01-31-2024, 06:08 PM | #155 | |
Rep 3,761
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 01-31-2024 at 06:24 PM.. |
01-31-2024, 06:22 PM | #156 |
Rep 80
That is because in soort mode it builds a bit more of a reserve over base due to the likelyhood of heavier accelleration etc. whatever charge level it is at (5 or 6) it is constantly drawing down and readding the charge to maintain a baseline. Battery hold does the same thing. If you coukd drive on a perfectly flat highway and never change your speed, you would be more correct but wven then, aerodynamics would pkay a much bigger role in fuel economy than weight. Weight is a big factor on accelleration.
01-31-2024, 06:30 PM | #157 | |
Rep 3,761
And no, Battery hold is very different that sport. Battery hold allows ICE to be off and car driven by eDrive. Sport mode really doesn't do that. There are very unqiue condition where even in sport mode, ICE is off, but it is extreme rare. In my experience, it usually involves a very step slope down hill where speed is no more than 5-10mph.
2022 G05 B58/PHEV
+ a few very old BMWs |
01-31-2024, 06:34 PM | #158 |
Rep 80
There is no such thing as perfectly flat constant condions. It is always going to vary to a greater or lesser degree.
Explain to me how the dozens of 50e owners are achieving the same mpg as I am. I haven’t seen anyone claim this kind of mileage from a 40i so why is that? Are 50e owners fabricating this? |
01-31-2024, 06:42 PM | #159 | |
13719
Rep 20,403
01-31-2024, 06:46 PM | #160 | |
Rep 3,761
27-29MPG after HVB deplete is great, but not unreasonable. My 45e can do 28 in my best day. I am not sure 40i owner get worst mpg on highway. And I am not sure everyone with 50e get 29MPG. Over the year, I have ask people to share trip computer screen with me, on average I would say 40i is 10% better than 45e. If you don't mind, share the since factory screen with me, we can do a apple to apple comparison with 45e average number
2022 G05 B58/PHEV
01-31-2024, 06:57 PM | #161 |
Rep 3,761
It is largely the case. My best understanding is if Edrive motor is engaged, the eDrive mile get counted. Majority will be in Electric mode or hybrid in eDrive, it also registered if ICE and eDrive engage together (eAssist). Reason I say that is, usually after a very long drive in sport mode, I see a bit of eDrive miles. For example, Mountain View to Tahoe, about 230 miles with a good uphill portion, I will see 0.5 eDrive miles. I am very sure entire drive was in sport with ICE on. So the only place it can come from is eAssist. I cannot think of another reason.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 01-31-2024 at 07:47 PM.. |
01-31-2024, 06:59 PM | #162 |
Rep 99
Drives: X5 50e
The "800 extra lbs" clearly shows that you're referring to the PHEV. But your description of the ICE's role would seem to apply more to a 'mild hybrid' and that includes every new X5 and X6. I assume switching to the mild hybrid system allows BMW to use the same type of transmission across all models - one that replaces the torque converter with a efficient low speed/high torque electric means to get rolling (plus clutch), and also adds a small amount of torque boost when called-for. In the PHEV, the ICE is maybe 'de-tuned' relative to the mild hybrids, but more efficient. Then the tranny gets a much bigger and higher voltage electric motor, which participates more during normal driving. Is the "800 pounds" of electric 'stuff' really an albatross? I think the economy numbers speak for themselves. And the fun is still there. If you're at 80 and don't like a situation or driver around you, when you goose it with the electric boost you're gone and the low hundos feel like nothing. No albatross under the seats as far as I can tell!
01-31-2024, 06:59 PM | #163 | |
13719
Rep 20,403
While we are asking questions, what is the difference between eAssist and eBoost?
01-31-2024, 07:15 PM | #164 |
Rep 80
I do a 300 mile roundtrip every month or two. On the way back, I have zero miles of electric showing since I cant plug in. Next time, ill take a screen shot. Try toggling the end of the turn signL stalk - it will show you in the instrument cluster the plus or minus kwh/mile(or whatever units you choose) while driving. The miles remaining of electric range doesnt tell the story because it is trying to maintain and balance that amount in battery hold or sport mode. It will still add miles if you go down a long hill because it isnt going waste that energy but it will then start to use it until you get back to base of zero or (5 ish in sport) or whatever range u activated battery hold.
01-31-2024, 07:16 PM | #165 | ||
Rep 3,761
I wonder if anyone think BMW EPA number actually mean something. It is as much of an apple to apple comparison as it can be. For those who live by BMW literature, this should the the gold standard. Quote:
eAssist vs eBoost, I think the best person to answer is nZtiZia . My understanding is, most of what we encounter, low to medium throttle input, low to mid RPM, it is all eAssist. eBoost occurs when we operate engine in high RPM and max acceleration situtation. I have never seen or notice eBoost in my usage.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 01-31-2024 at 07:30 PM.. |
01-31-2024, 07:24 PM | #166 | |
13719
Rep 20,403
01-31-2024, 07:25 PM | #167 |
Rep 80
It does combine both when calculating the mpg which scews it but I am calculating this by how much gas it takes to fill it up and actual miles covered or alternatively goi g by the mpg shown if I started with zero miles charge (there is always some amount of charge - we dont know the split).
If you use up ‘the charge’ then it act like a normal hybrid which is also much more efficient than non hybrids. The only issue with the 40i is that the e-assist consists of a small battery and small electric motor so it is not capable of collecting near as much energy on decelleration. Plus the engine itself is tuned for better performance and therefore not as efficient as the 50e - it will still be better than not having mild hybrid properties |
01-31-2024, 07:28 PM | #168 | ||
Rep 3,761
For regen in highway speed, in my experience, it is super mild at high speed. The car try to not regen and coast, which is the most energy efficient. Regen strength if you will, increase significantly at slow speed. I recent went down this steep down hill stretchy, only 2 miles, max speed was less the 5MPH, mostly 2-3MPH, sport mode, but ICE was off, foot modulate brake 100% of time. I recovered 20% (of 16kWh) just like this. Quote:
HEV (non plug in), they have small battery, ~2kWh. That is all they need to gain overall efficiency. Over weight will be much less. When you operate PHEV as HEV, 50e in this case, 18kWh is just dead weight. So PHEV as HEV will be less efficient than a real HEV. Weight does matters. As for detune engine, I explained above. The peak detune. Under the same usage, the output is needed. I would say there is no efficiency different at all, just lower RPM, torque comes a bit earlier, so less HP
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 01-31-2024 at 07:36 PM.. |
tooloud10796.50 |
01-31-2024, 07:30 PM | #169 |
75
Rep 378
As RichardE states, I will love the 50e for around town (up to 60kms per day for one charge) and flexibility of the Hybrid mode for longer distances out of town for a reasonable 8L/100kms approx. Solar smashing through our Tesla battery to replenish makes it perfect for our lifestyle. I have the Tesla Y covered for charge point in garage, now just need to find best type of charge point for the incoming 50e....
I had a chipped B7 RS4 (331kw) years ago and thought it was amazingly good, but to think the 50e out powers that is just amazing tech wise... |
01-31-2024, 07:34 PM | #170 |
Rep 80
Exactly and that 20% gets fed back in along with power from the ice which is where the gain happens. A regular ice car throws this energy away in the form of heat from braking. You often can’t feel the regen or boost at all as it is stphoned in and out as needed to maintain base charge or in the case of having miles of ‘plug in’ charge will use more of it proportionally that to advantage.
01-31-2024, 07:39 PM | #171 | |
Rep 3,761
2022 G05 B58/PHEV
01-31-2024, 07:43 PM | #172 | |
13719
Rep 20,403
It bothers me (too many years preaching/making sure data being shown was accurate and meant what it was supposed to mean) that BMW is not showing the actual/accurate values for the gas MPG and mileage. Showing an MPG that includes mileage from the EV motor may be good for marketing but it is not really a number that can be compared against anything.
tooloud10796.50 |
01-31-2024, 07:55 PM | #174 |
Rep 3,761
Mind share the since factory trip computer screen? I have about 5-6 50e data. I have about 40x 45e data share from member here as well. Just want to compare the differences.
2022 G05 B58/PHEV
01-31-2024, 08:02 PM | #175 |
13719
Rep 20,403
Granted it is generally statistical heresy to do so but what is the average of the MPG's you calculated for those 50e's?
01-31-2024, 08:06 PM | #176 | |
Rep 3,761
As you said, the mi/kWh should be more accurate, because it is total eDrive mile /total kWh used in this calculation. Assumption is eAssist mile is minimal. the kWh used also included regen kWh. The MPG is exactly as you said, it is pessimistic number, because this number didn't account for regen, because regen kWh get counted toward mi/kWh.
2022 G05 B58/PHEV
