05-05-2023, 01:31 AM | #111 |
29
Rep 41
Yes the adapter is 100% OEM BMW. Even though I don't have the car yet and therefore don't have the Flexible fast charger I did open the bag and played with the adapter a bit. It's actually a really nice plug adapter the end the plugs into the charger has some sort of spring loaded latch mechanism that will lock it to the charger and comes with what says on it a water proof cover. And the whole thing is heavy duty.
nZtiZia5606.00 |
05-05-2023, 02:20 PM | #112 |
Rep 7,852
Out of curiosity, for anyone that has the various adapter power plugs for their fast charger, compare the end that goes into the main unit. My guess is that the pins differ, and that signals the base unit the mode to run in, and is part of what adjusts the output's pilot signal.
05-05-2023, 02:23 PM | #113 |
Rep 196
It is kind of weird that BMW increases the range, size of battery and touts a charging time you can’t achieve with the components included in the package. Especially considering these can easily price out at $90,000. I have an i4 arriving in 30 days, so I can just use the adapter that comes with it. That’s a great solution too, right? Buy another car that has the adapter….LOL>
2024 X5 xdrive50e. Ruby Red II, Silverstone Sensafin, M Sport, M Sport Pro, Premium Pack, Contour Seats, Climate Pack, PAP, DAP.
Elle BMW69.50 |
05-05-2023, 02:38 PM | #114 | |
5606
Rep 10,137
Drives: eVeRyOnE mAD!
at level 1, it reaches 10A max. at level 2, it reaches 32A max (yes, the EVSE is capable of going up to 40A, but the on-board charger caps at 7.4kWh, thus 32A max.) fr_tz posted his 0-100% charging session taking 3h9m which is actually slightly faster than the published 3h15m. while he did use a JuiceBox EVSE, the charging capabilities are the same as the 50e’s included fast charger at level 2, so what exactly isn’t achievable? |
05-05-2023, 06:59 PM | #115 |
Rep 7,852
FWIW, many homes in Europe cannot support the full charge rate the new X5 can achieve. Many consumer products don't even come with the charger needed to charge the device at its maximum rate (like many smartphones). I don't see this as misleading.
In the USA, the typical receptacle is a simple 15A/120vac device. It often isn't on a dedicated circuit either, so BMW limits operation to 10A so when you open your garage door, or plug in a vacuum or power tool while charging, you're less likely to trip the breaker. Not everyone has, or can install a 50A/240vac circuit, so they don't include that adapter, that, for many people would never be used. |
05-06-2023, 12:36 PM | #116 | |
Rep 196
05-06-2023, 12:43 PM | #117 | |
Rep 196
05-06-2023, 02:03 PM | #118 |
Generalissimo
782
Rep 1,543
05-06-2023, 02:09 PM | #119 |
Rep 4,667
I think 50e charging package isn’t bad. 7.6kW charging. Combo flex evse. Just need to buy adaptor. 45e got the lousy 3.8kW charger and L1 only evse. To me, it is a huge improvement already.
05-06-2023, 02:25 PM | #120 | |
5606
Rep 10,137
it wouldn't be cost prudent for BMW (USA) if they included level 2 charging for every 45e or 50e because: 1) not everyone needs that level of charging 2) not everyone has a 240V circuit or can afford to have one installed to support that level of charging 2a) if they did, it could be a different type of outlet (not every install is a NEMA 14-50) at minimum, they will include the EVSE that everyone can use to charge with which is level 1 @ 120V Last edited by nZtiZia; 05-06-2023 at 02:44 PM.. |
05-06-2023, 02:38 PM | #121 | |
5606
Rep 10,137
on the other hand, a PHEV has dual power trains (fuel and electric) and a much smaller battery array. many 45e owners are retired or WFH and can let the vehicle sit for 24h to charge at level 1. if they have to cut the charging short, there's always fuel for power. a PHEV requires level 1, but doesn't always require level 2. again, it's a smart cost-saving measure (for BMW). Last edited by nZtiZia; 05-06-2023 at 02:43 PM.. |
05-06-2023, 04:12 PM | #122 | |
Rep 196
rexus300160.00 |
05-06-2023, 05:02 PM | #123 | |
Rep 4,667
05-06-2023, 05:28 PM | #125 | |
5606
Rep 10,137
level 1 charging is inclusive of all persons who decide on purchasing a 45e/50e while level 2 isn't. maybe BMW isn't worried about being cost prudent by not including level 2 capabilities with every vehicle, but the cost savings to them is a positive side effect that not every owner will absolutely need level 2. are you simply looking for a "gimme"? using words like "tout" and "petty" imply ruses of being an inconvenience to you. to your question about not having a 14-50 outlet, if you read my post more carefully, i implied if they already had a 240V circuit, it may already have a different type of outlet installed. in that case, including the BMW 14-50 adapter would be a lost cost for BMW, then multiply that by the tens of thousands of owners who may be in the same situation. |
05-06-2023, 05:31 PM | #126 |
Rep 4,667
But why not offer L2 combo evse with adapter and let user have choice. For the case of 50e, it is a $150 piece of cable at retail, oem cost is probably $75. And why assume people don’t Alfredo have 240V access? I know plenty house here with 240V in garage and use gas dryer, so 240V isn’t even used. In newer build houses I often see 2x 240V outlets in separate circuits. So I don’t see the justification for that assumption.
05-06-2023, 05:33 PM | #127 |
5606
Rep 10,137
it's already a big plus BMW includes a combo level 1/level 2 EVSE with the 50e. 45e owners weren't given a choice...
05-06-2023, 05:36 PM | #128 |
Rep 4,667
This I totally agree as well. But why nickel an dime 50e buyers. For 45e, I think the biggest catch is that 3.7kW charger. But it is also a much less expansive package.
05-06-2023, 05:41 PM | #129 |
17761
Rep 24,785
I'm not following the argument as to nickel and diming the 50e buyers. BMW is giving them more than what they did with the 45e buyers aren't they? I thought they only gave them a 120v cord and if owners wanted to charge at 240v they bought they own Level 2 charger. For the 50e they provide a charger that can be used for 120v but if the owners wanted to 240v, they have an option of buying the adapter or buying a level 2 charger. Am I misunderstanding the situation?
nZtiZia5606.00 |
05-06-2023, 05:44 PM | #130 | |
Rep 4,667
redhot47fla869.50 |
05-06-2023, 05:58 PM | #131 | |
17761
Rep 24,785
I think it is a waste of time to try and figure out the marketing decisions. For example, that is like asking why don't they make adaptive cruise standard since many entry level vehicles have it. The answer is they don't need to from a marketing/sales perspective. Once and awhile it makes for an interesting discussion but the majority of times it just comes off as whining/complaining.
05-06-2023, 06:04 PM | #132 | |
5606
Rep 10,137
from a marketing standpoint, that's a lot of money wasted for BMW to include the adapter when not everyone will or can use it. they will and can use a level 1 immediately, so it makes sense that's the level of charging BMW will include for everyone |
