      04-24-2023, 11:56 PM   #89
zztops
Drives: 2013 328i (N26) F30 M SPORT
Originally Posted by Wtfitzvi View Post
will that trigger any lights on the dash?
No lights on the dash
      04-25-2023, 01:34 PM   #90
Alan l.
Alan l.'s Avatar
5940
Drives: 2020 F95 X5M Competition
One thing about keeping the valves open all the time is your cold starts will be WAY louder this way. I have the Dahler exhaust valve controller and if i force the valves open during cold starts its easily 2-3x as loud.
      05-01-2023, 11:37 AM   #91
Alan l.
Alan l.'s Avatar
5940
Confirming that the Dinan Xpipe works with the Akra rear section perfectly. I'd say it increases the volume by 15-20% overall. Keeps the exotic tone but just more of it. Any competent shop can install this in under an hour and thats taking their time.
      05-01-2023, 11:42 AM   #92
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7319
Drives: Audi BMW Ferrari LR MB
Not sure if it is just the photo or if those clamps are so close together that it may cause some knocking or clanging.
      05-01-2023, 11:43 AM   #93
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
I thought the valves were open already on cold starts?
Please post sound clips
CURRENT: 97 E36 | 18 F80 Competition | 22 F90 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 23 Civic Type R
      05-01-2023, 11:47 AM   #94
Alan l.
Alan l.'s Avatar
5940
Its just the angle of the pic. part of why i took pics is to make sure I could review things like this afterwards.
      05-01-2023, 11:49 AM   #95
Alan l.
Alan l.'s Avatar
5940
I thought so too until i got the exhaust valve controller installed. If i press the open valve button during cold starts the volume increases by at least 50%
I'll try to get clips this weekend but the iphone never seems to capture it accurately.
Wtfitzvi930.50
      05-01-2023, 05:33 PM   #96
m-prsev
Drives: 2021 X5MC, 2021 X7M50i
Were there any issues tightening the clamp to the OEM secondary pipes?
      05-02-2023, 10:03 AM   #97
Alan l.
Alan l.'s Avatar
5940
No issues. At least i didn't see the mechanic struggle or spend extra time there.
m-prsev79.00
      06-08-2023, 11:13 PM   #98
-DB-
25
Drives: X5MC GT500 Z06 Zl1
Anyone have the size or good recommendation for replacement band clamps. The set for front and X connection are not great and have minor leaks. When really tightened down they either warp in odd way or the bolt heads bottom against the clamp side.
Could be way better from factory
      06-09-2023, 06:57 AM   #99
Alan l.
Alan l.'s Avatar
5940
Interesting. I would have to re-check mine. I do noticed that after installing i feel more "rumbling" inside my car while the car is idling.
      06-09-2023, 09:24 AM   #100
-DB-
25
Mainly when cold start, seems there is some pipe expansion. I replaced 2 of the bolt sets with flange one and its better but the metal of the band is touch low qual. Different levels of stretch across the whole set.
The rear connectors to the Stock exhaust seem fine, just the other 4
I am assuming a good set of 3.25 inch id or whatever the true dia is would work but was wondering if anyone had the actual dimensions before i remove it again.
Thoughts appreciated
      06-11-2023, 03:40 PM   #101
LukasAT
Drives: 2024 BMW X5M
you made a video of the sound?
      09-23-2023, 03:01 PM   #102
Crogalin
Crogalin's Avatar
Drives: 2022 BMW M4C
Any word on when this will be in stock?
      09-25-2023, 08:57 AM   #103
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Soonish (early October is my best guess). Waiting on a window for one of the tube benders to free up and tooling can be changed, etc.
      09-25-2023, 09:11 AM   #104
Hunter399
Hunter399's Avatar
338
Drives: F90M5
Any idea on when the LCI version will be released?
      09-25-2023, 09:22 AM   #105
Dinan_Engineering
Drives: Any BMW
Need an LCI in house before I could even hazard a guess.
      09-25-2023, 12:57 PM   #106
bellabimmer
Drives: BMW X5M F95
Did anyone tried Full decat both primary and secondary cats as downpipes + dinan Xpipe then other part of exhaust stock ?
I have Full decat + GPower exhaust which has a mid section with resonator but I get drone at low rpm in highway speeds so I am thinking in changing mid section with X-Pipe and rear end of exhaust stock exhaust so that way I get less drone and big noise since using XPIPE makes lots of difference.
      04-24-2024, 11:38 AM   #107
S68 X5MC
DD214
S68 X5MC's Avatar
Drives: 2024 X5M Competition
I know we spoke on coming up from Destin to you guys so we can test fit last year, but I just haven't had time to submit my vehicle to the cause.
Has anyone been there to test fit yet so we can see if the X-Pipe will work on the LCI? If not, I might just order and be the test dummy.
      04-24-2024, 11:49 AM   #108
Falcon900
Falcon900's Avatar
Drives: BMW X5M, M760, Alpina B7
Does this fit on the 2024 X5M Competition?
      04-24-2024, 12:05 PM   #109
Dinan_Engineering
Drives: Any BMW
Nope, no volunteers, so we ended up buying our own a couple weeks back.
Does not. Tis going to require a bit different pipe as the connection method to the DP's differs between the S63 (clamp) and S68 (gasket).
      04-26-2024, 09:50 AM   #110
S68 X5MC
DD214
S68 X5MC's Avatar
You wouldn't have a timeframe would you?
