| 03-13-2026, 01:46 PM | #67 | |
![]() 20
Rep 56
Drives: Current 2015 M3;Old 09M3, 04M3
I went with the 11mode since it’s a 5 minute install and only $200-300. There are others that charge $500+ and you have to wire in a box and splice the power or run a power wire to the battery- no thanks. Not sure how 11mode does it but it’s just an adapter cable - plug and play. |
PCar2Bcar152.00 |
| 03-13-2026, 02:32 PM | #68 | |
![]() 152
Rep 84
I am assuming at this point you have no need for the valve controller remote unless you decided to plug in the fuse again to get normal operation? |
| 03-13-2026, 09:20 PM | #69 | |
![]() ![]() 43
Rep 377
PCar2Bcar152.00 |
| 03-13-2026, 09:24 PM | #70 | |
![]() ![]() 43
Rep 377
| 03-15-2026, 11:39 AM | #71 |
![]() 20
Rep 56
After a week with the 11mode valve controller, I really like it and as valve controllers go, the 11mode is the best one - (best price and best product and easy install). Highly recommend the 11mode if you're going to get a valve controller. Not sure what tech the 11mode controller is, but it's very simple. Other valve controllers require a separate control box that needs to be powered by splicing into some factory wire harness.
| 03-22-2026, 04:05 PM | #72 | |
Rep 1,399
X5Mnwi48.00 |
| 03-24-2026, 10:51 AM | #74 |
Rep 1,399
I have a valve controller….cant you attach the controller, open the valves when car first starts? The sound difference is obvious which means you should be good to pull the fuse….does all that make sense?
| 03-24-2026, 11:00 AM | #75 |
![]() ![]() 43
Rep 377
Yes correct then you're good. Start the car, then press the remote to open the valves. Leave it running then pull the fuse and you're good to go they will stay open even when you turn the car off.
sharkymcpeterson1355.50 |
| 03-24-2026, 07:37 PM | #76 |
![]() 95
Rep 179
Drives: 2025 X6 M60i Isle of man green
Can you tell us exactly where fuse 203 is located? 2025 x6 m60i, Which fuse box exactly? TIA
bimmerdream78.00 |
| 03-28-2026, 10:33 AM | #77 |
![]() 152
Rep 84
Installed mine just now. On the m50i it makes a pretty decent difference. Can definitely hear it off the line a lot more prominently. Even in regular driving mode vs sport or sport plus. I am actually kind of worried about my mpg because I feel I am driving more "spirited" with the change in noise lol.
Going to try and pair to my mirror home link button so I don't have to fumble for the remote. |
X5Mnwi48.00 |
| 04-21-2026, 11:21 AM | #79 |
![]() 95
Rep 179
So I started mine up this morning, pressed the button I have programed into my mirror for the 11 mode to open the valves, you can positively hear the difference in the exhaust, then I went back and pulled the 203 fuse and then went for a drive. Shut the car off to run into a store and came back and started her up and sure enough the sound was the same. I no longer have to press any buttons or the remote and my exhaust is open at all times unless I put the fuse back in. Nice simple mod that actually works great!
| 04-21-2026, 07:28 PM | #80 |
![]() 275
Rep 76
Anyone having issues programming it to their Homelink? Can’t seem to get it to take. I have it in standby mode, press and hold the button until it’s blinking yellow, press the 11 mode button, Homelink button goes to solid green. But when I start up the car and press the Homelink button, I get nothing. Tried multiple times and won’t seem to work.
Open to any suggestions. TY! |
| 04-21-2026, 10:10 PM | #81 | |
61
Rep 48
| 04-22-2026, 01:45 PM | #83 | |
18
Rep 58
| 04-22-2026, 08:06 PM | #84 | |
![]() 95
Rep 179
| 04-23-2026, 05:18 AM | #85 | |
![]() 275
Rep 76
Yes, tried 1 button for on and 1 for off. I held the remote a couple of inches in front of the button. Hard to believe holding it under would make a difference but will give it a try. TY! |
| 04-23-2026, 05:19 AM | #86 | |
![]() 275
Rep 76
| 04-25-2026, 08:46 AM | #87 |
Rep 20
so do you remove them before you take it in for service, or is that not a concern? Whats the consensus on that? Im considering ordering these, but was curious if people take them off before taking to the dealership for service, or is it all good to leave them on for service appointments? i've read that it may be better to take off before service, but seems like a hassle to have to to do that. Just curious what you fine folks are doing?
| 04-25-2026, 09:41 AM | #88 |
![]() ![]() ![]() ![]() 557
Rep 757
Just placed an order, sounds like the best bang for your buck 1st step. Appreciate all the information provided in the thread.
2026 X6 M60i 2025 M240ix, 2022 M4 Comp X, 2021 M440ix, 2015 M235 - Sold |
| Bookmarks |
