01-08-2025, 03:12 PM | #90 |
Forced Induction Connoisseur
1309
Rep 973
Drives: 23 X5MC / 23 720s / 25 M4CS
Garage List 2025 M4 CS [0.00]
2023 BMW X3MC [0.00] 2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
That is super thin for stainless.
Oy vey, look at all these shekels
01-08-2025, 03:42 PM | #91 |
DD214
426
Rep 502
Says who?
Edit: Someone needs to measure the stock piping thickness. I'm curious what they put on these from factory. Last edited by S68 X5MC; 01-08-2025 at 03:55 PM.. |
01-09-2025, 02:48 PM | #95 |
DD214
426
Rep 502
Not sure what company's exhaust is made with aluminum. Either way, 1.3mm will do just fine considering it's harder than stock systems and .3mm difference.
01-09-2025, 02:58 PM | #96 | |
1309
Rep 973
As others have replied, typical thickness is 1.6mm or .0063" and using a heavier gauge metal generally reduces drone within the range our ears detect. This happens because thicker exhaust walls raise resonant frequencies shifting them higher on the spectrum and out of the drone generation trouble spots in the RPM band. For example, the exhaust on my x3m doesn't drone at all because it's thickwall and copied off a proven design. In short: Thicker metal = stiffer structure = higher natural frequencies. While the number of vibration modes stays the same, each mode occurs at a higher frequency. As a result, the resonance peaks move upward, reducing the likelihood of experiencing audible drone.
01-09-2025, 03:25 PM | #97 | |
DD214
426
Rep 502
Edit: I'm not going back and forth on this, it'll be just fine. Last edited by S68 X5MC; 01-09-2025 at 03:57 PM.. |
01-09-2025, 04:13 PM | #98 |
1309
Rep 973
I don't think I ever said thickness was the main or only factor. Both absolutely factor in. Why do most thinwall titanum exhausts sound higher pitched? Reason: Thinwall.
01-09-2025, 04:35 PM | #99 |
DD214
426
Rep 502
No, titanium exhaust tends to be thinner and smaller in diameter like Valvetronic. The stainless 80mm diameter with a 1.3mm thickness will be fine without drone. This isn't my first rodeo.
01-09-2025, 07:02 PM | #100 | |
1309
Rep 973
You are correct that most titanium exhausts are thinner wall, but you are correct that 80mm with a 1.3mm thickness will likely be fine even though it's a little thin.
01-09-2025, 07:03 PM | #101 | |
DD214
426
Rep 502
For anyone else buying. They have Chinese New Year coming up and production will take a bit longer. He estimates receiving my exhaust around February 20th. I can't complain when they're custom making these things for us. Last edited by S68 X5MC; 01-09-2025 at 07:04 PM.. |
01-09-2025, 07:07 PM | #102 | |
1309
Rep 973
In for results. Think it'll work with pre-lci or did they completely change everything? Haven't thrown a LCI on the lift to see if it looks different.
01-09-2025, 07:14 PM | #103 | |
DD214
426
Rep 502
Edit: I found something interesting and asking about it on this thread. https://g05.bimmerpost.com/forums/sh...&postcount=149 Last edited by S68 X5MC; 01-10-2025 at 10:13 AM.. |
