| 02-16-2026, 11:35 AM | #49 |
In the garage
500
Rep 243
14 days door to door, ordering direct from 11Mode. Installed in 5 minutes and programmed 'open' to Homelink button. Works perfectly. I love that there are no wires or modules to install, unlike the VSC-2 I installed, which didn't work anyways.
BMW M2CS 6MT - sold
BMW X5 M60i |
X5Mnwi48.00 |
| 02-19-2026, 05:40 AM | #51 |
Rep 262
Drives: '26 BMW X5 M60i
| 02-24-2026, 02:28 PM | #52 |
Rep 1,399
Received yesterday, installed today. Nice upgrade….but damn, took me 30 minutes to get them plugged in….not a ton of room down there.
| 02-25-2026, 06:56 PM | #53 |
48
Rep 43
Drives: 2026 BMW X5M60i
| 02-25-2026, 07:49 PM | #54 |
Rep 262
| 02-25-2026, 10:43 PM | #55 |
![]() ![]() ![]() 667
Rep 501
You can wire the fuse in parallel with a rocket switch, stick it in glove box and can have memory function with 11mode controller. Turn the switch on (connecting the fuse), valves are in stock mode. Press open button on 11mode remote and turn switch off : valves fully opened.
IL X5 M60i43.00 20X750556.00 |
| 02-26-2026, 04:49 PM | #56 |
![]() 273
Rep 229
I just received my 11mode valve controller. It says on the packaging label "BMW M3 (G80/G81) Exhaust Controller" - will this fit the G05 X5?
On order 2027 G80 LSB Tartufo Carbon bucket seats
Current 2026 X5 G05 40i M Sports with MPE ![]() |
| 02-27-2026, 01:32 PM | #57 | |
![]() ![]() 43
Rep 377
| 02-27-2026, 08:11 PM | #58 | |
Rep 501
Stick the rocket switch to glove box or convenient place you can reach to turn on / off along with your 11Mode remote. With that setup in place. Now you can : - Rocket switch turn on: fuse connected and you have stock vavle mode - Preess 11mode remote to open vavle and turn the rocket switch off: fuse disconnected and Vavles fully opened and stay opened until you turn on rocket switch again. The below illustrates the setup: |
| 02-28-2026, 02:06 PM | #59 | |
![]() 273
Rep 229
My G05 has one valve so I have an extra controller.
| 03-01-2026, 11:38 AM | #60 |
![]() 20
Rep 56
Drives: Current 2015 M3;Old 09M3, 04M3
Ordered my 11Mode controller for my M60 and GT3. Can't wait to install and hear how it sounds!
| 03-02-2026, 08:36 PM | #61 |
![]() 11
Rep 33
Anyone ever take a look at the control signal to the flap? I believe I read it was a PWM signal.
If one knew what the signal looks like, it would be trivial to do this with an Arduino. Would be nice to save a few hundred $ for some DIY |
| 03-12-2026, 10:12 PM | #63 | |
![]() 78
Rep 63
Yup, it’s most noticeable during a cold start, but I can confirm there is an increase in overall exhaust sound even in comfort mode. I have an M60i. Last edited by bimmerdream; 03-14-2026 at 11:01 PM.. |
PCar2Bcar152.00 BMWM3Rules20.00 |
| 03-12-2026, 10:20 PM | #64 | |
![]() 152
Rep 84
I guess question regarding cold start...I thought the valves "reset" to default function after turning the car off. I assume then to get full cold start impact, you would need to set car to accessory mode, toggle the valve controller remote, and THEN push to start actual engine...? Sorry if I'm not wording that right. |
| 03-13-2026, 07:38 AM | #65 | |
![]() 78
Rep 63
I just turned on the car normally and opened the valve after that. I have the valve open function programmed to my home link buttons in rearview mirror, so it was just a matter of seconds. Haven’t tried opening it in accessory mode tbh. |
| 03-13-2026, 12:09 PM | #66 | |
![]() ![]() 43
Rep 377
BMWM3Rules20.00 |
| Bookmarks |
