03-05-2023, 07:47 PM | #111 |
Rep 2,091
Yes, there is enough room for 4.5 and No, 4 aren't any tight in there.
03-08-2023, 08:28 AM | #113 | |
Rep 526
One thing that bugs me from the back of the M50i is the large muffler unit. |
Anders R52.50 |
03-22-2023, 10:58 AM | #115 |
Rep 2,091
03-22-2023, 11:05 AM | #116 | |
Rep 608
How secure would you say these hold from you experience? |
03-22-2023, 12:25 PM | #117 |
Rep 2,091
I do have the stock exhaust but this is not a just bolt on application. In post #91 is what I did to make it work on any 4" tips. I had to cut and weld then weld the tips also.
03-23-2023, 09:54 PM | #118 | |
Rep 10
03-23-2023, 10:09 PM | #119 | |
Rep 10
Im going to use the same style but will cut off the winglets and sand smooth then reapaint. |
03-24-2023, 09:35 AM | #120 | |
Rep 2,091
https://ikonmotorsports.com/products...er-abs-pp-3pcs
03-24-2023, 03:14 PM | #121 | |
Rep 10
Does the top part of the inner section mount with tabs? And do you need to use 3m tape on tthat section? I ask because i have tow package. My hope is that the center piece fits over the tow hitch and when i want to use it i can just remove the panel. |
03-27-2023, 10:57 AM | #122 | |
Rep 2,091
08-07-2023, 03:18 PM | #123 |
Rep 452
I installed the following tips from Amazon on my XLine 50i and they fit perfectly without any modifications or cutting. Additionally since the tips are straight cut and not diagonal at the end, there was no need to adjust for evenness. The upper lip of the rectangular trim holds them in place firmly to avoid falling off if the upper part is slightly recessed into the trim. YMMV on M models.
https://www.amazon.com/gp/product/B0757K9KZM It was a 2 minute install on all 4 tips. Last edited by starlights; 08-15-2023 at 08:01 AM.. |
LDT1620.50 |
11-06-2023, 08:54 PM | #124 |
Rep 2
Great mod. The exhaust looks finished now. Before it looked like BMW forgot to put exhaust tip on or cover up the exhaust. I went with the straight edge tips as well and glad I did as there were none weird issues other seemed to encounter with getting the angle right. I did notch the inner tips on each side to allow them to slide in farther and still stay properly centered on the exhaust. The outer one maybe could have used a bit of notching too but I thought it was good enough. Very easy to do with a Dremel.
11-11-2023, 10:58 AM | #128 | |
Rep 1,224
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
12-26-2023, 06:49 PM | #129 |
Rep 206
The Amazon ones definitely will fit on. I put them on my M60i yesterday.
I haven’t gotten a second to look at the actual outcome though. Threw them on in 60 seconds before jumping into my lowering links install and had 0 time after to inspect. Then dropped off at the shop today and forgot to inspect before leaving. Won’t be able to report back for a couple of weeks but the Amazon ones do definitely at least fit on nice and snug. |
02-11-2024, 07:03 PM | #130 | |
Rep 206
More vehicle photos here. |
03-02-2024, 05:21 AM | #131 |
Rep 3
Drives: BMW X5 M50i 2020
Didn’t work out for me. Just dowsnt look right. The black tips would have been better and might try those. I posted a real m image as well…it’s not even close. The rear exhaust on the x5 m is the only reason I was considering one.
03-02-2024, 05:37 AM | #132 |
Rep 3
