BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      12-02-2015, 06:24 AM   #67
Tjalle
Drives: X4 35i
Wheels?! Take a look at the X4 thread 22"!
      12-03-2015, 03:38 PM   #68
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
Originally Posted by Jonny
Here's my new setup... Sorry for the crappy iPhone pics.
20" m5 replicas
I think the m5 reps are the best looking stock style wheel for the X3 . This style and the spoke style 345m. If they only made the 345m in 20" hyper black , I would have gotten them.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
      12-03-2015, 03:41 PM   #69
///Mposter
Macgyver
///Mposter's Avatar
Oh and here is my 20" setup as well. I had my own thread but for the sake of this one.
245/45/20 all around MRR H-10.
I've since modified the BMW center caps to fit the wheels so it looks more OEM.
      12-09-2015, 08:45 PM   #70
jello
jello's Avatar
184
Drives: LCI M2
2018 BMW M2  [8.33]
bbs xa
20x8.5 et 33 w/ 245/40
20x9.5 et 42 w/ 275/35
seriously contemplating on dropping with euro version of eibach to which drops to 1 inch front and rear. what do you guys think? nothing crazy but just a mild drop though...
      12-10-2015, 02:12 AM   #71
Jonny
Drives: Bmw 2011 X3 F25
They do mate. I had the option for either this or the black...
      12-10-2015, 08:34 AM   #72
///Mposter
Macgyver
///Mposter's Avatar
I searched eBay for a while waiting for the graphite or " hyper black" which is the dark chrome look. The only one available for more than 6 months was silver or black. So I went with another style.
      12-16-2015, 04:31 PM   #73
PARTS@STBMW
PARTS@STBMW's Avatar
2714
Drives: BMW
Loving all the 20's on your X3's!
      12-22-2015, 09:37 PM   #74
BE X
Drives: X5 35d /X3 35i / R1200R
303m on F25?
Has anyone tried OEM 303m wheels on an F25?
Bit of research compared to the 310m wheels:
BMW 310m
Front alloy wheels: 20x8.5" ET38
Rear alloy wheels: 20x10" ET51
BMW 303m (from F07 - 5 GT series and others)
Front alloy wheels: 20x8.5" ET25
Rear alloy wheels: 20x10" ET41
Based on a wheel offset calculator on
Fronts would sit 13 mm wider (Is this too much? Cause issues long term?)
REARS - CORRECTION BELOW
I like this style wheel but could live with 19" if there are some OEM options that are similar...
      12-23-2015, 01:53 PM   #75
///Mposter
Macgyver
///Mposter's Avatar
BMW 310m
Rears would be 10 mm narrower - so would need spacers - thinking 15 mm but could it stand 20 mm? 20 mm would put the rears at +10 mm compared to the 310m.
The only thing I didn't confirm when I was looking at buying a set in Charlotte was the center bore could be larger than the X3's . If I recall correctly, the x5 wheels and 7 series may have the larger bore. I cannot confirm right now. As for offsets, I tried a 19" 9.5" et 33 and 10" et 38 up front . It stuck out slightly but not enough it would be a concern for me. So in comparison 8.5 vs 9.5 is a 10mm difference , so my 9.5 et 33 is like a 8.5 et 23. I also don't have the calculator but you could confirm the results.
      12-23-2015, 02:03 PM   #76
///Mposter
Macgyver
///Mposter's Avatar
Okay so here are some pictures. What you see is the 10" wide 275/35/19 in front and rear. (They were the rears on my coupe. )
      12-23-2015, 02:04 PM   #77
///Mposter
Macgyver
///Mposter's Avatar
Won't let me post pictures again....
      12-23-2015, 02:13 PM   #78
///Mposter
Macgyver
///Mposter's Avatar
One last try. Top down at two different angles.
      12-23-2015, 02:44 PM   #79
///Mposter
Macgyver
///Mposter's Avatar
Okay so I searched Google and found the 303M from a seller claiming the center bore is 72.5. So then I checked the forums and found that x3 f25 is as known 72.5. And the F01 7 series is also 72.5 according to the forum posts.
Best of luck with the purchase. I would like to see them in some real world pictures mounted !
      12-23-2015, 04:13 PM   #80
BE X
///Mposter - thank you, thank you, thank you! Appreciate the pics of the 10" 19's - no issue with that much extension. Will need to do my diligence on using spacers at the rear (most comfortable with the concept - just know to use high quality for all parts). Really like the look in the left pic at post# 76 - where on earth did you find that?
      12-24-2015, 03:33 PM   #81
BE X
Checked my rear offset calculations - had them backwards!
With 303m wheels =
Rear - 10mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 10mm
No need for adapters!
Maybe a set of 343m instead...
      01-16-2016, 12:23 AM   #82
FSociety
IG @bmwF9xG80
FSociety's Avatar
3817
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Anyone using 20s with All-Season or Winters lol?
Wondering how if anyone crazy enough to roll with 20s in the winter Except the X5/X6 guys they have to
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo
60-130 4.82s | 9.4@148mph 1/4 Hybrids
IG: @bmwF9XG80
      01-16-2016, 12:20 PM   #83
car_fan
car_fan's Avatar
382
Drives: 2020 F97 X3M
2020 BMW X3M  [0.00]
  [0.00]
245/40/20 Yokohama Advan A/S. SoFla to Iowa and viceversa. No choice but to, as I wasn't going to run summers in temps below 40F. I'm liking these tires so far, was going to go with the Continental Extreme DWS or Michelin Sport A/S. So far I am pleased with the peformance and looks of the Yoko's. I even put a set on the MINI
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired)
2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired)
2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired)
      01-18-2016, 07:59 PM   #84
///Mposter
Macgyver
///Mposter's Avatar
Yes Pirelli scorpions.
      01-18-2016, 09:28 PM   #85
FSociety
IG @bmwF9xG80
FSociety's Avatar
3817
Wow really.. no issues?
I thought only 245/40-20 would fit the front
60-130 6.5s X4M
IG: @bmwF9XG80
      01-18-2016, 09:34 PM   #86
///Mposter
Macgyver
///Mposter's Avatar
If there was a sale on 255/45/20, I probably would have tried it. 245/45 is close but there is a little bit more room. I'd have to look at the tire size calculator again to see how much extra diameter is added.
(I wanted to close the gap without lowering SUV)
Edit;
Okay so I used the example of a fitting 19" tire size diameter to calculate what it would be in 20".
255/50/19 = diameter 91.2"
245/45/20 = diameter 90.1"
255/45/20 = diameter 91.2"
Also be aware of the plastic flap that protrudes from the spring/ strut area. I guess it could be cut away if the offset is too close (high) verses a low offset wheel that sticks further out towards the fender.
      01-19-2016, 03:43 PM   #87
FSociety
IG @bmwF9xG80
FSociety's Avatar
3817
Edit;
I have M-sport so no plastic
60-130 6.5s X4M
IG: @bmwF9XG80
      01-21-2016, 09:39 PM   #88
S-P335xi
Drives: e92 335xi
I need your help guys. I want to know if style 214 will fit on my x3 ?
My car : x3 F25 35i Mpack 2013
My wheels right now :
Style 369
19 x 8.5 et 38
Style 214 :
Front : 20 x 10 et 40
Rear : 20 x 11 et 37
It will probably needs some spacers ?
Help
http://www.willtheyfit.com/index.php...et2=37#content
135i N54 Mpack Jb4 intake DPs
F25 35i - Mpack - Fully loaded
Tags
eibach, lowered
