01-30-2020, 04:19 PM | #155 | |
Rep 159
Thanks, I will try that. I did back my files up also. Just thought it would be so obvious when taken to the dealership, the Alpina Dash display is so different! |
01-31-2020, 06:02 PM | #156 |
Rep 159
The Alpina Dash is just awesome. My car is Alpine White with Ivory White /Night Blue Full Merino and dash with the Aluminum Tetragon trim ( I like how that trim compliments the ivory white and night blue).
Then I have blue for the accent lighting color, so the blue Alpina dash just makes it look amazing. |
LexxM31703.00 |
02-25-2020, 12:02 PM | #157 |
Rep 20
hey guys,
Did anyone discover how to keep foglights on with highbeams? also can't switch light off from lightswitch, probably cause DRL is coded by default, need to change that as well. Everything works great, trunk key doesn't close from inside and keyfob needs to be pressed at least 3 secs to close trunk, will have to check that later |
02-26-2020, 05:07 PM | #159 |
Rep 2,610
https://www.bimmerfest.com/forums/sh...d.php?t=983244
E-Sys 3.33.4 for G-series (eg G05 aka G005 aka I-STEP S18A) coding. E-Sys 3.34.xx exists, but is not well supported — so as it stands today, I would advise to stick to 3.33 (lots of skipped details behind that, too chaotic to post). If VO coding-only (change FA, code ECUs, nothing else), that plus latest psdzdata lite is enough. If FDL coding, also need a launcher (Launcher Pro from Tokenmaster, chaotic donation-ware) or ESysX (less chaotic pay-ware). As of the date of this post, psdzdata lite at the link above (v4.21.32) is plenty latest for any G05 I-STEP out today. |
02-27-2020, 06:29 AM | #160 | |
Rep 5
Hello buddy, can you send me a copy of Automatic Speed Assistant for X5 G05, thank you very much! Email qq1071785793@gmail.com |
02-27-2020, 08:33 AM | #161 | |
1202
Rep 1,587
04-27-2020, 06:40 AM | #163 |
Rep 99
Can I code my G05 X5 with this cable;
https://www.amazon.co.uk/ENET-OBDII-...7987217&sr=8-3 and the appropriate software obviously. Thanks all. |
04-27-2020, 08:39 AM | #164 | |
Rep 2,610
04-27-2020, 11:17 AM | #165 |
Rep 99
04-28-2020, 04:14 AM | #166 | |
23
Rep 48
Drives: BMW X5(G05) 2019
Use the READ ECU instead of the READ SVT. |
04-28-2020, 04:29 PM | #167 |
Rep 99
04-29-2020, 02:39 AM | #170 |
Rep 99
04-29-2020, 10:53 AM | #171 |
1202
Rep 1,587
I bought the dongle version direct from the supplier. They will only supply the latest version whether software only or dongle.
04-30-2020, 12:26 PM | #172 | |
150
Rep 365
05-01-2020, 07:14 AM | #173 |
Rep 99
05-01-2020, 08:36 AM | #174 |
150
Rep 365
05-03-2020, 02:52 PM | #176 |
JoseSportM
415
Rep 371
