      02-14-2026, 08:57 PM   #23
Megapixel
15
Drives: 2023 BMW X5
Originally Posted by josec70 View Post
Have you thought about trying it on your own? It is not very difficult .. took me about 1.5 hours to do both.
I followed the IND video …
Just a thought if you want to save $ on the labor.
Good luck!!
Thanks for the response. I’m travelling in California, and I don’t have any tools at all, so I’m worried about trying it incase I run into issues. I’m not exactly sure what tools I’ll be needing to complete it all, and may not want to go out and buy them all, unless it’s really basic stuff. That’s the only reason why I’d prefer a shop to do it.
      02-20-2026, 09:34 AM   #24
PJ///M
Capo
PJ///M's Avatar
Drives: 2026 BMW X5 G05
2026 X5  [0.00]
Has anyone had any fitment issues with IND color matched side markers for the front?
I replaced all 4 front and back stock reflectors with the Brooklyn Gray IND painted reflectors. The rears were easy of course. The fronts were a pain going through the wheel well and they just don’t sit, or stay taped down properly. I prepped the areas perfectly after removing old and installing new, but I think the glue to the double sided tape was just bad. I think I have to go back in, remove and redo.
d_v_o_1118.50
      02-20-2026, 11:48 PM   #25
Megapixel
15
Drives: 2023 BMW X5
Very strange also to just see the general fitment seems to be off on the corners of the markers, like they aren’t original BMW pieces (which IND certainly uses). It’s throwing off the whole thing, beyond the pieces not sticking flush. Hopefully you can get it addressed. IND say anything about it?
      02-21-2026, 10:00 AM   #26
Akkord29
Drives: G05, F80, G20, E46
I saw this referenced in a video but also checked mine that just came in from IND and looks like they no longer use OEM Reflectors. The mold on the back of the reflector says IND. I'm planning on putting mine on tomorrow
      02-22-2026, 06:42 PM   #27
MmmCar
30
Drives: 21' BMW X5 Msport 23' X3 M sp
I just did mine today. The first one took a much longer bc i was hesitant to snap the trim which is held in by the clips (green circle).
Even with my fat hands, I was able to complete it by taking out the 2 screws (circled in red), popping off the molding, and popping out two rivots (i drilled out the center of each).
I did purchase a rivot tool that came with appropriate sized rivots off of Amazon for
Like $17. I have never used one before and it worked perfectly.
Appreciate 3
21X3M40285.00
TDWP169.50
      02-23-2026, 02:16 AM   #28
Megapixel
15
Drives: 2023 BMW X5
Could you provide the link for the rivet tool? Looks great BTW
      02-23-2026, 05:51 PM   #29
MmmCar
30
https://a.co/d/0amLfnFW
They come with 3 sizes, 10 of each. They worked perfectly and i have a bunch extra for when the need arises.
The hardest part for me was to get that body colored trim started. Once u get the bottom, u can gingerly work your way up the wheel well. There is a tab the you cant reach or see on the end of the trim which points straight down. That seems to
Be what keeps it real secure. I would guess to make sure your not doinf this in freezing temps, warm up the plastic to make it more pliable.
21X3M40285.00
      02-27-2026, 12:16 PM   #30
Megapixel
15
Drives: 2023 BMW X5
Thanks for the link!
I was also curious to see if anyone has used “Trasitional safety film” before on the reflectors? As a plan B, my tint shop said they would install this film that will darken with exposure to UV during the day, and will stay clear at night to maintain reflectivity and safety.
      02-27-2026, 03:12 PM   #31
TS29849228
TS29849228's Avatar
Drives: Germans Only
IND has an option to add "OE Plastic Rivets that are required for installation" for $18.
Are they literally just 1/4" rivets that you can get from the hardware store?
The fleet:
2018 F80 M3 Manual, 2022 Audi RS3, 2018 F87 M2 Manual, 2023 Audi RS5, 2024 BMW X5 50e
      02-27-2026, 03:31 PM   #32
Akkord29
Just finished mine up. I took the long route removing the wheel and fender liner. Definitely didn't need to remove it on the second side but did it anyways. As mentioned above removing the two bolts and rivets should give you enough space. The harder part getting the original reflector to come out. I used a heat gun sparingly and eventually got them started from the bottom.
d_v_o_1118.50
      03-02-2026, 07:23 AM   #33
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i, 2022 X5, 2018 330i
2014 BMW 428i  [10.00]
I purchased this “black” reflective vinyl from Amazon, and think it looks pretty good. No more ugly yellow yet still a reflector.
https://www.amazon.com/dp/B0D9LV5WRZ
___________________
2014 F32 428i M-Sport
2018 F30 330i
2022 G05 X5 M-Sport
Appreciate 3
Urbz14.00
d_v_o_1118.50
      03-07-2026, 04:07 AM   #34
Megapixel
15
Drives: 2023 BMW X5
Not bad, if I were to buy that vinyl roll, how does one go about installing and wrapping the reflector? Sorry for the Noob question
      05-10-2026, 05:43 AM   #35
Megapixel
15
Drives: 2023 BMW X5
Got a shop to install it for me, went with IND option. Very happy w it
d_v_o_1118.50
      05-10-2026, 12:46 PM   #36
Sevn86
Sevn86's Avatar
Drives: BMW X5 sDrive40i Msport
I went the vinyl tint route and haven't had any issues 2 years in. Plus I think it looks nice with all the other black accents the X5 has.
Current - 2025 X5 sDrive40i M Sport/ 2021 Range Rover Westminster
Sold - 2023 Lexus RX350 F Sport/ 2023 Rivian R1S Launch Edition/ 2018 Range Rover Sport HSE
/ 2017 Lexus RX350 Luxury Pkg
d_v_o_1118.50
      Today, 10:14 AM   #37
Boston G05
Drives: 2024 X5 M-Sport
Can you link the vinyl tint you used? And is it pre-cut?
      Today, 03:51 PM   #38
LDT
LDT's Avatar
Drives: 2026 540i
www//lamin-x.com
E70,F15,G05,G60
