12-14-2020, 12:12 PM | #111 | |
200
Rep 353
To go from 110 to 220, you will have to replace the wiring and put in a dedicated circuit. You can't just change the socket. Then, yes you will need a different charger than the one that comes with the vehicle. |
IS350118.00 |
12-26-2020, 03:15 PM | #112 |
Rep 8,887
Drives: eVeRyOnE mAD!
great thread! i just picked up my 45e a week ago. my electrician will install a NEMA 14-50 outlet in my garage next week.
i almost went with the Tesla Gen 3 but decided against a hardwired setup. i went with this charger through Clipper Creek. i was impressed with their reviews on quality, customer service and tech support. they're based in CA. https://store.clippercreek.com/amazi...2014-50%20plug |
silverstar335503.00 |
12-26-2020, 03:58 PM | #113 |
Rep 537
I started this when we were getting ready for our x5 and I completed our home setup with Juice 40A WiFi charger. So far works fine, too much intelligence we need at this time but may be useful in the future. I usually overspend (like majority of BMW owners I guess?) so hopefully it will serve us for another EV in the future.
12-26-2020, 04:46 PM | #114 | |
Rep 6,946
Or buy the connector and a hunk of appropriately sized cable. THat CC unit whether wired or plug-in is identical, they just added the plug, |
nZtiZia4766.00 |
08-22-2021, 08:08 PM | #117 |
Rep 8,887
the MyBMW app Charging History fails so often. anyone else? that makes 3 sessions this week alone. my biggest pet peeve is that i won't see today's charging session(s) data until tomorrow.
i installed and connected a new EVSE by emporia. this is their first residential EVSE, but they've already established themselves in the electric utility arena with their other products for electric monitoring/management, so their app already had some good data to look at while charging...real-time charging data, too! time will tell its durability, but the customer support response to questions has already been off-the-chain. https://shop.emporiaenergy.com/ |
09-17-2021, 05:30 AM | #118 |
Rep 2
Good Morning,
I live in Houston and have owned an X5 45e for about 8 months now. By year end, I will be relocating to Belgium and I plan to ship my X5 with me (I will have no import tax). I am fully aware of all the limitations regarding Nav, ConnectedDrive, radio frequency, and hassles to get the car up to EU road standards (conversion). I am actively working on that. This post is specifically about the possibility to recharge my X5 45e by plugging into EU electric outlet. My car has a MALE J-1772 plug. From looking last time I was traveling to Belgium, the most common is for EV charger cable coming off wall charger to be with FEMALE MENNEKES. So digging on the internet, I finally found on Amazon UK the correct cable for this: that is a cable with FEMALE J-1772 on one end (will connect to my car) and MALE MENNEKES on the other end (will connect to the standard EU Female Mennekes outlet). The cable is around £100, not a big deal: https://www.amazon.co.uk/gp/aw/d/B07...X7X7p13NParams So this should resolve the plug compatibility issue. Could someone please indicate if this will work, or if my US-Spec X5 internal charger, for whatever reason, may NOT recharge on EU electric network? What this new cable resolves is geometrical compatibility between the US/EU plugs. I want to know if there may be a more profound problem of internal charger compatibility, or if those chargers are the same on X5 45e US-spec vs EU-spec. This is very important for me to verify, as I am working to resolve all these issues ahead of my relocation to Belgium. |
09-17-2021, 08:23 AM | #119 |
Rep 3,826
Can anyone recommend a good level 2 charger that meets this criteria?
- 40-50a (knowing the 45e only charges at a max 16a, I want to futureproof a bit) - Reputable brand - Clean lines, doesn't look cheesy when wall mounted - App functionality, but not too reliant on the app for basic functionality I'm coming into this tech completely blind, not knowing the first thing about reputable charger brands. Considering Juicebox, ChargePoint, Grizzl-e, and Wallbox at the moment. As with many tech products, many have 4.5/5 stars, but the negative reviews are very concerning, like firmware updates breaking the whole thing (in the case of the Juicebox) and the app being terrible. I just want a basic charger that looks good in the garage and will give me a basic, functional app. |
09-17-2021, 09:05 AM | #120 |
Rep 8,887
a new kid on the block (though not new to electric monitoring) is emporia. I like it and its companion app and used mine only twice (already boxed) but I switched to one offered through my electric utility company with their incentive program. PM if interested; it's essentially new.
09-17-2021, 07:19 PM | #121 | |
Rep 6,946
Any time you introduce more parts in the path, there's the possibility of failures, but the 16A maximum charging rate on the X5 may not be stressing things very much. Reprogramming the radio head system to use the different FM channel spacing might be tricky, but should be possible. Getting the nav maps changed could be problematic, but should be possible...just bureaucratically messy. Probably have to essentially pay for a new license. |
09-17-2021, 07:26 PM | #122 | |
Rep 6,946
09-18-2021, 05:33 PM | #123 |
25
Rep 37
I ended up going with a JuiceBox 40a plugin, so I could future-proof my work should I want another type of charger or take it with me when I move. I was compelled to buy it because I went to my power company's website to find out about any sort of rebate or connectivity. They support a few, ChargePoint being another. I'd think folks in the market for one would check power company first, as I got enough to cover the cost of the thing by identifying it on their grid so they can throttle it back on higher demand days. I went through the summer and noticed not a thing. Highly recommend the JuiceBox, and pairing it with the power company. I mounted it outside, on the side of the house at the driveway. the thing is mint and it's seen the full spectrum of weather. /endorse
View post on imgur.com |
nZtiZia4766.00 |
09-18-2021, 09:17 PM | #124 |
Rep 8,887
do you use Dominion? Dominion Virginia also sponsors these two EVSE. i'm considering the JB and will link with Dominion's demand program. currently waiting on them to validate my account so i can purchase it.
09-18-2021, 10:56 PM | #125 | |
Rep 203
09-19-2021, 02:07 AM | #126 |
Rep 6,946
An EVSE derates the circuit it's installed in to 80% max, so that's why a 40A circuit goes to a max 32; a 50A to 40A; and a 60A one to 48A...right now there's an upper limit on EVSE level 2 charging, so larger won't buy you much if you can find one. I don't see a CCS unit becoming a typical homeowner install primarily because of the cost and that's if your power company would even consider providing enough power in a typical residential neighborhood. There are ways to store power over time until you plug the vehicle in, but that also adds to the overall costs to implement a CCS unit.
09-19-2021, 06:57 AM | #127 | |
25
Rep 37
I had to do the same thing with Eversource - wait for them to validate before I bought. This isn’t an automated part of their business. I got an email from an actual person at the company when they pinged my device and got it up and running. Nice check showed up a couple days later. I’ve been pleased with the process despite the back and forth. It’s been seamless since activation. I don’t even think about it at all. Good luck! Last edited by bigeks357; 09-19-2021 at 08:58 AM.. |
nZtiZia4766.00 |
02-04-2022, 12:30 PM | #128 |
Rep 71
Wallbox Pulsar Plus 40A
Anyone installed a Wallbox Pulsar Plus to charge their 45e? How is it? Any issues?
https://wallbox.com/en_us/types-electric-car-chargers |
02-05-2022, 07:55 AM | #129 |
Rep 3
Wallbox Pulsar Plus
Had a WallBox Pulsar Plus (40A) installed a couple of months ago; hardwired on a 60A circuit. Just picked up our 45e about 2 weeks ago. Thus far, we are pleased with the WallBox EVSE. Does what it is supposed to do and the included App seems to work well. No problems to date, although we have not yet been using it for very long.
02-07-2022, 05:30 PM | #131 |
Rep 3
Level 2 bad for the battery?
We just bought a wall box level 2 charger for our 2022 X5. Someone told my wife that using a level 2 charger all the time will destroy the battery. Problem is that using the level 1 charger takes over 24hours to recharge from zero to full so that is not sustainable. Any ideas?
