      12-18-2024, 08:14 AM   #23
DykstraMotorsports
DykstraMotorsports's Avatar
Drives: 2021 BMW X5 M50i
Originally Posted by matowi View Post
To those of you who experienced a differential failure, what were the symptoms. And, were you running OEM wheels or some aftermarket ones (importantly: were they in OEM spec in terms of rim sizes)?
The noise was a “whirring” or scraping type noise from the front.
Stock wheels 741M and tire size.
matowi1173.00
      12-18-2024, 10:11 AM   #24
matowi
matowi's Avatar
Poland
1173
Drives: '24 X5 M60i
2024 X5 M60i  [9.50]
Thank you!
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d
      12-18-2024, 11:30 AM   #25
dwwStL
dwwStL's Avatar
Drives: 2024 X5 50e, 2025 X3 30
Originally Posted by swainbmw View Post
....I’ve had this problem with Land Rovers over the years and what I started doing was getting a rebuild kit for the dif and having a local shop that specializes in transmissions and differentials to rebuild it much cheaper
This has happened to you so many times you have a standard go-too fix? I would die.
2024 50e Ametrin / Coffee Merino
2025 X3 30 Arctic Blue / Espresso Veganza
      12-18-2024, 11:33 AM   #26
swainbmw
swainbmw's Avatar
670
Drives: 2022 x5 40!
Yes, I left Land Rover many years ago in fact, 2015 started out with a Land Cruiser and found out what true quality was about with no Mechanical breakdowns Now I’m Toyota for life
dwwStL378.50
      12-18-2024, 11:35 AM   #27
dwwStL
dwwStL's Avatar
The leak(s) can't be fixed by replacing gaskets? Or even the casing. I'd think a local transmission shop would be able to fix this for less than replacing. Replacing for a leak seems excessive, but I've never had this so have no idea.
      12-18-2024, 11:37 AM   #28
dwwStL
dwwStL's Avatar
I think Land Rovers are beautiful and the coachwork is excellent, but wow, their reputation for mechanical failures is legendary. Notorious?
ETA: Range Rovers but same difference.
      12-18-2024, 11:38 AM   #29
swainbmw
swainbmw's Avatar
670
Drives: 2022 x5 40!
They’re so bad and I drove them for 20 years. They should be banned from selling cars.
dwwStL378.50
FSociety3897.00
      12-18-2024, 06:39 PM   #30
ef11
Drives: 2020 X5 M50i Loaded
I heard a sound that was like a coat hanger lightly dragging under the car. Could only really hear it from 30-40mph, but that may only be because there was too much wind noise above 40mph. Took it in and had the FDD replaced under warranty luckily. I could hear it more when next to a fence or concrete wall with the windows cracked.
2009 E90 335i MSport BSM over Oyster
JB4, VRSF CP, VRSP 5" FMIC, DPs, DCI
2020 X5 M50i Mineral White / Full Coffee Merino
DHP, DAP, Executive, B&W, Night Vision
matowi1173.00
FSociety3897.00
      01-13-2025, 04:31 PM   #31
eordaz
Angry Differential failure
I just got my car for service two days ago. For the last couple of months has been hearing intermittentl grinding noise. I thought that was the brakes. For my surprise the inspection showed that the front differential is leaking oil. The car has 53000 miles. The repair is quoted $9300. Outrageous.
I am waiting for the manager to get back to me to see what they can do. I will be calling today to BMW customer relations.
Seems there is a lot of people with the same problem. I believe this should be a lawsuit.
FSociety3897.00
      01-14-2025, 11:29 PM   #32
Axxlrod
Dude man
Axxlrod's Avatar
168
Drives: X5/X7/Acura NSX
Just adding info.
The front diff failed died on my '23 X5 50i at around 20k miles. Dealer blamed it on the replacement tires even though they were the stock size, but different brand since there was a tire shortage of the stock tires at the time.
Not sure how it ended up as I sold the X5 to the dealer while it was getting fixed.
FSociety3897.00
      01-14-2025, 11:55 PM   #33
suitedcboy
Cattlecar
109
Drives: 16 X5 50i MSport, 21 M50i DHP
On many models of many brands using variable torque distribution transfer cases (some brands call them Power transfer cases or power take offs) the part time diffs fails when the clutches stick. The part time diffs are smaller and that is true for near 100% of SUVs, CUVs, and 1/2 through class 5 truck front diffs. FWD based AWD would be rear diff failures. If the transfer case sticks and keeps too much torque on the part time diffs, the oil bakes and fails and gears gall and bearings fail. The worrisome part here is diffs getting replaced and no mention of anything done to transfer case.
      01-15-2025, 06:14 PM   #34
Zena123
Drives: BMW m850i xDrive
I agree seems to be happening a lot. I’m having same problems that started around 45k or earlier. What did BMW customer relations say?
      01-16-2025, 10:39 AM   #35
PunsGalore
BMW Enthusiast
PunsGalore's Avatar
305
Drives: 2011 328i xDrive Wagon
Im confused, is this issue specific to the V8 (50i and M50i) X5's or is this also on the 40i/45e's? Also, Land Rover/Range Rovers look great but you couldn't pay me to own one - too unreliable and expensive
2011 BMW 328i xDrive Sports Wagon - Deep Sea Blue Metallic over Oyster Dakota Leather
      01-25-2025, 08:48 AM   #36
Gerhard Lamprecht
Drives: 2014 F15 50i, 2015 F15 50i
My 2021 M50i front diff went at 78k miles. I had a 2014 50i and after 160k miles no drivetrain problems. I now have another 2015 50i and after 150k miles no drivetrain errors.
I read in the BMW technical training manual that BMW used thinner oil in front differential TO REDUCE EMISSIONS !!! There you have it. We are all screwed so BMW can meet EU emission regulations. Most likely also the problem with transfer cases that according to TSB had the wrong oil from factory. I think they just used too thin oil to reduce drag.
What upsets me is nobody told me. If BMW told me I would have done more oil changes and changed the oil and saved me the $6500 that they quoted for repair. Everyone makes mistakes, as I am a design engineer too, but not telling customers and sweeping it under the carpet is criminal. I am not sure I will ever buy BMW again, not even electric, because I never know what they are hiding from me - after my 12 BMWs 1992-2023 (31 years loyal to BMW) Very sad day for me !!!
FSociety3897.00
      01-25-2025, 09:28 AM   #37
rmorin1249
rmorin1249's Avatar
994
Drives: 2019 X5 MSport 40i
I had my transfer case fluid changed proactively at 35k miles. If it fails I will trade the vehicle immediately and I've previously decided the X5 is probably my last BMW. Do not like the new style, exterior or interior.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th and likely my last BMW), 2015 Mercedes SL400; 2009 Lexus RX350
      01-26-2025, 12:41 PM   #38
LuckyBrand
LuckyBrand's Avatar
1849
Drives: BMW X5 F15, G05 X5, G80 M3 6sp
I wonder if this effects the V8 models more due to the extra hp and torque? I see a lot of V8's posted. Either way this isn't a good sign. If you're looking for a used x5 I would be extremely cautious on miles and warranty.
Make today your best day!
      01-26-2025, 09:14 PM   #39
FSociety
IG @bmwF9xG80
FSociety's Avatar
3897
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [10.00]
2020 BMW X4MC  [10.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [10.00]
Originally Posted by Axxlrod View Post
Just adding info.
Did you buy another car from them?
Its not specific to engine, it' seems like a trend now on 40-60k mileage X5/X6/X7 but some never have an issue.
My 2020 X7 M50i front diff started grinding at 51-52k miles, the transfer case noise at 47k miles. All fixed by BMW CPO warranty so far now 55k miles no issues.
According to Facebook groups there's a TSB released by BMW and does not really matter the engine. Most ppl are changing the transfer case fluid at 30k miles and front diff fluid too.
Current 23 G80 M3x | 20 X7 M50
Previous
20 X4M, F90 M5, F80 M3
IG: @bmwF9xG80
      01-28-2025, 10:26 AM   #40
PunsGalore
BMW Enthusiast
PunsGalore's Avatar
305
Porsche next
