      07-12-2024, 04:31 PM   #45
starlights
Drives: G05 50i
Originally Posted by TurtleBoy View Post
You can't fully implement anti dazzle using Bimmercode since it does not have access to all of the ECUs required. If you aren't going to get it done again by a coder using E-Sys you can implement a faux version using Bimmercode. I did that on my X5 and M340i and have not had any issues as it seems to work pretty well.
Awesome! Thank you for your quick response.
It's the time waiting in the Garage and setting up the VM for remote coding that I am trying to avoid.
      08-05-2024, 05:05 AM   #46
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
It is rather great people are admitting it cannot be come with bimmercode alone.
      08-06-2024, 01:21 PM   #47
starlights
Drives: G05 50i
I updated the code using TB's code provided on the 1st page of this thread through BC - I will report back in a few days after I have tried out the Anti Dazzle at night.
      08-16-2024, 10:39 PM   #48
sky520
Drives: BMW
Have you had the chance to try it out? Does the coding with BC bought you the desired features of Anti Dazzle? (I understanding it will not be 100% but 90%?)
      08-19-2024, 10:21 PM   #49
starlights
Drives: G05 50i
I finally got an opportunity to try out the anti dazzle and the lights worked perfectly. I couldn’t discern any difference from when the lights were previously coded remotely. No one flashed. Lights went to high beams on dark roads and stayed on hi beams both when following and with on coming traffic. Good to go
sky5200.00
      08-24-2024, 03:37 PM   #50
BruinMan
BruinMan's Avatar
97
Drives: BMW X5 M50i Unicorn
Confirm Anti Dazzle with Laser Lights
Alright. I have Laser Lights on my 2021 X5 and at times do long trips. My high beams turn on automatically and temporarily turn off with on coming traffic. I have done a bunch of Bimmer Coding.
It would be cool to code the Anti-Dazzle on.
All I need to do is follow TurtleBoy’s instructions?
You may want to try G05_Laser_ECE for LUT_AFS_DRV_HOR since the code below is from someone coding the G20. Obviously you want to use the ECE values and not the US.
2021 BMW X5 M50i Tanzanite Blue II Metallic
      08-24-2024, 03:39 PM   #51
BruinMan
BruinMan's Avatar
97
      08-25-2024, 12:42 AM   #52
starlights
Drives: G05 50i
Correct. In BC expert mode find entries from left column (easier to use keyword search from inside expert mode. They should be defaulted to middle column (US), chenge the selection to right column (Euro). For the last line, select G05 laser. Go slow to ensure you are changing the correct code because many lines appear similar at first look. Good luck.
      08-25-2024, 02:19 PM   #53
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
So using expert mode in bimmercode will allow the full anti-dazzle feature?
      08-25-2024, 02:44 PM   #54
BruinMan
BruinMan's Avatar
97
Thanks buddy!
      08-25-2024, 02:46 PM   #55
BruinMan
BruinMan's Avatar
97
Not full like the Euro cars. Per Turtle, it is pretty close for us in America.
      08-25-2024, 06:56 PM   #56
TurtleBoy
TurtleBoy's Avatar
17604
Drives: 2019 X5 40i,2021 M340i
No, not at all as you can't access all of the ECUs. You can enable a faux version that works very well.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      08-25-2024, 08:31 PM   #57
starlights
Drives: G05 50i
Honestly I m not sure what the difference is. I have had them both ways and I cannot tell any difference. My original coding using Esys got erased during SW update and I now coded it myself using the above code that you provided. Thanks for the code
      08-25-2024, 08:35 PM   #58
TurtleBoy
TurtleBoy's Avatar
17604
The code I posted works well. They main thing that you don't have is the access to the KAFAS ecu so I think spotlighting as well as some dimming due to road signs, overall not a big deal.
      08-25-2024, 08:43 PM   #59
starlights
Drives: G05 50i
Perhaps because my car was previously coded using Esys and all ECUs were coded and VO changed and maybe that change to those ECUs survived? : I can never be sure but I observed no difference from earlier coding and now.
      08-25-2024, 08:49 PM   #60
TurtleBoy
TurtleBoy's Avatar
17604
That could be the case.
      08-26-2024, 03:38 PM   #61
BobsM3Coupe
Drives: X5MC
I do remember when mine was coded with esys for anti-dazzle, that the spot lighting on signs did work well. After an OTA update, that feature, along with other anti-dazzle features was certainly gone.
Thing is I very seldom drive at night, so I don't know if I should bother with the faux version.
In some ways when the car had the esys version, I found the moving around lighting pattern kind of distracting.
Decisions, decisions???
      08-26-2024, 04:05 PM   #62
ekaz
Drives: X5 M50i
Has anyone coded anti-dazzle with Bimmer Utility? Is it this "fake" version or the full esys version?
      11-02-2024, 08:21 AM   #63
NbyNW
21
Drives: Various and many
Does anyone know if there is a chip based mod? One that plugs into the OBD port to unlock this feature.
One company from their website offers a remote connection but I don’t have Windows, I’m all Apple if that matters.
I’m not interested in coding that’s noted here especially if it’s not 100%.
      11-02-2024, 08:48 AM   #64
TurtleBoy
TurtleBoy's Avatar
17604
No there is not.
      11-03-2024, 09:00 AM   #65
jonesy16
Drives: 2018 530E xDrive, 2021 45e xD
I have done it. I have nothing to compare it to since this is the only way I’ve tried it. I know it did flash some ECU’s as a part of the process and I can say this the lights appear to “spotlight” road signs.
ekaz90.50
      11-23-2024, 02:16 AM   #66
Almaretto
Almaretto's Avatar
I have done it multiple times but never involved flashing. What procedure did you follow?
