06-29-2016, 04:27 PM | #45 |
370
Rep 354
I think that, I figured how this works actually.
AMG A45/CLA45 tuned their exhaust systems similar while in sport mode and on higher revs to produce those burble sounds. So, how it works well very simple by when you release the throttle between 2k-4k range, the small amount of fuel is being injected which makes those little crackles and which cool down the turbo in the same time. This is for practical reasons way more pronounced in sport+ mode and on higher revs, as it actually has real purpose, but again in comfort and only click of dsc is simply pointless and just to draw attention (show off). Well, It switch back to comfort mode anytime when you press DSC short or hold it for too long. So request is if someone with MPE, sport-cat decat or fabspeed pipes could try this out on idle, and make some video. Just rev on idle up to 4k revs and release the pedal. I will try to make comparison video in the next few days. Last edited by Yellowflash21; 06-29-2016 at 05:01 PM.. |
06-29-2016, 05:17 PM | #46 |
Rep 3,888
I agree that unburnt fuel causes pops as it hits the hot exhaust metal and ignites. But is the exhaust louder in comfort+DSC blip or does it just have more pops (running even richer)? If just more pops, then it must mean more unburnt fuel is making its way into the exhaust, right?
06-29-2016, 05:28 PM | #47 |
370
Rep 354
Can't determine huge difference on higher revs in that and in regular sport+ mode.
Will have to get one of those sound level measuring device, and record everything on idle. |
06-29-2016, 05:44 PM | #48 |
54
Rep 46
This works with the MPE as well. It's my new favourite radio station.
AndrewC198910949.00 |
06-29-2016, 09:55 PM | #49 |
759
Rep 1,835
Drives: 2020 X4M CS
Def for real...Im catless, and have the BMS Can Flap Module...I did it accidentally and it was outragrously loud....Then when I accidently turned it off I was confused and upset...playing with settings and using the bms mod, my inly conclusion is def an open valve along with maybe a more conservtve ignition timing setting or something, i dont have any idea but def more unburnt fuel exploding in that pipe...
I let off next to ppls windows, and I could imagine it would be startling...LOL im a dick
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
06-29-2016, 11:52 PM | #50 |
Rep 668
This is now my default driving mode.
I like the fact that we now have the benefit of diminished traction / lighter steering / burbly lift- off. The only issue is the diminished throttle response in comfort. I fixed that tho with a accelerator plug in |
///AVM2531.00 |
06-30-2016, 05:03 AM | #51 |
Rep 3,022
Yes totally.
Its not ASD, as mine is coded off, and it is all exhaust noise anyway
M2 Arrived!
Family 5er |
06-30-2016, 06:48 AM | #53 |
Rep 65
Brilliant find, well done to the OP and shame on all the people that doubted him without trying it first!
It works in auto mode on the DCT as well, so you don't have to put it into manual to hear it. From my playing about with it, it seems like you are putting the exhaust into the same as Sport+ while the engine/DCT stays in comfort mode. A little less help on the traction side, but who cares about that when it sounds even more awesome for low speed in town driving. |
caseymack5.00 |
06-30-2016, 07:04 PM | #54 | |
759
Rep 1,835
Drives: 2020 X4M CS
Im installing this witha NX express WOT swich under the throttle pedal (activated at 50% throttle) and a toggle...Piping the unrestricted 3" pipe to a 2.5" polished SS reducer to a hole in the side skirt in front of the rear tires with a professionally fabricated carbon heat shield/surround....Then going to have a JB4 map tuned to a super rich mixture as running rich all the time might avoid knock but it robs power and over time wears piston rings.... Used it n my evo 8 and it spit flames under the car until i got a flash which leaned it out... Not even kidding, seriously doing this lol. Im going to have a spare side skirt after this repair...hehe. Doing it for uniqueness and performance but if i can geta setup going hat shoots flames that will be a bonus..
JackyStuntin154.50 |
06-30-2016, 09:22 PM | #56 |
Rep 5,678
I find the exhaust is more burbly by doing this in all modes... including Sport.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
06-30-2016, 10:17 PM | #57 |
3692
Rep 15,083
Drives: '16 M2, '23 GT4
Nice! Tried it this evening!
IG: Trackinheels
06-30-2016, 10:21 PM | #58 |
Rep 556
annabellapizza236.00 |
07-01-2016, 03:28 AM | #61 |
Rep 103
Side topic, does anyone know how loud (in decibel) is the m2 mpe? Particularly interested to know the noise leave in track mode. Just wanna double check whether it passes my local authority noise level.
07-01-2016, 07:05 AM | #64 |
Rep 3,888
07-01-2016, 07:08 AM | #65 |
Rep 235
07-01-2016, 12:35 PM | #66 |
Rep 3,844
In the M235, long 5 second press of the traction button is "DSC off" mode which is said to be the best mode for tracking the car. It activates the e-diff and tells the nannies to go away. It is a an actual mode in itself, I find that this mode sets my car free.
I'm interested to know if the button works the same way in the M2, of course the M2 uses the excellent M diff instead. |
