      04-02-2021, 12:15 PM   #111
redbullfan
redbullfan's Avatar
374
Drives: 22 TR X3MC
2022 BMW X3MC  [0.00]
Originally Posted by Abhi_b View Post
Got Bimmerlink opened the valve removed the fuse 203 and guess what absolute waste of time, money and effort �� It works yes flap stayed open but barely any noticeable difference in sound forget pops or bangs on the contrary the nice blip blip which I used to get on launch when gears changed is gone the fuse is going back in tomorrow. Please save yourself the effort if like mine you own the X5 40i M sport My2021. Cheers
Originally Posted by LexxM3 View Post
Contrary, many others, including myself, have noted significant improvement in exhaust sound with flap permanently open (but it is, of course, not even close to a full exhaust overhaul, it would be silly to expect otherwise). If it didn't work as expected for you, it would be more prudent for you to question and investigate that rather than making an arrogant recommendation based on your rather limited experience. It's possible that there are changes in MY2021 or in recent software that have an effect. Or the comparative test environment is unlike most others (it may be a difference in engine or environment temperatures, or I'll note that sound improvement is more pronounced when starting and driving in Sport+ mode). A little humility is in order ...
I can vouch for Abhi_b on this, It doesn't sound louder for MY2021 cars. MY2021 is in fact quieter then previous model years so if you have a MY2021 don't waste your time or money doing this.
2022 X3M Comp
2013 335i xDrive (Sold)
      04-02-2021, 12:19 PM   #112
DCC
Drives:
My 2020 is noticeably lounder with the flap open.
But you might be right about 2021 cars. They tinkered around with these cars so much there is no telling what changed.
I actually don't do it so much for the sound but more for seeing exhaust coming out both tips vs one side only LOL
      04-02-2021, 12:24 PM   #113
redbullfan
redbullfan's Avatar
374
Drives: 22 TR X3MC
It has a lot to do with the BS Mild hybrid system
2022 X3M Comp
      04-02-2021, 02:24 PM   #114
LexxM3
LexxM3's Avatar
1765
Drives: E46M3, G05X5
2019 X5  [10.00]
Ok, that's interesting (that MY2021 exhaust behaves quieter even with flap open than previous MYs). How about further experiments to fully qualify? With flap open, what if you start and drive in Sport+ mode? Any difference if car is cold versus already warm? Any difference dependent on ambient temperature?
By the way, it's not that I don't believe the reports. What I don't like is the immediate jump to conclusion and blanket advice for everyone to give up. If it has been fully qualified, then that may be good advice, but the posts so far are shallow on the experimental results.
      04-03-2021, 05:42 PM   #115
redbullfan
redbullfan's Avatar
374
Drives: 22 TR X3MC
There's no experimenting needed, I've owned the car for 6 months and have tried it all.
Also I can assure you the car sounds quieter then this and doesn't make the same brap sound between shifts.
2022 X3M Comp
GordoCLM292.50
      09-28-2021, 09:48 PM   #116
Dhillon63
Dhillon63's Avatar
144
Drives: 2022 X5 M50i
Reviving this thread...
Did a straight pipe in place of my resonator on my 2022 M50i. Then I learned the flaps are always closed lower than a certain RPM. I ordered a bluetooth OBD2 scanner that I'll pair with bimmerlink.
My question is...once I open the flaps using bimmerlink and pull the fuse the flaps stay open permanently? I can pull the scanner and put it away?
Also, when the fuse is put back in will valves revert to auto or I will have to connect obd2?
      03-15-2022, 02:31 PM   #117
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
Bringing this back…
Has anyone tried this method with the F95? I’ve tried searching the forums but couldn’t come up with anything.
Is the fuse location the same across all X5 models?
CURRENT: 97 E36 | 18 F80 Competition | 22 F90 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 23 Civic Type R
      03-17-2022, 12:01 AM   #118
elite-fusion
Drives: 335xi
can this be done on the 2019 X5 xDrive50i? I opened the flap today via BimmerLink app, and i heard it open, but I do NOT hear much of a difference. What am I missing?
      03-17-2022, 12:39 AM   #119
AlpineG05
hi
AlpineG05's Avatar
231
Drives: Alpine White G80 Comp
Open the valve then disconnect cable. The valve will remain open permanently.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit
      01-18-2023, 01:51 PM   #120
MattTheCarNut
MattTheCarNut's Avatar
Drives: 2023 G05
Just completed the mod on my ‘23 40i. Wait for the revs at the end. Not bad!
https://youtube.com/shorts/fyqv5XKKd5s?feature=share
2023 G05 Phytonic Blue/Cognac, M Sport, Prem Pkg, Parking Assistance Pkg, 22", M-sport red brakes, heated armrests, 4zone climate, HK, extended shadowline
      09-15-2023, 01:58 PM   #121
TomiOmni
Drives: X5
Just in case anyone else searches like I did, and did not get a clear statement ...
2023 x5 4.0, when turned off, valve is OPEN, thus pulling fuse keeps it open, sound is "better" when starting and in certain situations, but not annoying. Will keep it open.
Tom
LuckyBrand1772.50
      09-17-2023, 05:12 AM   #122
wardy007
20
Drives: M3 F80, X3 M40I, X5 M60I
WOW.. 40I sounds better that the M60I... astonishing!
      03-24-2024, 11:51 PM   #123
gunnergahr
Drives: BMW E60
Originally Posted by jad03060 View Post
FWIW, in the US, making changes to the emission controls can get you into trouble. The flap is there to help the vehicle warm up quicker by getting the catalytic converter up to temperature faster. In the meantime, you're going to be spewing more emissions than you should. All this for a little cold start improvement in sound?
No trouble at all. We don't have emissions guy running around to take readings.
      03-25-2024, 04:47 PM   #124
poison
Drives: 2024 X6
Couldn't one put the car on sport plus to open the flap, then pull the plug, so as to not require an OBD2 tool?
      03-26-2024, 12:15 PM   #125
Sevn86
Sevn86's Avatar
Drives: BMW X5 sDrive40i Msport
Correct! Thats how I plan to do mine once the car gets here.
      04-16-2024, 02:34 PM   #126
xxx5phev
Drives: 2024 X5 PHEV
I might be missing something here but why wouldn't you just always run the car in sport mode vs unplugging anything?
      04-16-2024, 06:50 PM   #127
Sevn86
Sevn86's Avatar
It’s so you can have a louder exhaust note in comfort mode vs always having to drive it in sport mode.
I ended up removing the device that operates the flap and zip tying the flap in the open position.
Current - 2025 X5 sDrive40i M Sport
Current - 2023 Lexus RX350 F Sport
Sold - 2023 Rivian R1S Launch Edition
Sold - 2018 Range Rover Sport HSE
Sold - 2017 Lexus RX350 Luxury Pkg
Appreciate 3
      12-05-2024, 01:00 PM   #128
baadsha88
Drives: BMW X5
does this make a difference in a 2022 40i? or does that fall under the MY21 updates? also, any difference between pulling the fuse and pulling the cable under the car?
