12-12-2023, 06:44 PM | #111 | |
13727
Rep 20,415
aussieintexas241.50 |
12-12-2023, 07:01 PM | #112 | |
Rep 3,761
Only two things are the same, right? Front subframe, and rear anti roll bar.
2022 G05 B58/PHEV
+ a few very old BMWs |
matowi372.50 |
12-12-2023, 07:10 PM | #114 | |
Rep 1,201
We arent talking something like the 03/04 cobras where they went from solid rear axles to IRS. This is more like, a revised set of sportier components. |
12-12-2023, 07:14 PM | #115 |
13727
Rep 20,415
That is correct, it is a B58 with 380hp and electric motor of 200hp. The good news is that combination will have been in the field for about three years (in the M760e and M560e) and so it shouldn't run into the problems that the 50e did.
12-12-2023, 08:19 PM | #116 | |
Rep 1,201
That said I did eventually come around to the Ford Ecoboost, and it has been overall acceptable in our Expedition. A PHEV version of that would be better (inteat drove a powerboost f150 and the mild hybrid really helped smooth out power delivery. It wasn't fast, but it also never felt sluggish. |
12-13-2023, 04:52 AM | #117 | |||
303
Rep 382
I was actually planning to go with the hopefully finally arriving iX5 but depending on the actual specs of the M60e it might be a close one. I'm not sure though BMW will actually do the M60e since it also opted to leave the "60" to only the i5 M60 on the G60 and do a 550e instead with the drivetrain of the X5 50e but smaller battery. Quote:
I think the V8 will suffer the same fate as the V12 did when V8's were able to produce V12 power. The development essentially stopped and it was only being built in small quantities for the sake of being a V12 like the 65 AMG with the old 5 speed gearbox for a while and then faded away. Looking at the S58 being able to produce V8 numbers on stock internals/turbos (700hp+) with better fuel economy and less weight than a V8 I don't see a bright future for V8's. Last edited by SwissBeemer; 12-13-2023 at 05:05 AM.. |
12-13-2023, 09:18 AM | #118 |
1229
Rep 1,350
I love V8s, always have and probably always will and could care less whether Europeans favor them or not but was totally sold on the BMW S58 I6 when I drove an M4 Comp not to long ago. Absolutely awesome, wicked car.
12-13-2023, 09:33 AM | #119 | |
13727
Rep 20,415
Looks like you have some bad information. They are using the M 60e moniker for the top model PHEV models for the G60 and G70 with the M560e and M760e. That is the drivetrain that will be in the X5 M60e.
12-13-2023, 10:03 AM | #120 | ||
303
Rep 382
12-13-2023, 10:39 AM | #121 |
Rep 1,201
The problem with losing V8s and v12s is less tondo with output, and more to do with desires. Nobody buys a 7 series as a choice based on needs. You buy it because it's an emotional splurge. If your splurge doesn't feel more special, why splurge?
People don't like being forced into a downsized motor. People buying a $100k vehicle can and will eat the fuel cost for a better experience. The automakers are all learning that Americans won't pay more for products that feel objectively less. Dropping the v12 was a mistake for BMW. Dropping the V8 would be an even bigger mistake. Look at the utter failure of the new C63. It makes big power, but it's a total colossal failure because they didn't get that buyers don't want a turbo 4 and an electric motor, regardless of how fast it is. They want the big V8 making rowdy sounds. All the electric vehicles (except for the very cheap priced Teslas) are failing too, because it's not what consumers want. Automakers are learning the hard way they service the market, consumers set demand. They have been thinking they can set the market with what they offer, and it's a failing proposition. |
matowi372.50 |
12-13-2023, 10:44 AM | #122 | |
Rep 3,761
Now in practice, the technique of balancing piston is mature. Everyone knows how to do it (maybe except bmw with their n20). You see many high rev, 8000+ engines are inline4, v8, v10. The balance talk is abut over blown. The real advantage of inline configuration is really cost of manufacturing: One head, one set of valav chain, one set of cam, one intake exhaust manifold, one set of cat, o2 management, …. 2x of all of these on a V. The disadvantage is packaging. Block is long, basically eliminating the possibility of FWD. I also think the recent adaptation of inline 6 by MB and Mazda is about the simple turbo implementation
2022 G05 B58/PHEV
12-13-2023, 10:49 AM | #123 | |
Rep 1,201
That's a big reason Stellantis is switching to an I6, it leaves the door.open for them to pivot back to a V8 if sales don't meet expectations. |
12-13-2023, 10:55 AM | #124 | |
13727
Rep 20,415
I was referring to what you posted regarding the G60 not having an M60e.
12-13-2023, 11:23 AM | #125 |
Rep 3,761
Yep, if inline6 fit V8 will fit. Plenty of e46 have LS retrofit into it. Monster track car. Will give M3 a run for the money. Will even smoke x5m after 5 laps. Lol.
2022 G05 B58/PHEV
12-14-2023, 10:16 AM | #126 | |
1229
Rep 1,350
The M60i is showing identical acceleration(0-60) as the pre LCI X5M @ 3.5 seconds. This test was also done at a horrible 6,000 ft DA which would reduce the turbocharged M60i's power by 9%(18% for a NA motor). Obviously there is a huge difference in acceleration between the M60i and 50e and not a "very close" comparisson as some guys here would like to believe. 3.3 is a real possibelity at sea level in good air. Last edited by cobramite; 12-14-2023 at 10:31 AM.. |
12-14-2023, 10:52 AM | #127 |
Rep 447
Drives: '24 X5 M60i
Question is if acceleration times are a good measure of the actual technical differences between the M and the M60i
From this thread (and others) I take away that there’s a number of changes across the entire underbody (subframes), suspension components, gearbox, x-drive, engine and turbos, body frame bracing, exhaust, etc They may be minor when viewed in isolation (a tweak here and there), but add up to a difference making the entire package rather significantly different in overall feel (rigidity, stiffness). What’s „big” to some may be „negligible” to others
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d |
hiluca69.50 |
12-14-2023, 12:09 PM | #128 |
254
Rep 320
Numbers are awesome (and make me happy as M60i owner) but let's not kid ourselves - M is not simply higher HP and TRQ numbers. Handling, steering, cooling, exhaust and so on. Extra 25-30 thousand for "M" get you much more than simply drag race numbers.
Still smiling looking at numbers. |
hiluca69.50 |
12-14-2023, 12:13 PM | #129 | |
Rep 1,201
I'm a big "driving engagement" guy. I think that electrification has make acceleration a sort of pointless measure. You can get Kias in the 4 seconds range, let alone the cheap garbage Teslas. It's no longer special to hit 60 really fast, what's special is building a compelling product that pulls you in and makes you want to drive and enjoy it. The problem is that engagement and fun often go down as max performance goes up. At some point you're making the ride too stiff for max g forces, the grip becomes too much to be fun, you end up with a car that is so capable, it's not fun at normal speeds, around town, etc. The most fun car I've ever driven was a 2013 Mustang Boss 302. It wasn't the fastest car, but it was loud, had super short gears, and just wanted to do burnouts and be sideways. The most fun car I've ever owned was an R53 Mini Cooper, the supercharged one. It was not fast, and didn't even handle that amazing. But it felt quick, was super light on its feet, and was a blast to drive everywhere because it had a ton of character and transmitted all the feelings to you. Stomp the gas and IT FELT like you were accelerating hard, you weren't, but it made you feel like you were. Go around a turn and it felt like it was glued to the road and you were driving like a hero, in truth you were only going slightly above normal speeds, but it felt.like you were a race car driver. All this to say, I don't know that the extras of the full M make it better. The majority of reviewers don't seem to think so, and some of them even go so far as to say that the difference is so small that the only reason to go full M is if you just want to show that you spent the extra money. I think that's probably a bit of a stretch, but I bet a good driver in a M50 or M60 could beat an average driver in a full M around a track. |
12-14-2023, 12:55 PM | #130 | |
Rep 886
Pretty sure both of my current BMWs have launch control, but I've never tried it.
M3 - X5 - 911 - Miata - Raptor - Edge
12-14-2023, 01:45 PM | #131 |
1229
Rep 1,350
Yeah, looks like the M60i is a tick faster than a C6 Z06 and not far off the mark of a C7 Z06 at least to 60, crazy for a 5300 lb SUV to be in the middle of that pair.
12-14-2023, 02:01 PM | #132 |
13727
Rep 20,415
Likely is a stretch depending on the course and the drivers. Look at the cars that the current X5M has outdone in the Lightning Lap. It is an SUV that handles better than many cars you would think would blow it away.
