      04-29-2023, 03:27 PM   #67
TurtleBoy
TurtleBoy's Avatar
17760
Drives: 2019 X5 40i,2021 M340i
Originally Posted by akin67 View Post
I understand that, but why have this requirement on US vehicles but not anywhere else in the world?
Most believe it is due to our longer battery warranty.
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
akin67470.00
      04-29-2023, 03:34 PM   #68
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
the U.S. DoE imparts a minimum 8y warranty on the HV battery (longer in CARB states). it is believed the reduction in usable capacity is to ensure the battery lasts that long (or even longer). to answer your question, it’s done similarly in the EU but their warranty length is shorter, so the reduction in usable capacity is not as much as the U.S.
in the case of the 45e with its 24kWh net battery capacity, usable capacity is reduced to 21.6kWh there compared to 17.1kWh in the U.S.
akin67470.00
      04-30-2023, 07:31 AM   #69
viperdoc
viperdoc's Avatar
369
Drives: X7/‘21 45e/‘23 45e
Just to chime in, as nZtiZia has mentioned, is it very important to have a 20amp circuit dedicated to charging if you want to charge the 45e overnight. I finally got tired of juggling where all my vehicles were parked overnight to share my Level 2 charger, so I purchased another Level 1 charger that could pull 16 amps for my 45e that is outside at night. Previously took about 18 hours to charge to full at 10amps. Now it finishes in 9 hours.
      04-30-2023, 07:56 AM   #70
nZtiZia
nZtiZia's Avatar
Originally Posted by RetSurfer View Post
As a comparison, I purchased a ChargePoint Home Flex, Level 2 up to 50 Amps. $750
Electrician to put a 50-amp double switch in one of my panels, run a wire around 50 feet using a direct connect to the CP. $750
I didn’t know before that the included charger line with my new 50e could be a level 2, (with whatever the cost of the of that was) but, to me, it wouldn’t have mattered.
So, $1500 total…
that’s a ding on your CA for not letting you know its charging capabilities. you could’ve saved $600
still, don’t forget you may qualify for a federal tax credit on your charging station (Form 8911) to include the EVSE plus installation labor come tax time next year. I believe it’s a 30% credit up to $1000, whichever’s less.
      04-30-2023, 08:47 AM   #71
javapro
Generalissimo
javapro's Avatar
Drives: 2024 iX xDrive50 Sport
Can any of the US 50e owners run the vehicle telematics report as per the steps below? I am afraid that BMW is screwing us in the US again by putting a lower limit on usable capacity just like on 45e to make sure the battery can withstand the 8 year warranty period.
1. Log into https://mygarage.bmwusa.com
2. Go to vehicle profile.
3. At the top menu choose CarData and “Request BMW CarData Report”.
4. It will take around 24 hours to get generated. Just check in the same place for your CarData report.
5. Usable battery capacity is under “Energy content of the high-voltage battery” in the main HTML file if the report.
Thank you.
      04-30-2023, 08:51 AM   #72
javapro
Generalissimo
javapro's Avatar
Originally Posted by fr_tz View Post
The 3hrs in 15min was displayed on the dash. See screenshot from app..car was at 0% and charged to 100% in 3 hrs 9 min. I started the car and confirmed it was at 100% after.
fr_tz, so did you get a chance to run the vehicle telematics report. You can follow the steps below.
5. Usable battery capacity is under “Energy content of the high-voltage battery” in the main HTML file in the report.
Thank you.
      04-30-2023, 08:56 AM   #73
nZtiZia
nZtiZia's Avatar
could EU-based 50e owners also run a telematics report as well (if capable), so we can determine if there is indeed a difference in country-specific usable capacities?
      04-30-2023, 09:00 AM   #74
javapro
Generalissimo
javapro's Avatar
Originally Posted by nZtiZia View Post
could EU-based 50e owners also run a telematics report as well (if capable), so we can determine if there is indeed a difference if usable capacities?
I don’t think anyone outside of the US got their 50e yet.
nZtiZia5606.00
      04-30-2023, 09:34 AM   #75
KT_OH
Drives: 2024 X5 xDrive 50e
with the X5 50e, a separate level 2 isn't required since it comes with the flexible fast charger that charges both level 1 (max 10A) and level 2 (max 40A), but the adapter to charge at level 2 is not included. someone just purchased it to the tune of $150 which is a lot cheaper than buying a standalone level 2 like a ChargePoint. if you had the 50e and purchased the level 2 adapter, you only would've spent $1350.
we 45e owners had no choice but to buy a separate level 2; i have the JuiceBox (two, actually)
Maybe lot of new 50e owners are buying the adapter. Out of stock - will see when it actually ships. No worries though, my production was pushed back too, so nothing but time and waiting...
      04-30-2023, 02:19 PM   #76
Pakoenig
Drives: X4 35,X5 4.6is,E46 M3,X5 50e
I went and bought a basic NEMA 14-50 plug based, 32A 240V EVSE on Amazon w a 2 yr warranty for a net price of under $200 so I could start charging right away. I expect dealer delivery this week - the car arrived at the Richmond, CA “port” on 4/28.
I’ll keep the BMW EVSE in the car as a backup and order the 240V cord - the NEMA 14-50 version, not the lower rated 240v cord.
Pissed about this since the standard equipment list for the 50e lists the Flexible Fast Charger as standard equipment, and all the online listings that BMW has list both level 1 and level 2 cords. So BMW created a hidden, crippled FFC for the 50e.
Class action ?
      04-30-2023, 06:22 PM   #77
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
I just ran it and will report back tomorrow. I can understand how some may be upset with this but we’re really enjoying this X5. Really pleased with it and the power is just tremendous.
nZtiZia5606.00
      04-30-2023, 07:19 PM   #78
jad03060
Drives: X5 45e
Batteries live and die by the number of cycles. One full cycle is from zero to 100%. If you can never fully deplete the battery because of the way things are programmed, each apparent cycle is less than a real one so it should last longer.
Since the US regulations require a vehicle HV battery to have a minimum life, to ensure that more reliably, BMW limits the actual capacity that is available. Europe tends to have a less stringent rule on battery life, if one exists, so it's safer to allow more of it as long as it lives past the warranty period, for the tradeoff of it typically not lasting as long.
      05-01-2023, 10:45 AM   #79
javapro
Generalissimo
javapro's Avatar
Thank you. Do let us know as soon as you get the report.
      05-01-2023, 01:06 PM   #80
mobsync
Drives: '24 X5 50e
I ran it and got the following-
"Energy content of the high-voltage battery" 20 kWh
      05-01-2023, 01:10 PM   #81
javapro
Generalissimo
javapro's Avatar
Thank you! That’s even lower than 21 kWh we estimated.
      05-01-2023, 05:37 PM   #82
Jongp3
32
Drives: M3
Anyone using a NEMA 14-30 24AMP plug?
My new construction condo has this connection. Looks like BMW has the adapter. Curious if anyone is using this can what the charge times are like?
https://www.ecstuning.com/b-genuine-.../61905a13a60/#
      05-01-2023, 06:05 PM   #83
nZtiZia
nZtiZia's Avatar
note that's the plug for a 30A circuit, so the max amps you can pull is 24A or approximately 5.8kW. divide that by ~22kW, you're looking at 3h48m charge time from 0-100% on a US 50e, BUT…
DO NOT USE THE INCLUDED FLEXIBLE FAST CHARGER ON THAT CIRCUIT unless you can limit its max amperage. it’s rated for 40A via level 2 and may draw 32A on a 24A circuit = risk for thermal event if the breaker doesn’t trip
      05-01-2023, 06:19 PM   #84
eelnoraa
Drives: G05 X5
But be very careful. The 50e flex EVSE will draw max 40A at L2 supply voltage, right? Even plug into 50e, it will dray to draw 32A, this will cause issue for your 30A peak/24A continuous circuit. Best case is it trips the breaker. Worst case, 32A is so marginally above 30A breaker, breaker doesn't get trip. Wire will get heat up enough cause more catastrophic issue. So don't use an EVSE with high max current capability than the circuit can supply.
2022 G05 B58/PHEV
+ a few very old BMWs
      05-01-2023, 06:24 PM   #85
TurtleBoy
TurtleBoy's Avatar
17760
If he sets the limit to be 24 he should be fine, right?
      05-01-2023, 06:53 PM   #86
eelnoraa
Drives: G05 X5
Yes, you are correct.
I briefly look at the manual of the flex EVSE, it seems only have only two options for current limit: max (40A), and 6A when limit is enabled. No intermediate setting. I could be wrong. Owner please chime in with correct information.
2022 G05 B58/PHEV
      05-01-2023, 06:55 PM   #87
TurtleBoy
TurtleBoy's Avatar
17760
I was referring to the iDrive setting figuring that if it was set to 24 then it shouldn't draw more than that even with the flex at 40A.
      05-01-2023, 07:19 PM   #88
jad03060
Drives: X5 45e
I'm assuming that the charging limit menu range has been expanded for the 50e versus the 45e, but the user's manual I've looked at does not indicate that fact. In the USA, on the 45e, that menu limit only works on SOME level 1 devices. Level 1 is not the same as a mode used elsewhere to differentiate the different charging modes.
So, am curious how the menu interacts with the flexible fast charger when attached to both 120 and 240vac circuits.
