01-10-2021, 06:05 PM | #133 | |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
https://www.canadiantire.ca/en/pdp/m...-0111519p.html Toggle button allows me to check current, voltage, and charge status (LO, 60%, 70%, 80%, 90%, FUL). Second toggle button allows me to choose between three different amp choices - always defaults to lowest 4 amp and automatically scales up and down. Charging status light blinks during charge operation, and becomes solid light when fully charged. Lot bigger in dimension than usual battery tenders and has an automatic fan to cool it down.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
01-10-2021, 08:54 PM | #134 | |
Rep 177
thanks, man!!! This or any similar ones seems to be not available on Amazon. I am in Texas. Curiosity question - I have read at different places that charging the battery at a higher amp can damage the battery. With your system, it seems it started charging at a higher amp, and then it stabilized at the trickle charge rate once it was topped off. Is it not going to damage the battery in the long run? Forgive my lack of knowledge or relevant experience in this area.
2021 BMW G05 X5 xDrive40i - Phytonic Blue/Coffee Vernasca, "an adorable beast" :: 11/2020.33 (Delivered) -- 11/2020.45 (Updated at dealer)
01-10-2021, 10:18 PM | #135 |
Rep 6,946
Look at it this way...the on-board alternator on my last BMW was a 200A device. I'm not positive how big the one in the X5 is, but they both have the same type and approximately same-sized AGM battery.
What you DON'T want, is to be trying to push high current into a fully charged battery, so one with some smarts to drop the level when that is approached should be fine. |
ChiefOne81.00 |
01-10-2021, 10:20 PM | #136 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
ChiefOne, rule of thumb: up to 10% of the battery capacity is safe, for the X5 battery that will be ~10 amp (10% of 105 Ah). My charger did push around 7 amp at the beginning during bulk charging, but quickly tapered down. I can force it to stay at or below 4 amp if I want to, I just let the automatic setting decided what amp is appropriate and it did a good job. It has a microprocessor that finds the optimal settings itself. All modern chargers should have the same.
By the way, don't let those two hood latches go into the sockets, make sure there is gap. I am pretty sure this is how iDrive knows if the hood is open or closed (and when open it turns off the 48V system).
01-11-2021, 08:03 AM | #137 | |
Rep 177
Definitely, makes sense. I am going to look for a similar product in the US market and will try. Your suggestion on not letting the hood latches go into the socket seems an interesting but key factor. So far I have been gently lowering the hood, but was not preventing it from going into the sockets. Wow, a lot to watch for. Thanks for the pointers, truly appreciated. I hope I am able to charge the battery as well.
01-11-2021, 08:05 AM | #138 | |
Rep 177
Yup, seems reasonable. I am gonna order some products and will try again soon. Hope it/something works. Thanks for the insight!
01-11-2021, 08:10 AM | #139 |
11
Rep 44
I have a camera in my garage. I checked the footage and noticed it was about every 410 seconds that the car restarted some units when charging with Noco, the parking light and gear shifter light etc. lit on as well. It's so frustrating, I don't know if it's the car's issue or the charger is not compatible.
The charger you SmartSaves have was disc, the only similar one I can find is https://www.canadiantire.ca/en/pdp/m...w.ds#store=235 Last edited by tcbmhell; 01-11-2021 at 08:34 AM.. |
01-11-2021, 08:31 AM | #140 | |
11
Rep 44
01-11-2021, 10:09 AM | #141 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
tcbmhell the newer model you found is even better than the one I have, I would get it. By the way, I drove the X5 this morning and didn't see any errors.
01-11-2021, 10:18 AM | #142 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
It makes sense because there must be some sort of switch inside those two sockets (hood latch goes into) that informs the iDrive the hood is open/close. When it is open then it turns off 48V lithium battery system and let the 12V system to receive charge. It appears there needs to be a clear separation when we want to charge the 12V battery from external chargers.
01-11-2021, 10:33 AM | #143 | |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Idea is simple, don't do anything that might wake up the car's electrical system while it is being charged. Don't check the app, bring the keys near, etc. All proximity sensors are off including tailgate. Parking brake is on. Turn off the iDrive manually. Hood stays open. Charger engaged. Lock the doors. Keep the charger somewhere where you can monitor it (mine was on a stepladder in front of the car).
01-11-2021, 11:10 AM | #144 |
11
Rep 44
ChiefOne Do you remember whether you drove the car out before the last time it was successfully charged, or whether you connected the charger once the car was turned off?
Every time I tried to charge it was after the car was locked and parked there for a while. I don’t know if it was because after parking for a while, the car would go to a certain state to prevent charging. Last edited by tcbmhell; 01-11-2021 at 11:57 AM.. |
01-11-2021, 01:32 PM | #145 | |
Rep 177
https://g05.bimmerpost.com/forums/sh...1&postcount=63 https://g05.bimmerpost.com/forums/sh...7&postcount=64 To answer your question, once CTEK showed that the battery is completely charged, I unplugged the CTEK, did not drive the vehicle, had no need to, and after about 10 hours or so plugged the BMW charger. The status was stuck at 3 for a bit, but then it charged completely. After that I have tried a few times, all unsuccessfully.
01-11-2021, 01:38 PM | #146 |
Rep 177
I am logging something else that I am trying:
10 Jan 2020, 07:30 PM CST, I plugged in the BMW charger in the following conditions - - Vehicle is in a closed garage - Hood is gently down, the hood latch is not in the socket - Car is locked using the key fob - Have been in the garage few times to take a look, but have not carried the key with me. No attempt to wake the car. - When I peek in from time to time, the Hazard symbol, the Electronic Park red light, the headlight AUTO switch (Green) are lit. Everything else is shut. - Sometimes I do hear some clunks in the vehicle, but not sure what system is making that sound. - It switched to stage three within minutes. Little over eighteen hours now, the charge status is at stage 3.
01-11-2021, 01:40 PM | #147 | |
Rep 177
01-11-2021, 01:53 PM | #148 | |
11
Rep 44
From the footage I could see that a loop of lights on and off is about 410s Last edited by tcbmhell; 01-11-2021 at 02:02 PM.. |
01-11-2021, 02:18 PM | #149 |
Rep 11
Exactly the same here.
01-11-2021, 02:27 PM | #150 | |
Rep 804
When my 45e is charging, I have noticed the same lights are lit, at least in the beginning of a charging cycle. |
01-11-2021, 04:15 PM | #151 | |
Rep 11
01-11-2021, 05:58 PM | #152 |
Rep 177
This all sounds absurdly crazy, and to be honest borderline pathetic. It's beyond me to comprehend why BMW would introduce such a behavior. This could have been an easy thing but has been a solid headbreaker for the past few weeks.
Nonetheless, I will keep trying.
01-11-2021, 06:58 PM | #153 |
13706
Rep 20,381
What would be interesting to see is if the wake up/light pattern occurs when you are not charging the battery, hood closed and doors locked. If it doesn't, then try the test again with the same as if you are charging (hood open, doors unlocked, etc.) but no charger connected.
01-11-2021, 06:59 PM | #154 | |
311
Rep 332
SSMXV
