      07-06-2024, 09:27 AM   #89
Marty in NY
Marty in NY's Avatar
Drives: 21 X5 40i, 18 GTi, Snowblower
Originally Posted by nZtiZia View Post
the phone widget on the home screen can verify you placed the phone properly on the tray as it will show a charging icon
Ha, it's a waste of time to use that charging pad, I gave up some time ago as even when properly placed it gets really hot while only adding about a 3% charge after an hour. I carry USB cables in the car, that works fine.
Appreciate 4
nZtiZia5526.50
eelnoraa2713.50
Cityman282.50
      07-06-2024, 11:07 AM   #90
JFS007
JFS007's Avatar
Drives: 2024 X5M
Originally Posted by jad03060 View Post
Unless it changed, the user’s manual says the maximum length is 6.1”, and the pro max is longer than that, especially if it’s in a case. I think it’s also wider than they say. This may result in the phone not being able to be properly centered on the charging coil, which will allow it to run hotter. The charger’s status LED should glow blue when it is properly positioned. The location of that LED can be hard to see depending on your height and seat position.
Could be - my build week is 37 so I have a while left before I get to try 😆
That said, it overheats on our other cars so I suspect that I would not use that charger regardless
      07-06-2024, 01:42 PM   #91
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
yeah I stopped using the charging tray 1.5 weeks into ownership. after almost 4 years, I’ve only used it for Digital Key purposes a handful of times. I was just pointing out one doesn’t need to contort to know when the phone is charging
      07-06-2024, 03:10 PM   #92
Marty in NY
Thanks, I didn't know that. Well, that'll be yet another feature I won't get to enjoy
nZtiZia5526.50
      10-06-2024, 01:22 PM   #93
WHATHISNAME
Drives: BMW G30 M550i
Great Wireless Microwave Charger
I have a 2018 G30 and an iPhone 14 pro, Samsung s21 ultra and a Samsung S20 ultra. When charged with the built in wireless charger they all will heat to the point of thermal shutdown. I've complained to BMW even writing letters to the BMW USA and the local dealer. I even left my phones with the dealer to test the charger with the zone rep present and was told that there was nothing wrong with the charger. So I did research and found that the charger had changed part numbers 3 times in 6 months at the time, so I bought the latest and replaced the charger myself to no avail. I just gave up and bought plugin chargers and the over heating problem was solved, reasoning that BMW is a great car manufacturer not so much with the phone charging. I haven't used my wireless charger since 2018, I believe that the heat will shorten the life of the phone battery.
To tell you the truth I'm kind of disappointed that several years on the same problem persist. I would love to hear the reasons behind the lack of attention to what should be an easy fix. Oh that's right there is no problem per BMW.
Cityman282.50
      10-06-2024, 04:41 PM   #94
Daveschally
Drives: BMW X5 2025 50e
Not sure if it’s related but my 15 plus Since the last iDrive update .40 phone doesn’t heat up like before. Still super slow charge though
      10-06-2024, 05:11 PM   #95
Snave01
Snave01's Avatar
421
Drives: ‘25 X5 40i
the wireless charging pad is 5W.
This explains why it charges so slowly and why I won't bother to use it. If I want the phone to be charging, I want it to actually charge. The heat buildup will damage the battery over time and for getting next to no charge is not worth it. I'll probably end up using a MagSafe charger mounted somewhere. Also, the USB A port located nearby is not going to charge very quickly either. When at all possible, choose a USB C port for the most power/fastest charging.
'25 X5 M40i Carbon Black Metallic / Silverstone
      10-06-2024, 06:13 PM   #96
Marty in NY
I bought this to plug into the cig lighter/power port, super low profile, quickly charges the phone.
.Name:  Screenshot 2024-10-06 at 5.38.18 PM.jpg
I can easily close the cover when nothing is plugged in.. ..
.Name:  USB copy.jpg
Cityman282.50
      10-06-2024, 08:02 PM   #97
Steeem
16
Drives: BMW X5 45e 2023
.Attachment 3570205
.Attachment 3570212
I see you still have a plastic film on your dash it's even on a volume knob?
On topic: What other uses do those charging trays get? I feel like it's a perfect space for the phone but then, like others, I don't want it to overheat.
      10-06-2024, 08:57 PM   #98
Marty in NY
No plastic film on anything, just a clean and glossy car :-) My sis-in-law made me a non conductive cover that I place on the built in charging pad so I can put my phone there without it trying to charge.
Steeem15.50
      10-06-2024, 09:21 PM   #99
CR290Guy
Drives: ‘25 X5, ‘22 Subie
Previous posters said it was CarPlay and Waze that caused the overheating while using the wireless charger. Well, it doesn’t get hot using those apps while using the cable to charge.
Mine shutdown on Friday after being on the charger. High temp warning. Guess I won’t be using it again.
      10-06-2024, 09:22 PM   #100
nZtiZia
nZtiZia's Avatar
I’ve been using a 15W MagSafe mounted charger plugged in via a USB C PD adapter since Dec 2020
iX nOOky182.50
      10-06-2024, 09:25 PM   #101
Marty in NY
It’s got nothing to do with any app on the phone. Mine over heated while it was in sleep mode without any apps running in the background
      10-06-2024, 09:34 PM   #102
nZtiZia
nZtiZia's Avatar
the wireless charging tray houses the NFC sensor for Digital Key use primarily for pre-LCI X5. LCI X5 feature Digital Key Plus that doesn’t require physically placing the phone on the tray, but it’s there as a backup for when UWB Digital Key Plus isn’t working or for the digital keycard
the wireless charging tray also couples with the LTE compensator to boost the mobile cellular signal which explains its high cost (most people think the wireless charger option is only the charger)
Steeem15.50
      10-06-2024, 09:39 PM   #103
nZtiZia
nZtiZia's Avatar
despite the majority having poor experiences with the wireless charger, there have been many users who could use it, but those who used Waze suddenly could not
      10-06-2024, 11:12 PM   #104
starlights
Drives: G05 50i
I had experimented with Apple MagSafe adapter in armrest with iPhone 12 mini and phone overheated when CarPlay was being used. That is what had me thinking that it’s the phone heat management issue when it loaded with running apps, gps and inductive charging rather than faulty BMW charger. Some phone models may be better at heat management due to more internal resources such as iPhone pro max. My iPhone has no issues when wired charging and CarPlay.
      10-07-2024, 02:41 AM   #105
driftkido
driftkido's Avatar
Indonesia
58
Drives: '24 X5 xDrive40i
My iphone is charged okay up to 80% if i use android auto, though it's getting quite hot. If you use carplay it will affect the phone temperature and stop charging to prevent overheating.
      10-07-2024, 07:34 AM   #106
biterror
Finland
570
Drives: X5 45e 2021
My OnePlus 9 Pro was charging ok (getting a bit warm, though), but my S24 Ultra does not charge, it just gets hot and slowly discharges even when running no apps on the phone.
      10-07-2024, 07:42 AM   #107
nZtiZia
nZtiZia's Avatar
the phone’s lack of adequate ventilation inside the armrest was the factor to overheating, not from CarPlay or running apps. the phone can manage the heat from wireless charging/apps, but you didn’t let it by placing it inside there
my MagSafe charger is mounted out in the open and I’ve had absolutely no issues with overheating while using CarPlay (almost 4 years with iPhone 10, 12 Pro, and 14 Pro and all with protective cases), and I always have at least eight apps open and running:
  • Messages
  • Phone
  • Facebook
  • Calendar
  • Safari
  • Spark (email)
  • Parcel
  • Apple Music
  • **Apple or Google Maps during long trips if not using BMW Navi (I don’t use Waze)
wired charging is definitely more efficient than wireless charging as you found out
      10-07-2024, 09:03 AM   #108
iX nOOky
Drives: 2019 Ford Edge ST, RX350
My 5 year old 2019 Ford charging pad gets warm, but works without issue. I suspect it's not hard to engineer a wireless charging pad in a vehicle, it just needs the power and probably a passive heat sink to help remove the heat of a phone charging in a tight enclosed space.
I bet many people have a case on their modern phone that interferes with the wireless charging function, but newer phones are so fragile that a case is almost mandatory.
As a poster said above, probably the best bet is an aftermarket 15 watt unit plugged into one of the cars higher wattage ports.
      10-07-2024, 09:42 AM   #109
biterror
Finland
570
Drives: X5 45e 2021
I remove the case before putting my phone in the charger, but it doesn't seem to help with S24.
      10-07-2024, 02:48 PM   #110
Cityman
Cityman's Avatar
Drives: 2024 BMW X5 M60i
My main beef with the system isn’t necessarily that it cooks the phone, but it cooks the phone and doesn’t charge worth a 💩. I think it charges less than 10% an hour. I just plug it in with a cable.
LDT2256.00
