Closed Thread
      06-09-2015, 07:01 PM   #111
The Wind Breezes
913
Drives: 135i N55 DCT
I hate to break it to everyone in this 5 star thread but the ENTIRE point of a heads up display is it's collimated or focused to infinity. This way your eyes don't need to change focus between looking at the road and the display.
In other words, this product is a crappy gimmick.
      06-09-2015, 07:09 PM   #112
Artemis
Moderator
Artemis's Avatar
30017
Drives: BMW M2C - BMW X1
Actually, you would be surprised to know what your eyes are capable of 'seeing' - blurred or not - when focused on the road.
Ain't the same as taking your eyes off the road to focus on the instruments panel.
///M is art Artemis
      06-09-2015, 10:52 PM   #113
bimmer_yu
Drives: BMW F10 520d + BMW E89 35i
Originally Posted by david51 View Post
hello
I installed and adapted my BMW F30
What is this rubber cover that you have used to hide the device?
      06-10-2015, 03:27 AM   #114
Waspo
Waspo's Avatar
England
94
Drives: E90 330i M Sport, Silver
you CAN, if you require, place this behind the screen to give you a brighter display but it negates the effect of seeing through it like a HUD should be! Can't see why you would use it!
I had to use mine as my display gradually began to fade and eventually disappear, but i had a faulty unit which is another thread!!!
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you"
      06-10-2015, 03:29 AM   #115
bimmer_yu
Originally Posted by Artemis View Post
Hm, as soon as you fold/incline the screen of this device towards you in a ± 35° angle, the screen cuts out. And that's on purpose: if you want the display to stop (showing info), just turn the screen down - if you fold it upwards again, it resumes after a second or two. So don't count on projecting info on the screen. If you put it at an angle just before the screen cuts out, you may see some info on the windscreen, true, but barely + in mirror writing.
Depends on a car's dashboard - in F10 there is some space (see my pics above) but agree that half closed + windshield sticker (couple of bucks at eBay) is too much hassle...
I am more interested in this rubber/plastic cover posted in this thread - something like that would make perfect fit for F10. Strange that BMW didn't come with factory adapters for dashboards espec. as this accessory is not cheap...
      06-10-2015, 03:32 AM   #116
bimmer_yu
I am not talking about this small rubber display cover that comes with display (I have it too somewhere in my car ) but if you look at david51's F30 pics more carefully you will notice that whole device is hiden under "plastic/rubber plate" on the top of his F30 dashboard... Looks quite good.
      06-10-2015, 03:49 AM   #117
Waspo
Waspo's Avatar
England
94
hi Waspo
I think your problem is the layer of the screen is wrong fix
Hi David,
Can you elaborate please? Bear in mind that i am not an electronics expert?
Thank you
Steve
PS. I love what you have done with your HUD unit? will you Market that idea and build one for my E90?
      06-10-2015, 04:02 AM   #118
Waspo
Waspo's Avatar
England
94
This of course is 'In Your Opinion'. in other eyes, it is a 'GOOD' Gimmick!!
      06-10-2015, 06:45 AM   #119
Peter_R
Air Vice Marshall
Peter_R's Avatar
United Kingdom
256
Drives: X1 LCI xDrive 2.0i M Sport
Yes so am I. I have an X3 (F25) and looking into hiding it in such way as it to not look too much like an aftermarket piece of kit.
Could you advise readers where it came from. Looks as though some thought has gone into producing it. Perhaps some kind of kit that can be adapted for any car/application.
2007 BMW 325d M Sport remapped (E91).
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-10-2015, 09:24 AM   #120
2HIGH~PSI
2HIGH~PSI's Avatar
164
Drives: '94 Supra TT 6MT, '15 MW M4
I do not understand your question
In this picture... The entire thing looks black, and not transparent?
And at that point, why not just look at your speedo as this appear to obstruct the view of the road...
      06-10-2015, 10:12 AM   #121
david51
david51's Avatar
France
542
Drives: bmw M3 F80
hello
To support the head-up:
I bought the original media at bmw (piece # 3 on image)
référence bmw 51459239336
I cut my dashboard(it is best to stick to the overly complicated dashboard cut)
setting good position head-node and after I have everything covered in black
leatherette
      06-10-2015, 10:24 AM   #122
david51
david51's Avatar
France
542
Drives: bmw M3 F80
Here are pictures of leatherette
      06-10-2015, 10:41 AM   #123
david51
david51's Avatar
France
542
Drives: bmw M3 F80
Hi David,
Thank you
Steve
hello
you must remove the piece and put in a good position the web (black circle in the picture)
To remove the water, it must lift the clip brown up and return in good position
I can not give you because we need your support to have a BMW E90 in order to position the head up
      06-10-2015, 10:43 AM   #124
david51
david51's Avatar
France
542
Drives: bmw M3 F80
hello
leatherette
      06-10-2015, 12:02 PM   #125
The Wind Breezes
913
No. I've used an actual HUD. There is no comparison. This is a cheap substitute with completely inferior functionality.
      06-10-2015, 12:27 PM   #126
david51
david51's Avatar
France
542
Drives: bmw M3 F80
Are you sure?
there is t he torque and indicated power, signaling speed signs, the location of speed cameras, fuel reserve?
      06-15-2015, 02:11 AM   #127
eeghie
Kind of a big deal
301
Drives: an 1M not often enough
Great job, you've elevated aftermarket install to OEM level.
Where did you get the leatherette from?
      06-15-2015, 05:42 AM   #128
david51
david51's Avatar
France
542
Drives: bmw M3 F80
hello
I bought the leatherette to a specialist in my area I found another model of imitation leatherette that looks more like the dashboard and better
      06-21-2015, 08:32 AM   #129
eeghie
Kind of a big deal
301
hello
That seems like an even better match indeed. Would you mind sharing the name of the store and provide details of the product (name/type/manufacturer etc)?
      06-21-2015, 05:04 PM   #130
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
I see real danger out there in our California roadways that many might not be experiencing in other parts of the world were people take pride in driving as a skill. The last thing people need is one more distraction or thing to look at. People here in SoCal are not paying attention to the road. I think it's especially disturbing at night where BMW has sold out from the awesome red backlit E46 night vision displays to the trendy bright hues with a bright lcd on top of the dash and now another gadget on top of the dash.
Paying attention to what is going on outside is the real need these days in my humble opinion, much more than more data and blinking lights and menus on the screen.
I was at the San Diego aerospace museum a couple of days ago with my kids showing them the cockpit of the Spirit of St. Louis. This guy crossed the Atlantic Ocean alone with these instruments.
Just a thought!
      06-21-2015, 09:18 PM   #131
david51
david51's Avatar
France
542
Drives: bmw M3 F80
Hello
Here the reference of leatherette
ref: Valencia 107-9035 Schwarz
http://www.spradling.eu/patterns.asp?Pattern=Valencia#
      06-28-2015, 04:46 PM   #132
Rejohn
Drives: X1
I had one retrofitted to my x1 but sadly it doesn't work. Will have to take my car back to check connection
Closed Thread
