11-25-2023, 08:51 AM | #67 |
Rep 602
Westside Guy5970.50 |
11-28-2023, 12:23 PM | #68 |
39
Rep 35
Anyone have a good sunglasses holder solution? i have Maui Jim sunglasses and they're a little larger than standard. i keep them in the door pocket now, but would be nice to have them more protected, in their own spot.
11-28-2023, 12:29 PM | #69 |
Darth ZEDer
6304
Rep 1,143
Drives: 2022 BMW Z4 sDrive3.0
My sunglasses and gloves easily fit here.
9
ebirotedu1484.00 MisanoblueZ41456.50 tallslenderguy39.00 Westside Guy5970.50 stlcdr1025.00 Wynnsiensheng900.50 Flying Clog89.50 Golfman35.00 mdoneinvt522.00 |
11-28-2023, 10:42 PM | #71 |
Rep 4,600
Drives: 2022 Z4 M40i, 2021 228i GC
11-30-2023, 07:05 AM | #72 |
Rep 67
^^ What Westside Guy said. Me Two
11-30-2023, 11:26 AM | #73 | |
Rep 4,600
In fact when I first picked up my car I thought the fuse box was behind that cover. |
12-01-2023, 10:01 PM | #74 |
Rep 19
Here's an extremely minimal accessory that took me a few tries to find. If you either don't have the wireless charging pad or don't want to cook your phone with it, you can charge your phone with the USB connector next to it. Here's an extremely short cable with exactly the right configuration: a straight USB-A connector on one end and and a right-angle USB-C connector on the other end. It was $5.00 from a company called Tackform that mainly makes phone mounts. They have Lightning and micro USB versions as well. I tried two other cables from Amazon that didn't work. The first had a right angle USB-A connector which was sticking up in the air preventing the sliding cover from closing. The second had a USB-C connector that didn't have any space between the right-angle connector and the rest of the cable, so it didn't clear my phone case.
https://www.tackform.com/collections...ices-6in-18-in |
12-02-2023, 07:56 AM | #75 | |
Rep 4,600
StanDiego6304.00 Wynnsiensheng900.50 |
12-02-2023, 01:57 PM | #76 | |
39
Rep 35
i've played around with phone charging too. i wanted to use the higher speed port under the arm rest, but ran into two issues. One, finding a one inch charging cord. Two, when setting the phone (iPhone 11 here) on it's side to fit it in the armrest slot, if you rest your arm, it will push the buttons on the phone in such a way as to disconnect your music and alert the iPhone SOS feature.... am guessing that's not what the SOS on iPhone is intended for. |
12-10-2023, 11:30 AM | #77 | |
Rep 28
12-11-2023, 05:53 AM | #78 | |
Rep 4,600
Thanks for the information! |
12-25-2023, 01:21 PM | #79 |
Rep 2
How do I remove this for replacement?
First time to post...just purchased my 2020 Z4 M40i about 2 weeks ago. I've already replaced mirror caps, kidney grills, and exhaust tips, but I want to replace the front bumper trim and can't figure out how to get them off...any help?
https://i.ebayimg.com/images/g/iwwAA...KK/s-l1600.jpg |
12-27-2023, 05:59 PM | #82 |
Darth ZEDer
6304
Rep 1,143
12-30-2023, 03:29 PM | #84 | |
522
Rep 320
12-30-2023, 03:30 PM | #85 |
522
Rep 320
12-30-2023, 05:49 PM | #86 |
Rep 4,600
12-30-2023, 08:07 PM | #87 |
Rep 895
Drives: BMW Z4 M40i, BMW X5x40i
I learned about it at the Performance Center. That's where they put the key fobs for the fleet. That way people can just get in the cars and drive and there's less likelihood they get misplaced.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
Westside Guy5970.50 stlcdr1025.00 |
01-12-2024, 06:25 PM | #88 |
¯\_(ツ)_/¯
760
Rep 393
Drives: '24 Z4 M40i
I want to drop in here and recommend the fitted "AutoTech Zone Sunshade" available on Amazon for under $35 shipped and which I think is pretty decent quality: https://www.amazon.com/dp/B09PJVXPT4
It also works nicely in conjunction with the FITCAMX dashcam recommended in this thread and which I just installed (I'll wait to see if it rattles) but would so far recommend as well. |
Wynnsiensheng900.50 StanDiego6304.00 |
Tags |
accessories, g29 |
