01-25-2025, 02:26 AM | #45 |
Rep 88
Drives: '04 E46 ZHP 6MT, '22 G22 RWD
OK. Thanks! I ended up ordering the set from ETAmfg.com (where I also ordered the Renn stands.) They are tall enough to prevent crushing the sides of the jack pad receptacle on the car.
01-25-2025, 10:01 AM | #46 | |
Rep 4,534
Look like the same ones I have. Pretty sure I bought mine at ECS a loooong time ago but what I see there now is $30 a pop. I don't mind paying them a little extra but not that much for these things. |
01-26-2025, 06:29 AM | #47 | |
473
Rep 395
01-26-2025, 09:52 AM | #48 |
Rep 4,534
I just checked a few minutes ago, and they do for me. The BMW black plastic gizmo has about 1/2" in height inside, and these are slightly over 1/2" (the page says they are 0.6"). Mine goes in and solidly hit where they can hold the weight of the car, and there's still a sliver of daylight all the way around them.
01-26-2025, 08:42 PM | #49 |
1Addict
3700
Rep 8,225
Honestly I just roll the car up onto some 2x4s and then use a normal low pro jack.
I would not trust RennStands. IIRC there have been... Tipping events.
2010 E82 1 Series M Clone
Hydra Performance augmented OEM+ |
01-26-2025, 08:56 PM | #50 |
Rep 4,534
I was thinking about that as well. You could angle them somewhat and make them pretty safe, I think.
Envision them being the ends of an X shaped pattern. It made me think about my Esco's, too, the tripod shapes and ensuring that a triangle point is facing outwards. I have occasionally put my snow tires under the car as a backup plan. Which I think is related to the topic to mention. |
01-26-2025, 09:52 PM | #51 | |
1Addict
3700
Rep 8,225
02-01-2025, 07:52 AM | #52 |
473
Rep 395
I've had multiple cars on my Rennstands dozens of times. Nothing close to a tipping event ever! Anyone can F up any jacking situation by performing reckless actions on any tool. Be smart and you won't have an issue.
02-01-2025, 04:41 PM | #53 |
Rep 703
Drives: '25 M240xi
To the OP question.
I just switched to the long reach low profile from harbor freight. What a huge improvement from the normal jack! Reach to center jack point. Lift car. Jack stands under the side points (using the heavy duty HF circular pad ones) repeat if you want the whole car up. So much better than lifting onto ramps or on the sides. Car is up and down twice as fast and way more safely.
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
tracer bullet4126.00 Belair6221.00 |
02-02-2025, 01:45 AM | #54 | |
21
Rep 36
02-02-2025, 06:04 AM | #55 | |
Rep 703
Drives: '25 M240xi
If anyone is contemplating picking this jack up regularly.... don't.
Belair6221.00 |
02-02-2025, 08:48 AM | #56 |
Rep 121
Yeah, mine is mostly on the ground, rolling around the garage and driveway. I do take it with me on track days (to swap wheels at the paddock), not a big deal to lift it into the trunk, but if an aluminum jack happened to land on my lap (which would still hurt like hell), I wouldn't say no. Just not bothered enough for 2-3 track days a year to get one.
tracer bullet4126.00 |
02-02-2025, 10:01 AM | #57 |
Rep 4,534
I've got an old Craftsman and a new HF Low Pro / Long Reach as well. I tend to still use the Craftsman, it's just lighter and easier to move around. The HF has its moments (left under the front or rear central points, or to get my X3 super high) so I'm glad to have it but it is not the one I go for when doing simple things like semi annual wheel and tire swap.
