339
I stand corrected.But regardless, per the few different BMW manuals (my E30 is first where I read the detail about the warning) states what I wrote regarding the black ice warning. The E90 states it as: "When the displayed temperature sinks to approx. +37F/+3C, a signal sounds and a warning lamp lights up. There is an increased risk of black ice. Black ice can also form at temperatures above +37F/+3C. You should therefore drive carefully on bridges and shaded roads, for example, otherwise there is an increased risk of an accident." The "shaded road" one once showed me, on a road I used to drive on every day, how well the BMW stability control works. The ice warning came on just as I entered a very tight turn, in the shade, in the winter, and next to a valley of creek I had just dropped about 100 feet down into. Pucker factor pegged the needle. ![]()
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
tracer bullet6112.00 |
| Bookmarks |
