06-20-2023, 05:24 PM | #67 |
Rep 4,529
What spacers are you running on the rear axle with 10.5” wide et 46mm and 295/30 tyres ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-21-2023, 06:59 AM | #68 | ||
Rep 1,404
Oem suspension won't fit on gts knulckles. |
Bee Pee1787.50 |
06-23-2023, 02:23 PM | #69 |
Rep 1,404
gphung193.50 Philly_sweden653.00 |
07-04-2023, 03:19 PM | #71 |
Rep 1,404
07-04-2023, 06:44 PM | #72 | |
Remove Before Flight
6940
Rep 1,616
Specifically-- How do they mount? Do you drill into the bumper? Part numbers? Will they fit a M2C w/ no modification? I've been lacking on the car lately (too much else going on in life), so I'm not "up to speed" on this topic. TIA! R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
07-05-2023, 05:27 AM | #74 | ||
Rep 1,404
I didn't drill holes in the bumper, I cut the tabs and used zip ties. I had to make a few cuts with a cutter to insert these tabs, nothing more! Quote:
With coilovers you can use 15mm spacer and +-3.0° of negative camber. If u use regulable control arms you can go with less than 3° of negative camber. Yes Last edited by Track/S; 07-05-2023 at 05:38 AM.. |
07-07-2023, 03:06 PM | #75 |
Rep 435
Drives: F87 M2 DCT, F15 X5
Great thread, subscribed.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
07-07-2023, 04:53 PM | #76 |
Rep 1,404
07-07-2023, 09:03 PM | #77 |
3039
Rep 13,778
Man I put mesh grills on my Macan GTS and those guys on that side of the forum would be up in arms saying how much airflow restriction these probably add. What a nutty group.
~loud noises~
Kevin_The_Clean13433.50 D_SheerDrivingPleasure1106.00 |
07-08-2023, 06:12 AM | #78 |
Rep 928
Haha! Nutty is right . On Rennslist there is a discussion about possible engine wear caused by the poor air from the Canadian wild fires. One 992 owner won't start his car and he installed an air filtration system in his garage. A slightly less neurotic Porsche owner wrote that he won't exceed 4,000 rpm unless air quality index is below 125.
07-08-2023, 04:50 PM | #79 | |
3039
Rep 13,778
~loud noises~
07-09-2023, 08:54 AM | #80 | |
Rep 1,404
God level paranoia |
07-25-2023, 04:28 PM | #82 |
Rep 1,404
15
chris7197393.50 to_riffic3038.50 Fabb228.50 gphung193.50 Kevin_The_Clean13433.50 whoop_ass355.00 jason.seki55.50 CoffeeLife397.00 The_Werm214.00 Bee Pee1787.50 Distinct165.00 neonbrown274.50 aatlas214.50 dtmurf486.00 HomoPirate84.00 |
09-08-2023, 07:45 AM | #83 |
The Seeker
14199
Rep 3,426
My god this thread.
Your name should be The Solutionist. |
SYT_Shadow11517.00 |
09-08-2023, 02:14 PM | #86 |
///M Powered for Life
11517
Rep 10,345
I sent mine, he did a great job!
chris7197393.50 ///MPhatic14199.00 |
09-08-2023, 03:41 PM | #87 |
Rep 1,404
09-08-2023, 05:44 PM | #88 |
Rep 4,733
It's great to have someone out there thinking outside the box. Asking things like... Why do we need this, when we can do this?
It's been my belief from the beginning that the 2nh caliper is quite capable. Especially when paired with CCB. Now that it can be paired with a smaller more efficient iron rotor to run 18" wheels is great. Now if only the CCB rotors cost as much as the iron.
