02-22-2023, 06:00 PM | #156 | |
345
Rep 322
Who cares "1000 time stronger". It's all about lumen output, which is regulated by the DOT. LED and lasers are the same in the US. I had the Laser lights on my last X5. They weren't any better than my current M5 and X7. People get hung up on thinking they were better because they were part of a package and had limited availability. Oh cool... I had a little blue piece of plastic in my headlights and a fancy yellow diamond laser sticker. The performance wasn't any better than the LEDs with them being detuned in the US. Now outside the US.... that's a totally different story.
Current - Second 2023 XM (first one was taken back by BMW) and 2023 X7 40i
Past - 2009 X5 35d, 2011 MB E350, 2011 740i, 2015 X5 35d, 2018 M550i, 2019 X5 40i, 2021 M5C |
02-22-2023, 06:45 PM | #157 |
Rep 221
I think people also fail to realize only the high beams utilized laser.
I drive in/around the city 95% of the time, while the idea of laser headlights were cool to think about, losing them doesnt bother me. |
02-22-2023, 06:58 PM | #158 | |
Rep 246
After driving 1000 miles she's decided that her current LED's are better than the unlocked G05. I did unlock the G07 for anti-dazzle through the backdoor programming and then applying the update. I really notice no difference between the lasers and LED's, as there really shouldn't be. Color accuracy should remain better on the lasers. |
rccarps2345.00 |
02-22-2023, 08:33 PM | #159 | |
Rep 197
Brendan///M48.00 |
02-22-2023, 09:34 PM | #160 | |
Rep 832
Laser diode illumination excels compared to LEDs past 5 meters.
Two is One and One is None
02-22-2023, 11:29 PM | #161 | |
Rep 430
Is this a typo in the specs? I don’t see any air suspension mentioned elsewhere. |
02-23-2023, 12:25 AM | #162 | |
Rep 246
I’m also going to go out on a limb and say if there was an advantage at this juncture, the two automakers that spent considerable resources investing in the tech (bmw and vag) would continue to be using it, as well as the maritime industry which unlike autos isn’t subject to lumen restrictions. Given they’ve all switched to LEDs I think we’re beating a dead horse here. Remember even from the promotional videos, the main advantage was the lasers were going to allow more compact and creative headlight design, given what we’ve seen on so many different cars lately I don’t think engineers are all that limited. Where laser light sources will continue to be used is in theater, where color production is paramount as compared to led which still struggles somewhat with color fidelity. Interestingly even in that usage, the led produces higher lumen output per area and lower thermal requirements, but at the expense of color accuracy. Last edited by Tehnoid; 02-23-2023 at 12:32 AM.. |
Tejas18361002.00 |
02-23-2023, 12:36 AM | #163 |
Rep 113
It's probably just me but I haven't been all that impressed with the laser lights on my 2022 X5MC.
Maybe they've been throttled down by some sort of DOT regulation... |
02-23-2023, 08:09 AM | #164 |
Administrator
41312
Rep 21,248
Live walkaround video:
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
02-23-2023, 08:43 AM | #165 | |
Rep 2,869
Amen to the return of the 818M rims! I prefer Marina Bay Blue for the X5M, will mostly stay with color for my LCI build, was hoping for Java Green to be a P1 color instead IOMG.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
02-23-2023, 09:16 AM | #166 | |
Rep 221
If I go with the individual program, I might actually go for something like midnight sapphire. That paint seems to be more of a true dark blue, whereas TBII looks like it has a hint of purple. |
02-23-2023, 09:59 AM | #167 | |
Rep 246
Again, I'll take the anecdotal path, if there was a significant improvement, BMW and VAG, who spent massive amounts of money on the technology would still be using it. It's no longer supply chain limited as well. |
02-23-2023, 12:30 PM | #168 |
Rep 6
Big miss on the displays. Almost looks like two tablets side by side.
Blindside_1376755.00 |
02-23-2023, 03:50 PM | #170 |
210
Rep 336
Quote: "The electric motor, complete with power electronics, is integrated into the compact housing of the 8-speed M Steptronic transmission and delivers an additional up to 12 hp of output and 147 lb-ft of torque"
I'm assuming these numbers are included in the HP and Torque rating for the vehicle? If so, while I know BMW often understates actual power, how does this work that it (and the M50i vs M60i) have the exact same or almost identical numbers for the pre-lci? Wouldn't the motor/turbos have to be creating considerably less torque than previously for the numbers to be staying relatively the same? What am I missing? |
02-23-2023, 03:56 PM | #171 | |
Rep 221
If the specs really are inclusive of the 48V motor, then I'm gonna guess the 147lb-ft of extra torque only kicks during low RPMs and then the ICE takes over completely once the turbos are at full boost. Benefit of this would be improving the lower end of the torque curve (more immediate felt acceleration) while keeping the same top end and prolonging the life of the 48V system. Just my guesses though. I have zero actual sources to back this up. |
scotchy210.00 |
02-23-2023, 06:46 PM | #172 | |
Rep 246
scotchy210.00 |
02-23-2023, 09:25 PM | #173 | |
Rep 199
Of course, with the rampant BMW under-rating, those specific numbers are likely wildly wrong, but the general concept should be right. Adding the electric gives a torque boost/fill right off idle and makes the auto start/stop much smoother since the electric can get the car rolling. In performance driving the electric likely does next to nothing, though. |
scotchy210.00 |
02-24-2023, 05:01 PM | #175 |
210
Rep 336
Yeah just looking at this now, seeing improvements of about .3 seconds on both the 0-60 and quarter mile for the X7 M60i vs M50i. Will be interesting to see how the X5/6M and M60i go.
02-24-2023, 05:38 PM | #176 |
Rep 1,054
What about the Alpina X7s - stating 3.9 0-60 with 630 HP
https://www.caranddriver.com/news/a4...a-xb7-details/
2023 X5MC | Donington Grey | Black
